cdennisg Samba Member
Joined: November 02, 2004 Posts: 20275 Location: Sandpoint, ID
Posted: Sun Feb 03, 2013 11:05 am Post subject: |
Gas shocks tend to stiffen up and climb to their highest position after the vehicle has been parked for awhile. Once you hop in and start driving, they settle in to place. They will not give you positive camber issues while driving. They do not affect the spring rate of the suspension, only compression and rebound damping, etc.
The rear of a stock height truck/bus will generally have a slight amount of positive camber even with the correct settings of the torsion bar/spring plate angle. It is normal, and generally doesn't cause excess tire wear, as that camber constantly changes while driving down the road. This is the same thing that happens in early (pre-69) beetles, or any vehicle with a swingaxle setup. It is inherent in the design.
The front wheel camber can be adjusted to stock spec by swapping shims on the link pins per the procedure in your Bentley manual. You could also have something worn or bent/broken in the front suspension. A careful disassembly and inspection of all of the front suspension components will reveal any issues. _________________ nothing |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Sun Feb 03, 2013 1:56 pm Post subject: |
cdennisg wrote: |
The front wheel camber can be adjusted to stock spec by swapping shims on the link pins per the procedure in your Bentley manual. You could also have something worn or bent/broken in the front suspension. A careful disassembly and inspection of all of the front suspension components will reveal any issues. |
and on top of that you can set your rear ride-height to be level side to side. _________________ regards
Uli
SambaUser1M Samba Member
Joined: October 27, 2012 Posts: 135 Location: Irvine, CA
Posted: Thu Feb 07, 2013 7:47 pm Post subject: |
thank you for the replies. I'll work on it soon and post the results. |
pete-stevers Samba Member
Joined: August 22, 2009 Posts: 22 Location: mission bc
Posted: Wed Feb 27, 2013 2:39 pm Post subject: |
I am looking to run the tallest widest tire on my 59sc that is practical for roads less traveled
just looking to hear thoughts from folks in the know....
My rim are 15 inch |
big bus mike Samba Member
Erik G Samba Member
Joined: October 16, 2002 Posts: 13278 Location: Tejas!
Posted: Mon Jun 10, 2013 10:46 am Post subject: |
september of 1959 truck, 64-67 big nut trans. What can I do for the ebrake cables? I think I remember seeing what looks to be a lame u-bolt type clamp connecting what I would assume to be the correct front, and the correct rear. Is that the only option to get the ebrake to work? It's not ratcheting anyways so I need to take it all apart to fix that. Just seems like a lame fix for something that people do on a semi-regular basis (small but bus, big nut trans) but previous owners of this truck have done some other pretty lame fixes for normal stuff too
Thanks |
Posted: Mon Jun 10, 2013 5:25 pm Post subject: |
I used the buggy style parking brake cable shortening kit. Worked great. There is a long thread discussing the options and processes involved. I'll see if I can find it. _________________ nothing |
Stevo Wide 5 Samba Member
Joined: August 30, 2000 Posts: 1110 Location: Antwerp, Belgium
Posted: Wed Aug 21, 2013 10:17 am Post subject: |
Installed my wide 5 rims and meaty tires!!!
Have enough clearance everywhere!!
All I need now is my transmission back so we can get her driving!!! _________________ 62 Type 3 Notchback
Check out my Aircooled blog @ http://stevo.skyblogs.be
Wide 5 Vintage Volkswagen Club
http://www.wide5.com |
RobzKombi Samba Member
Posted: Mon Aug 26, 2013 2:06 pm Post subject: |
Stevo Wide 5 wrote: |
All I need now is my transmission back so we can get her driving!!! |
NICE!
What's it measure now, from the top of the rack to the ground with those meaty tires? and it still fits in the garage even better! But then again that doesn't look like your standard garage door opening. |
Posted: Mon Aug 26, 2013 2:51 pm Post subject: |
I haven't measured total height but no way does it fit in a regular garage!
I think we have an 8.5ft clearance at the shop cause we just a stock bay highroof in there which just cleared the door! _________________ 62 Type 3 Notchback
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Mon Aug 26, 2013 8:29 pm Post subject: |
Regarding an early emergency brake cable into a later model rear brake plate, if you can do a search, I have commented on this several times.
I make the newer style brake plate like the older style brake plate by grinding off the spot welds on the pedestal on the newer plate, removing the pedestal, then enlarging and shaping the hole to match the hole on the older plate. I use an adjustable wrench to bend the outer end of the hole towards the inside, grab the stop from the old plate, then line it up in the hole on the newer plate and mark the spot for the mounting hole. After drilling a hole, I use a stainless steel screw with a nylock nut to hold the stop on the plate (use the shortest screw possible, while still allowing the nylock nut to lock on the screw). This method has worked on my 1957 bus for thirty years and I have recently done it to my 1959 double door panel.
Send me an e-mail message if you want a picture. _________________ Don't worry; be happy. (Baba) |
Posted: Mon Aug 26, 2013 8:45 pm Post subject: |
Campy wrote: |
Send me an e-mail message if you want a picture. |
You just reminded me about the pictures you sent. Damn. I will get them up, life has been too busy lately. _________________ nothing |
Ohio_Style Samba Member
Joined: July 09, 2007 Posts: 610 Location: You'll never leave Sparta alive, Ohio
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Fri Aug 30, 2013 11:39 am Post subject: |
Search campingbox's ads in the classifieds. |
WideFive SBS Hit Squad
Joined: August 20, 2002 Posts: 1147 Location: Litchfield, Ohio
Posted: Fri Aug 30, 2013 6:53 pm Post subject: |
cdennisg wrote: |
Campy wrote: |
You just reminded me about the pictures you sent. Damn. I will get them up, life has been too busy lately. |
I got your slack, Corey
Pix from Campy. Thank You! _________________ Aaron D. Badertscher
Click here for ALL my links. |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Fri Aug 30, 2013 7:23 pm Post subject: |
Ohio_Style wrote: |
zozo wrote: |
Yeah, he just has rebuilt sets and doesn't sell left sides alone.
I may end up swapping the whole front beam for one from a 71 and running adapters. |
I have about half a dozen extra right hand spindles if anyone is in need. One of them came from you John. I'm short on lefts. Do three rights make a left? |
zozo Samba Member
Posted: Fri Aug 30, 2013 7:32 pm Post subject: |
campingbox wrote: |
Ohio_Style wrote: |
zozo wrote: |
Yessir. I recall. That left one was pretty boogered up. You were great to work with on it, and your tech support is second to none. I'm still singing your praises and making referrals whenever I can.
It may be easier in the long run to find a complete beam with some rebuildable spindles and go from there. |
Posted: Sat Aug 31, 2013 1:53 pm Post subject: |
WideFive wrote: |
I got your slack, Corey |
Thanks. We all need a little boost occasionally. _________________ nothing |
