Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Sat Apr 27, 2013 12:01 pm Post subject: |
I agree with "the grid", being the issue. Ten minutes is plenty of time to defrost a window. And if you're getting power to the window--and you grounded the other side in your test, then it has to be the grid(s).
Many years of cleaning will rub the lines too thin.
Run your finger along (and up and down) each grid line to see if there are any missing spots (by feel). Also, look at the grids--but this doesn't always tell the full story.
I used a gridpatch back in the '70's and it works for small areas--about an inch per area. But maybe they've improved on the product since then.
Tim |
sb001 Samba Member
Posted: Sat Apr 27, 2013 3:15 pm Post subject: |
Thanks guys-
I actually have a lead on another whole back glass window with defrost grid for $40, maybe be a better fix than trying to patch this one? (Course I have no way of testing it until I actually have it hooked up but the guy says it works fine) |
'69Custom Samba Member
Joined: September 16, 2008 Posts: 2497 Location: Ventura, California
Posted: Sat Apr 27, 2013 4:56 pm Post subject: |
sb001 wrote: |
Thanks guys-
You can test it out with a multimeter/continuity tester before you install it. That will tell you the grid pathways are good. And I agree, it's likely an easier route to go. _________________ -Tim
1969 Frankenbug
1965 Ford Mustang
:2gunfire: F-U-M-P!
~"I thought I was wrong once, but I was mistaken." ~The Boss
Please excuse any typos as my iPhone doesn't speak English very well.
tham64 wrote: |
Why tune a big round again and again????? For me.... 1 hour will solve the case |
www.endlesscustomz.com |
