wolfdragon Samba Member
Posted: Tue Oct 26, 2010 5:17 pm Post subject: Need temperature sensor 311906041 resistance #'s (914 1.7L) |
I have a 914 1.7L engine that I am steadily making a sandrail chassis for.
I want to use the existing cylinder head temperature sensor, but I don't know what the resistance values correspond to in terms of degrees.
Part number is 311906041
A chart, an equation, something that gives me the math would be greatly appreciated. I would put the thing in an oven with a thermometer and measure it myself but I don't have a sensitive enough rig, nor do I know what the max/norm/min running temperatures should be. I have been busy working on getting the frame to hold the engine, I can work on the running details later.
Thanks in advance. |
Adriel Rowley Samba Member
Joined: October 12, 2006 Posts: 3267 Location: El Cajon, California
Posted: Tue Oct 26, 2010 5:39 pm Post subject: Re: Need temperature sensor 311906041 resistance #'s (914 1. |
| wolfdragon wrote: | I have a 914 1.7L engine that I am steadily making a sandrail chassis for.
Search the type 3 forum: it is on thread, might be even in my build thread. See you are here now...
Here: http://www.thesamba.com/vw/forum/viewtopic.php?t=2...start=1080
 _________________ 1971 Sunroof Squareback with Fuel Injection
http://www.thesamba.com/vw/forum/viewtopic.php?t=219811&highlight=squareback+rejuvenation |
Posted: Tue Oct 26, 2010 6:02 pm Post subject: |
that's enough for me to calculate a formula for
thanks!
I have to admit that I was expecting higher numbers for the temperatures
like the 200 degree range, i guess that would be more the oil temperature?
The list I found for a type 4 engine was 180-250F being the normal operating temperature.
Of course I am used to water cooled engines where those temperatures are quite normal... |
Posted: Tue Oct 26, 2010 6:25 pm Post subject: |
| wolfdragon wrote: | that's enough for me to calculate a formula for
thanks!
Somewhere there is a factory chart which might show the entire range, but thought this would get you started, and glad it has.  _________________ 1971 Sunroof Squareback with Fuel Injection
