MagmaJctAz Samba Member
Joined: November 26, 2011 Posts: 289 Location: Mesa, AZ
Posted: Fri Dec 02, 2011 4:35 pm Post subject: |
Many years ago I replaced my rusted and worn heater boxes with new ones. Despite the fact all new heaters have crappy springs vs. the original stuff, I thought I would get better heat. I didn't. Took me years to realize these new heaters have inferior heat sinks that don't even reach the sheet metal housing. In addition, I suspect he ID of the pipes are just that, pipes, not the shape of the original heaters.
I've seen in the back of the magazines suppliers that sell "heavy duty" heaters. How do these compare to stock? I don't want to spend another small fortune for the same thing I already have! |
zombiebug Samba Member
Joined: August 18, 2011 Posts: 1227 Location: Webster, MA
Posted: Fri Dec 02, 2011 5:20 pm Post subject: |
The cables to the butterfly valves in my heaters under the seat are broken. How do I replace them? Where can I get the cables? Is it an easy process or a PITA? |
Paul Windisch Samba Member
Joined: September 02, 2009 Posts: 2546 Location: Clinton Township, Michigan
Posted: Sat Dec 03, 2011 7:32 am Post subject: |
I'm not sure where to get the ACTUAL cable for the rear outlets, but I used one for the heat exchangers cut down in length a little bit. A little over $5 from aircooled.net. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer |
Posted: Sat Dec 03, 2011 8:13 am Post subject: |
I woke up this morning thinking about your tutorial to the cooling and heating system. I remembered a couple common mistakes people make, and you may want to consider added them.
I was part of a VW car club back in the mid to late 90s in San Diego. (Actually, a former friend and I started it.) A common mistake I saw was doghouse coolers without the sheet metal duct installed to exhaust the heated air outside the engine compartment. Apparently, people don't realize that this heated air is pulled into the fan.
Another common mistake is doghouse coolers with the earlier thinner fan instead of the wider fan. I'd read about this from Bob Hoover but only recently did I have an opportunity to see it first hand. A neighbor was being foreclosed on. He was into sand rails and had a lot of chrome stuff like fan housings, some spare alternators, etc...
He gave me all this stuff. Later on my fan developed stress cracks around the mounting nut. I went through all the fans I received from this guy. One of them was mounted on an alternator only, the other was fully installed in a doghouse fan housing. When I pulled the fan out and compared it to mine, I realized it was the wrong fan.
I ended up having to buy the correct fan. Two common problems that can lead to overheating and short engine life. |
Beetlebaum Samba Member
Joined: December 04, 2008 Posts: 2181 Location: Virginia Beach, VA
mrbigmax Samba Member
Joined: September 10, 2011 Posts: 1289 Location: Modesto, CA
Posted: Sat Dec 03, 2011 7:57 pm Post subject: |
Yes, and that short pipe is supposed to be sealed by a rubber grommet through the rear cooling tin. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-Engle W110 cam
Patty B. Samba Member
Joined: July 14, 2005 Posts: 2181 Location: Brampton, Ontario, Canada
Posted: Sat Dec 03, 2011 9:37 pm Post subject: |
GREAT write up Paul!!
I keep messing around with lever and window and knob to find the defrost sweet spot but am thinking now I have a kink or hole in the A pillar tube, driver's side---heat I have (enuff to make a rubber shoe stink) wind at the window is a lacking. I find it's the humidity that does me so I'm wiping my winds all the time--gonna play some more now that I've learned a few more things here~!! |
Posted: Sun Dec 04, 2011 9:55 am Post subject: |
Okay, my car has those little metal pipes, but also, the "bulbs"/boxes on the muffler don't hook up to the J-tubes (it's supposed to be a good exhaust...). How do I fix that? Just extend the tubes down to the J-tubes?
