Sheet Metal Thickness & Gauge, Quality of Repair Panels
Goto page Previous  1, 2
djkeev
djkeev is offline
PostPosted: Thu Nov 25, 2010 5:38 am    Post subject: Reply with quote
Added more body panel dimensions for the Type I Ghia, Nose, Fresh air ducting, Inner Fender.
Dave
(o\ ! /o) (o)=l=(o)
1974 Super Convertible
http://www.thesamba.com/vw/forum/viewtopic.php?t=482968&highlight=rust+repair
Creating a 69 1/2 Ghia Convertible out of a 69 Coupe and a 70 Convertible
And the newest arrival!....... 86 Vanagon Westy!
joemac
joemac is offline
PostPosted: Thu Nov 25, 2010 9:25 am    Post subject: Reply with quote
Back in the mid-nineties, I had started a database of sheet metal thicknesses of various models of AC VWs. I lost it all when that PC crashed.
I remember realising that the Bug body sheet metal thickness had decreased eight times between 1949 and 1973. I remember at one point, Bus sheet metal was .042" and Bug of the same year (67?) was .036".
djkeev
djkeev is offline
PostPosted: Fri Nov 26, 2010 7:56 am    Post subject: Reply with quote
Too bad you lost that info, it would be good to have for reference!
Cars did get thinner metal, not only for cost savings but also to get the MPG's up by decreasing weight. That's also a big reason so much of a new car is plastic today.
Dave
(o\ ! /o) (o)=l=(o)
djkeev
djkeev is offline
PostPosted: Fri Nov 26, 2010 12:09 pm    Post subject: Reply with quote
Added two more Ghia dimensions
(o\ ! /o) (o)=l=(o)
Mike Fisher
Mike Fisher is offline
PostPosted: Thu Apr 07, 2011 9:39 am    Post subject: Reply with quote
djkeev wrote:
dansvans wrote:
"A" Pillar Door hinge pillar
Factory metal
20 Gauge
.0375
i sort of thought the factory would use a european measuring standard like 1mm, not 3/8". i measure mine at just under .040, which makes sense since 1mm is .0394, but then mine is a bus. are bugs a different english thickness?
Probably true but I'm not in Europe, I wouldn't be able to locally purchase a 1mm piece of sheet metal for any amount of money. .001 is .001 no matter where it is measured. It is also very easy to convert thousands of an inch to mm.
Also note what I said in my initial post, I used the thickness gauge pictured, I used a "go, no go" method of sizing and reported the "go" size as the thickness.
1mm = 0.0394
0.1mm =.0039
inches X 25.4 = mm
mm / 25.4 = inches
also a handy to read chart, print it out!
http://mdmetric.com/tech/cvtcht.htm
Dave
I just printed out a MARYLAND METRICS. It Does take all the guesswork/calculations out of Metal Thickness. Cool
http://s169.photobucket.com/albums/u236/mr_bojangles500/
69 FI/AT square Daily Driver
66 sunroof,67,71,71,71 AT,72,72 AT Parts
56 & 57 oval ragtop $2,500
djkeev
djkeev is offline
PostPosted: Sun Sep 11, 2011 7:47 am    Post subject: Reply with quote
Working on the 74 Super Beetle.
Some thickness information.
Running board support rail, is also the entire outer door sill as well, I was happy to see that!
The replacement panel, made by Klokkerholm was 21 gauge
The original metal is 20 gauge
Inner fender in front of lower door hinge.
replacement panel from Klokkerholm was 22 gauge
Original Convertible support member is 12 Gauge metal.
(o\ ! /o) (o)=l=(o)
Page 2 of 2
