Pastis, The Ultimate Subaru Boxer diesel EE20 Vanagon Syncro
Goto page Previous  1, 2, 3 ... 37, 38, 39, 40, 41, 42  Next
Forum Index -> Vanagon/Eurovan Share: Facebook Twitter
syncrogreg
syncrogreg is offline
PostPosted: Tue May 29, 2012 8:00 pm    Post subject: Reply with quote
syncroserge wrote:
Well there you go.. you figured it all while I was writing two lines Laughing
Thank you too for taking the time to write Wink
GSB
Now on FACEBOOK!! http://www.facebook.com/subarudiesel
- Subaru EE20 IN action : http://www.youtube.com/watch?v=1qSg_kSAO1k&feature=youtu.be
- Syncro Subaru DIESEL : http://www.thesamba.com/vw/forum/viewtopic.php?t=434656&highlight=subaru+diesel
syncrogreg
PostPosted: Tue May 29, 2012 8:12 pm    Post subject: Reply with quote
I found this melted spot where the front blower resistor seats...
I'm wondering if this is due to the old hard to operate blower motor or this just means that it the resistor is toasted and needs replacement Rolling Eyes
GSB
crazyvwvanman
crazyvwvanman is offline
PostPosted: Tue May 29, 2012 8:27 pm    Post subject: Reply with quote
The resistor normally gets very hot but some airflow from the fan limits how hot. Once the fan motor starts to die the extra heat can melt the plastic. Some people make the mistake of leaving the fan turned on even when the motor has frozen and then the resistor can slowly burn up, sometimes also making a hole in the plastic.
The photo is not very clear but the resistor looks ok still as best I can see. Just test it with the new motor.
Mark
GSB
syncroserge
syncroserge is offline
PostPosted: Tue May 29, 2012 8:29 pm    Post subject: Reply with quote
Not uncommon unfortunately..
http://www.thesamba.com/vw/forum/viewtopic.php?t=513875
syncrogreg
PostPosted: Wed May 30, 2012 11:23 pm    Post subject: Reply with quote
Got the BMW brake booster upgrade done.
Thanks to Herman this upgrade is very strait forward! that shows the difference in diamter. 9" for the Vanagon and 10" for the BMW.
Cut 1/4" thread from new brake booster, Drill (8.5mm) and tap the vanagon clevis to 10mm 1.5
the adjustment of the clevis needs to be done well as 1mm equal 5mm travel at the pedal. So 2 turns of the clevis could change your pedal travel about 15mm too high or too low Crying or Very sad .... anyway just make sure you have your pedal sitting where you want Wink that was a fun upgrade Very Happy
GSB
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed May 30, 2012 11:26 pm    Post subject: Reply with quote
I measured the mating face to the clevis pin before removing from the VW one,that was perfect the first time,since I did it on the car Wink
Good work Greg Cool
syncrogreg
PostPosted: Thu May 31, 2012 10:05 am    Post subject: Reply with quote
Good work Greg Cool
Thanks!
Next is sealing and installing the Syncro tank Very Happy MIAM MIAM
GSB
Welchmaster
Welchmaster is offline
PostPosted: Fri Jun 08, 2012 8:42 pm    Post subject: Reply with quote
Greg,
hows the progress coming along? cant wait to see it!
________________________
85 2wd Doka, 1.9 5-speed.
Picking up the new van this week... stay tuned!
"Further up, further in!"
syncrogreg
PostPosted: Fri Jun 08, 2012 9:21 pm    Post subject: Reply with quote
I'm. In the bonnaroo crowd listening to radiohead right now... will post this week progress on today Very Happy
GSB
otiswesty
otiswesty is offline
PostPosted: Tue Jun 19, 2012 9:31 am    Post subject: Reply with quote
It has come a long way...
1989 Syncro Westfalia
1978 Sage Green P22 Westfalia
Steyr-Puch 463.241
A-D Puch Inter 10
Jon_slider
Jon_slider is offline
PostPosted: Tue Jun 19, 2012 9:53 am    Post subject: Reply with quote
this is the latest photo I could find of the project
I look forward to the day that the Subaru Diesel powered Syncro starts driving..
Where in the world are the The Lost Burritos?
otiswesty
PostPosted: Tue Jun 19, 2012 2:20 pm    Post subject: Reply with quote
So ths is not the Syncro?
Steyr-Puch 463.241
A-D Puch Inter 10
SCM
SCM is offline
PostPosted: Tue Jun 19, 2012 2:42 pm    Post subject: Reply with quote
No, I think that is a customer or friend of Greg's.
'91 Westfalia GL Automatic
2.3L GoWesty Engine
syncrogreg
PostPosted: Mon Jul 23, 2012 5:18 pm    Post subject: Reply with quote
Hi Volks!
I'd like to have some input from the community.
I'm installing the Webasto diesel space heater and I would like to fit it in the front... I'd like to hook it up to the air diffusion system so it will spread in the van uniformly.
The >86 and <86 use different vent holes for the front heater unit...
Do you think it's possible/would it make sense that one of the unused hole of my 86 front heater could be perforated to use the Webasto inlet to spread the air in the cabin....
Feel free to share your idea! Thanks
up to 86 oval is plugged but the round is open
86+ use the oval vent instead of the round
GSB
Howesight
Howesight is offline
PostPosted: Mon Jul 23, 2012 9:28 pm    Post subject: Reply with quote
Hey Greg:
That approach will work, but only if you plug the fresh air inlet at the front of the van (the portion covered by the plastic mesh) so that your Webasto hot air is not lost to the exterior or diluted with cold outside air. I am doing something similar with a DIY air conditioning system with the evaporator mounted in the area behind the glove box and feeding into the vanagon air box, which is why I have had to give this some thought.
I am considering making flaps right at the front of the exterior air intake rather than in the air box since the exterior approach will, I anticipate, also quiet wind noise when the flap(s) is/are closed.
'86 Syncro Westy SVX
insyncro Premium Member
insyncro is offline
PostPosted: Tue Jul 24, 2012 6:05 am    Post subject: Reply with quote
As stated previously, your idea is a good one, but the warmed air will be mixed with cold external air and you will use much more fuel to have an effect. Venting directly to the cabin and adding a few new vent lines is how I have done it for heat and AC.
syncrogreg
PostPosted: Tue Jul 24, 2012 10:04 am    Post subject: Reply with quote
Howesight wrote:
Hey Greg:
Thanks for input,
I thought that the main cabin inlet ( from the plastic mesh ) can be closed by actuating one of the vent command?
I cannot remember from when it was apart few weeks ago Embarassed
GSB
0cean
0cean is offline
PostPosted: Fri Aug 24, 2012 9:56 am    Post subject: Reply with quote
Just wondering how the project has been going? Is it on the road yet?
syncrogreg
PostPosted: Sun Sep 02, 2012 11:09 am    Post subject: Reply with quote
Some cool updates soon!
GSB
0cean
0cean is offline
PostPosted: Tue Sep 04, 2012 1:29 pm    Post subject: Reply with quote
GSB
0cean chants "We want van porn, We want van porn, We want van porn" Very Happy
Reply to topic    Forum Index -> Vanagon/Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 38 of 42
