Deen Rechner Samba Member
Posted: Sun Mar 26, 2023 2:29 am Post subject: Shift rod missing part |
Hello,
Before I gave the shift rod to the painter, there was a spring at the bottom with a thing that is now missing.
What was it and where to buy it? Maybe there is also a spare part number? |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Sun Mar 26, 2023 10:02 pm Post subject: Re: Shift rod missing part |
Thank you for your help.
My pictures were not the best.
I mean the thing in the small spring is missing now. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
Posted: Sun Mar 26, 2023 10:10 pm Post subject: Re: Shift rod missing part |
I believe he means the little pin.
I don't know if it's available new
You might need to find one from another shifter.
I found another thread where someone was talking about it and he said he had a machine shop make one for him. Unfortunately I couldn't find any specs for it but maybe someone has one and can measure it.
This piece at the bottom:
Edit: I didn't see the post above. Yes, that's a better pic of what's missing. _________________ How to Post Photos
easy e Samba Member
Posted: Mon Mar 27, 2023 11:03 am Post subject: Re: Shift rod missing part |
EverettB wrote: |
I believe he means the little pin. |
I'd be moderately surprised if it wasn't a DIN 660 steel rivet.
It'd be similar to how VW apparently used a common rivet for the SO-42 rear curtain bracket:
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Posted: Mon Mar 27, 2023 9:47 pm Post subject: Re: Shift rod missing part |
Thank you for the support.
Now I ´ve got a new one.
But now I´ve got a problem to install it.
How is it plugged into the front shift rod? Left or right?
I do not understand the system with the spring at all and what the steel rivet is for. Can someone explain it to me? |
ted698 Samba Member
Joined: June 17, 2016 Posts: 104 Location: Shropshire, UK
Posted: Tue Mar 28, 2023 6:02 am Post subject: Re: Shift rod missing part |
The rounded end of the 'rivet' goes socket side with the spring, the straight end sticks through the slot in the shift rod.
The spring gives the rounded end some spring tension in the socket and stops the gearstick rattling/vibrating, and the straight shaft part in its slot stops the gearstick rotating.
When the rivet & spring is fitted correctly pushing on the rounded end it should bounce on the spring.
To fit it in the socket can be challenging! - I found very lightly 'peening' the edge of the hole in the ball of the shifter where the rivet fits, just so it stops it pinging out then drop it in its slot quickly! |
Posted: Tue Mar 28, 2023 11:40 am Post subject: Re: Shift rod missing part |
You are right.
I tried it before installation. It worked well.
But when I tried to install it, the spring kept jumping out of the hole and the bolt head blocked the front shift rod.
Today the shift rod has won... |
easy e Samba Member
Posted: Tue Mar 28, 2023 8:57 pm Post subject: Re: Shift rod missing part |
Deen Rechner wrote: |
But when I tried to install it, the bolt head blocked the front shift rod. |
Maybe file/grind the head, so it is more flat (like the pic in post #3). _________________ aka: Evan
Posted: Thu Mar 30, 2023 8:12 am Post subject: Re: Shift rod missing part |
Today I won...
Clara Samba Member
Posted: Fri Mar 31, 2023 8:50 am Post subject: Re: Shift rod missing part |
Looks dry
Did you plop a blob of grease down in the socket during assembly?
Today I won...
[img]https://www.thesamba.com/vw/gallery/pix/2380097.jpg/img] |
_________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
