Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Fri Jan 04, 2013 12:15 am Post subject: |
BusFactory.com wrote: |
OK guys, stop chuckling. Tires ordered: 205.70.15
That's as close to the 205.75.15 as I could get! I now understand how all the dimensions work and these puppies installed will be 26.29 inches tall and 8.07inches wide!! Nice!!!
My only concern is that stock 15 inch rims are 4.5 inches wide and my "wanna be Porsche" rims are about 6.75 wide. The rims have been on the bus 25 years with 165 tires but I think I'll be ok.
Thanks everyone, I'll let you know the result. |
whats the load rating of the tires? you dont want camry tires on a bus...corners would be very soft and the bus will lean alot...stronger tire means better handling and control. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
MrEnglishman Samba Member
Posted: Fri Jan 04, 2013 12:31 am Post subject: |
95S rating meaning 1,499lbs. Plus, whitewall! |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20275 Location: Sandpoint, ID
Posted: Fri Jan 04, 2013 12:38 am Post subject: |
As a rule of thumb, the tires on your bus should be rated 100 or higher for load. You'll probably be just fine, but reinforced sidewalls and higher ratings make for a much nicer driving experience. _________________ nothing |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Fri Jan 04, 2013 8:46 am Post subject: |
i bet the load rating is going to be better than the 165s it currently has _________________ regards
Uli
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Fri Jan 04, 2013 9:53 am Post subject: |
cdennisg wrote: |
Is this a master cylinder with a brake booster?
What is the deal with the upper tube on the beam? It looks swollen! _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Posted: Fri Jan 04, 2013 10:37 am Post subject: |
mandraks wrote: |
i bet the load rating is going to be better than the 165s it currently has |
Agreed. Way, way better. _________________ nothing |
Posted: Fri Jan 04, 2013 10:38 am Post subject: |
cru62 wrote: |
cdennisg wrote: |
What is the deal with the upper tube on the beam? It looks swollen! |
I wondered that, too. I just chalked it up to greasy grungy build up. It would be interesting to see that beam all cleaned off. _________________ nothing |
Posted: Thu Jan 17, 2013 1:36 pm Post subject: Looking for stock ride. |
OK, newly ordered tires are on the bus.....but now they're to big!! To much offset at the rear puts them about half an inch from the metal of the bus. At the front they fill the wheel arch. They're 205-70-15's. Just over 26 inches tall. (27 inches is original)
If I change to 15" vw bus wheels I know it'll move them in at the back and work but will it work at the front where they just look to big? Shame, cause I liked the chromes.
I know the bus originally came with 14"s but is the wheel arch space the same as earlier buses that came with 15"s?
Thanks for the advice!
Posted: Thu Jan 17, 2013 1:38 pm Post subject: |
does it rub when you drive it? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Thu Jan 17, 2013 1:48 pm Post subject: Re: Looking for stock ride. |
looks awesome, i say: make it work. I ran the same wheels for years on my 66 westy.
this should totally work. Peeps are running even bigger tires.
Worst case roll the rear wheel well lip, or just pull on it a little.
i always had Bilstein gas shocks in the rear, though, they pick the bus up a little in the rear.... _________________ regards
Uli
srfndoc Samba Member
Posted: Thu Jan 17, 2013 1:52 pm Post subject: |
Bug wheels have the wrong offset. You could have a company re-hoop them with a better offset but that costs additional money. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Thu Jan 17, 2013 1:56 pm Post subject: |
It hasn't been driven since it was parked in 1988!! I don't think the rear is rubbing but clearance is less than the width of a finger. In the front a full turn doesn't seem to touch.....but it's just very close! (especially the spike part behind the front wheel on the body of the bus) |
Posted: Thu Jan 17, 2013 2:55 pm Post subject: |
there is a body seam behind the front wheel, you can simply hit that with a hammer... I have had one bus where i needed to do this, and just on one side.
a finger is a LOT. this is mechanical, half an inch is half an inch, all the time
It will be fine _________________ regards
Uli
ttullo1 Samba Member
Joined: December 22, 2005 Posts: 120 Location: Russellville, Arkansas
Posted: Tue Jan 22, 2013 12:24 pm Post subject: |
Running 205/75-15's on my single cab with the same clearance you have and they don't rub at all. |
Posted: Tue Jan 22, 2013 12:32 pm Post subject: |
And? Are you driving it yet? _________________ regards
Uli
Posted: Tue Jan 22, 2013 8:40 pm Post subject: |
I slid under the bus while the girlfriend turned the wheel. The offset of the wheels combined with the size of the tires just wont work. In the back I can live with just a tiny gap between the tire and the bus, but in the front it touches at half turn. I looked at and measured many buses at Buses By the Bridge. So.....I've decided to get a set of 15 inch VW wheels for her. I already picked up one at Buses By the Bridge for $10....just 3 to get!
I think stock will look good to. |
Posted: Wed Jan 23, 2013 7:52 am Post subject: |
interesting, i ran those same style wheels for years, all they really do is push the wheels out, when you turn them they sweep a little more area than the narrower stock wheels, but, still, never had an issue. Stock 15s will look good too. paint them silver white or so? _________________ regards
Uli
Posted: Thu Jan 24, 2013 11:52 am Post subject: |
Yea, original cream color I think. It'll still look good. I love my new van! |
Posted: Thu Jan 24, 2013 11:53 am Post subject: |
Yea, original cream color I think. It'll still look good. I love my new BUS! |
Fixed that for you.
206-841-7324
[email protected] |
SambaUser1M Samba Member
Joined: October 27, 2012 Posts: 135 Location: Irvine, CA
Posted: Sun Feb 03, 2013 12:48 am Post subject: excess front positive camber |
I searched for an answer, but was unable to locate it, even in the Bentley manual.
I recently purchased a '57 SCab and noticed severe feathering on the front tires. The alignment shop confirmed toe was off by two degrees. They were able to correct the toe and the truck rolls straight, but there was no way for them to address loads of positive camber front and rear. The alignment tech blamed the KYBs for the camber, but that doesn't compute to me...
I've checked the height on the rear. One side is slightly lower than the other and I've found all the information for measuring and repositioning the spring plates & torsion bars to see if they're causing excess camber in the rear.
Is it really possible right-size gas shocks are the problem? He says "switch to oil shocks and I'll recheck everything for free." He didn't try selling me shocks - he understands I'm buying the parts online and doing the work myself. |
