Narrow Rear Suspension
Page: Previous  1, 2
bill may
bill may is offline
PostPosted: Sat Dec 30, 2006 8:35 pm    Post subject: Reply with quote
have you tried the 68- newer forum?
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
56Hotrod
56Hotrod is offline
PostPosted: Mon Jan 22, 2007 2:50 pm    Post subject: Reply with quote
Has anyone looked into this?
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=DRS0007&cartid=0122200769263884
This is what I was researching to do for my 56.
Also, VWZACH, have you gone through this yet? I found several companies that will widen your stock wheels to taste, for instance:
http://www.stocktonwheel.com/wheel_widening.htm
Infamousaircooled
Infamousaircooled is offline
PostPosted: Wed Jun 20, 2018 8:26 pm    Post subject: Re: Narrow Rear Reply with quote
Leslie Chloupek wrote:
That Convert is Mine. If you can cut and weld it is a little bit of work.
Thank you for your comment!! Laughing
I know this is an older post but I have been looking up this subject and it seems there isnt a lot of info on this modification. I am going to run 17 x 7.5 on all four corners and I have been fabricating for 20 yrs shouldn't be to bad of a job. It looks like you cut it in the middle, did you install a sleeve? I was told there are spot welds on the end that can be drilled out and remove the end, cut down the tube and reweld with spot welds. True or false?
Page: Previous  1, 2
Page 2 of 2
