Jeff H Samba Member
Posted: Tue Oct 01, 2002 10:03 am Post subject: Push Rod Tubes |
Hey Y'all;
I've got oil leaking from the push rod tubes on the right side of my engine (1600dp). I really don't want to pull off the heads to replace the tubes, so here's what I'm thinking.
I'd like to remove the pushrods, then pull the old tubes out from under the engine (I know this will pretty much destroy them). I'll then replace them with the spring-loaded tubes & slip the push rods
back in, torquing every thing back to specs.
Do any of you know any reason why this wouldn't work? I'm planning to install the spring-loaded tubes anyway, as they are reputed to be better at not leaking.
Your thoughts?
Jeff |
DeluxeMike Alligator Wrestler
Joined: April 30, 2002 Posts: 405 Location: Fort Myers Florida
Posted: Tue Oct 01, 2002 2:14 pm Post subject: Push Rod Tubes |
| you shouldnt have any problems doing this procedure. i have heard that the spring style are prone to leaking but have never seen for myself |
UncleBob Grease Midget
Joined: August 21, 2002 Posts: 2875 Location: Northeast Florida
Posted: Wed Oct 02, 2002 9:13 am Post subject: Push Rod Tubes |
| The spring type are prone to leaking, as is the threaded type. But out of the 2, I think the spring ones seal better. Of course, stock is always best. |
