stever70 Samba Member
Joined: October 30, 2009 Posts: 302 Location: california
Posted: Tue May 13, 2014 8:47 am Post subject: |
Woo-Hooo, Brakes are done!!! Nice strong pedal. So now that it will stop, I just need to make it go....... _________________ my build log
http://offroadvwbus.blogspot.com/ |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2676 Location: West Coast (Michigan's)
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Thu Jul 10, 2014 10:44 pm Post subject: |
Updates? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Sat Jul 12, 2014 9:13 pm Post subject: |
nothing new right now. been taking a break. will start back on it in about a month or so _________________ my build log
Posted: Mon Jul 14, 2014 11:48 pm Post subject: |
ill be watching _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Thu Oct 16, 2014 9:15 am Post subject: |
Ok, So I know that it has been awhile since I did an update. I did take a bit of a break, but now I am back on the project. Installed the dual radiator fan onto the radiator...HOLY COW, does that thing move some air. Should have NO problems keeping the engine cool.
I also added some serious insulation over the fuel cell, and then covered that with a sheet of stainless steel. Should not have any issues with the fuel tank getting hot. Also note the 2.5" fuel fill line, This thing will fill up fast. Not sure if I will run into issues with the line being right behind the fan, but I will test it out and then see if any changes need to be made. _________________ my build log
Posted: Thu Oct 16, 2014 9:17 am Post subject: |
i vote a heat shield between that right fan and the tube, i would thinik heat could get right into the tank from that tube getting warmed up. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Jcr. Kat Samba Member
Joined: November 09, 2012 Posts: 180 Location: san diego ca.
Posted: Thu Oct 16, 2014 9:52 am Post subject: |
If your going to run those cheap hose clamps on your fuel hose at least run 2 at each end. |
heywebonya Samba Member
Joined: July 08, 2010 Posts: 823 Location: Portage, MI
Posted: Thu Oct 16, 2014 10:08 am Post subject: |
This the best build EVER! _________________ If I knew what I was doing; I wouldn't be building a buggy! |
Posted: Thu Oct 16, 2014 10:14 am Post subject: |
I do have a plan to build a heat shield, just need to get some more material.
As far as hose clamps, yes 2, but that is all that they had. It at least allowed me to set everything in place. When they get more, I will add additional clamps. _________________ my build log
Posted: Tue Nov 18, 2014 10:16 am Post subject: |
some pictures of the cooling tubes install
connected to engine ( need to clean up the engine )
Driver's side tube along frame. welded tabs to hold the cooling tubes
Rear of cooling tube to the radiator
Mocking up 14" Fox shock. Will have to build a hoop.
Cooling tubes removed and painted, will get re-installed on Tuesday.
Posted: Tue Nov 18, 2014 9:34 pm Post subject: |
Keep it up! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Brian Samba Moderator
fabricator john Samba Member
Joined: October 09, 2009 Posts: 510 Location: manassas va. now Venice Fl.
Posted: Thu Nov 20, 2014 6:46 pm Post subject: |
what ya do with the stemline ? back into the upper hose? or tap into the waterpump? fabricator john |
Posted: Sun Nov 23, 2014 8:10 am Post subject: |
stem line??
Do yo mean over-flow? I have not installed that yet. _________________ my build log
Posted: Sun Nov 23, 2014 11:18 pm Post subject: |
Thanks for that info. That was something I knew nothing about. Question: since my engine is tiled down in the back, should I run them front and rear of heads or just the rears? _________________ my build log
Posted: Mon Nov 24, 2014 6:58 pm Post subject: |
stock ones come across the back of the heads, up the pass side of the intake , your should have it , if not they are a easy find , runs cooler gets all the steam pockets out of the heads , i allways hook em up on late model motor swaps just drill n tap the waterpump housing run a lil hose n waa laa.... be sure to put a recirculating water catch tank on it too ,, will like you for it , will get all the air out
john |
