spot glazing putty over paint?
mdwman
mdwman is offline
PostPosted: Tue Oct 12, 2010 6:02 am    Post subject: spot glazing putty over paint? Reply with quote
I just repaired a couple areas on the fenders using bondo. After primer, I used Rustoleum as it was a perfect match to the old paint. Now that all has dried I notice in one spot you can see the outline and texture of the Bondo. Guess I will go back over this area with spot glazing putty. Do I need to completely sand the paint down to the bondo before applying the putty or can I apply over the paint after sanding the surface a bit?
Oh, and how long should the Rustoleum cure before proceeding?
Thanks for the input.
M
MDWMAN
deaner
deaner is offline
PostPosted: Tue Oct 12, 2010 7:58 am    Post subject: Reply with quote
wait eight hours, and sand it down to bondo.
65 bug
68 bug
70 ghia