And also, could someone take a picture of where the rod from the thermostat hooks up to the flaps and where it runs with the shroud on the car please? _________________ 1973 Super Beetle
2003 New Beetle
Post your Super here: http://www.thesamba.com/vw/forum/viewtopic.php?t=331999
Beetle Bums VW Club Member |
FOE Samba Member
Joined: December 12, 2008 Posts: 37 Location: Wales, UK
Posted: Sun Dec 04, 2011 1:45 pm Post subject: |
Excellent write up. I'm sure those of us who's heating is working will vouch it's really worth the hard work to get the heating up and running especially in those areas where it's colder. |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Sun Dec 04, 2011 6:12 pm Post subject: |
Beetlebaum wrote: |
And also, could someone take a picture of where the rod from the thermostat hooks up to the flaps and where it runs with the shroud on the car please? |
the little couplings where the hoses attatch sit into the preheaters from the number 2 and 4 exhaust. that "bulb" attatches to the heat exchangers with a wide clamp. not sure where you could get the official one, but folks have taken aluminum cans and wormclamps to fashion a replacement. _________________
[email protected] wrote: |
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
pb_foots Samba Member
Joined: April 15, 2010 Posts: 1089 Location: Ben Lomond, CA
Posted: Wed Dec 14, 2011 5:45 pm Post subject: |
Any recommendations regarding cleaning the heat exchangers? MIne have been disconnected for some time and I'd bet they are full of oil and gunk. Last thing I want to do is pump that into the cab when I fix the system. |
Posted: Thu Dec 15, 2011 10:33 am Post subject: |
pb_foots wrote: |
When I cleaned mine, I blew lots of compressed air through them until the loose crap stopped coming out. Then I ran mineral spirits through them, changing their position and swishing them around periodically. I did this for a 9 hour shift at work. Then I drained all the mineral sprits out of them and washed them with plain soapy water (to remove the mineral spirits) followed by a wash of plain water. Then I blow dried them with the compressed air again and allowed them to air dry after that. It smelled a little bit the first couple times I used it, but it was still warm out so I drove around for several days with the heat on full and the windows open. I know the heat exchangers are working even with the heat off, but I did it that way to monitor the smell before I actually NEEDED heat with the windows closed. Really, any remaining smell after cleaning was gone in about 100 miles. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-Engle W110 cam
Posted: Sat Dec 17, 2011 8:16 pm Post subject: |
Good plan, thanks. |
Robbo112233 Samba Member
Joined: September 18, 2011 Posts: 817 Location: London, UK
Posted: Sun Dec 18, 2011 4:25 pm Post subject: |
This may have been answered, and if it has i apologise.
But does it matter what exhaust we are running, i have a aftermarket exhaust (no idea which one) and am wondering if i can still get the heat running?
I am new to all this and have little to no knowledge. _________________ 1973 Bug
Beetle Bums VW Club member
Archie's Photo Gallery |
PatterBon Samba Engine Connoisseur
Joined: September 27, 2008 Posts: 3446 Location: Copperas Cove, TX
Posted: Sun Dec 18, 2011 5:32 pm Post subject: |
Still getting the last piece for my fresh air, sorry it's taking so long _________________ PNW Dub Folk & Kitsap dub Folk (KdF)
Austin Aircoolers VW Gang
2020 Ford F-150
1973 Standard Beetle
1969 Cessna 172K Airplane
1959 Karmann Ghia
US Army CH-47 Chinook Helicopter Repairer |
Posted: Sun Dec 18, 2011 7:40 pm Post subject: |
Robbo112233 wrote: |
I am new to all this and have little to no knowledge. |
as long as your aftermarket exhaust is setup to run with factory heat exchangers, you are good... _________________
beetleman217 Samba Member
Posted: Sun Jan 01, 2012 10:45 am Post subject: |
Outstanding thread. It only misses a same level description of the stale air system. _________________ If all else fails, stop using all else
1977 Westfalia
1961 Beetle |
Posted: Sun Jan 01, 2012 5:48 pm Post subject: |
beetleman217 wrote: |
Outstanding thread. It only misses a same level description of the stale air system. |
different forum for cars of that era... this is the fatchick forum... _________________
