1957 Euro Semaphore/Ragtop Vintage Speed Project
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Rwoodshvac
Rwoodshvac is offline
PostPosted: Tue Nov 23, 2010 7:01 pm    Post subject: Reply with quote
Oval56
If you dont mind will you share your head and carb specifications with us?
88 hp means you did a lot of things right.
I still have those items to work out.
Thanks
57 Ragtop Semaphore Sedan
Vinatage Speed build
48 Aluminum Case
Porsche 356 B Crankshaft 74mm
Porsche 356 B Rods
Shasta Cylinders with JE Pistons 80mm
WW Okrasa Heads worked by Ron Chuck
34 Pbic Carbs rebushed by Mr Okrasa
Custom Okrasa Intakes enlarged to 34mm
Gene Burg Sump
Fram bypass Filter with Oil Cooler
oval56
oval56 is offline
PostPosted: Tue Nov 23, 2010 10:51 pm    Post subject: Reply with quote
no problem, i had all here online...
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=20
74x82,5
okrasaheads ww modified 36/33, solex 40pbic singel crabs, rockerchange (porsche super 90) porting, regrind custom cam, 356 rods balanced, crank reworked.....
my 1433 singelport:
[/url]http://www.thesamba.com/vw/forum/viewtopic.php?t=327411&highlight=oval56[url][/url]
www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com
Rwoodshvac
PostPosted: Wed Dec 01, 2010 8:33 am    Post subject: Reply with quote
Update on my Engine Build
I have put a lot of thought in what to have done to the Stock Okrasa heads. A memeber on here sugested i talk with Ron Chuck in CA. I gave Ron a call and he seems to think we can massage a good bit more performance out to the Heads.
So today i have shipped my heads to him.
We are going to
Bore heads to get the Compression Ratio that i want
Port and polish
Look at increasing the size of the Valves
Replace the stock valve springs with heavier ones
Any other suggestions are welcome?
Thanks
48 Aluminum Case
Porsche 356 B Rods
Gene Burg Sump
Rwoodshvac
PostPosted: Thu Dec 02, 2010 1:26 pm    Post subject: Reply with quote
With my heads off to Ron Chuck I thought I would focus on the Okrasa Manifolds Maybe to get some ideas on how to get more flow out of them. Any suggestions from the Forum would be nice . I am no engineer so hopefully someone will chime in. As I have a couple Questions.
The stock Okrasa manifolds consist of a 32 mm Carburetor flange that feeds a 32 mm tube that is 2.75 inches long, Then it splits or Y's into two 28.5mm tubes 5.5 inches long that feed the two ports on the heads
It seems to me that the two 28.5 mm tubes can flow more than the single 32mm tube that feeds them. If so my question is this What Size single feed tube would supply the two 28.5s to there maximum potential?
Thanks to you engineers
Rick
48 Aluminum Case
Porsche 356 B Rods
Gene Burg Sump
grueni
grueni is offline
PostPosted: Fri Dec 03, 2010 3:29 pm    Post subject: Reply with quote
what is your hp goal with this engine?
valvesize, cam? carburetor?
to your question. yes two 28,5mm holes flow more than one 32mm hole Wink but in a 4 cylinder 4 stroke engine. only one cylinder will suck at one manifold pipe at the same moment so it suck on the 28,5mm and on the 32mm and on the venturi of the carb...that will be the smalles area. so the manifold is good how it is. bigger single pipe will change nothing.
its a question of flow. i beginning with easy to calculate things but good to understand how engines work.
your piston goes down with a specific mean piston speed that is easy to calculate in your case i would say 12m/s here you start(this is at max. peak at 4500rpm).
this is also your mean port velocity in the cylinder. with a stock valve of 33mm the thinnest area would be...lets be optimistic and say 28mm this is about 8 times smaller than your bore of 80mm in square. so the speed of gas would be 8 times faster so you are at about 100m/s. alot of people found out that at about 80-90m/sec you will have best flow VE and so your peak hp. normal... flow and so volumetric efficency (VE) will go up with rpm up to 110-120m/s ...depends on ... and than it run into pumping losses and the VE will decrease rapidly. to use the engine over peak hp make only sense on races...so 80-90m/s is for peak hp on engines like we have.
how you see with your kind of parts an engine rpm over 4500 is not usefull the port and intake valve is the restriction. for the most 36 it is very hard to go over this RPM mark with peak HP.
this are the limits of the heads. what you want at the end is that heads, cam, manifolds, exhaust and carbs are all in a range arround this limit.
same calculation for your carb. the venturi is the smalles area and also an restriction. with a venturi of about 28mm it would work great how it is maybe smaller for driveability.
if you want more you could also use steffi.g 's manifolds for zenith carbs.
they have and also give more potential to the heads.
one thing that you can do with the okrasa manifolds is to shorten the bigger pipe. this could transfere the powerband a little up or could give a little more top end and a little less low end. but this will not be really much just a little. the manifolds are long and that is good for low end power. and 4500 is no high rpm. you want as much as under the curve how you can get.
you could also try to mount bigger and better flowing carbs so with a bigger big pipe on the manifold but this could be tricky to make it work. but if the carb is the most restrictive part in your build it will free some HP.
lets see what your head porter will do with your heads Wink maybe after that you have 2x 30mm holes Wink than you need a new manifold Wink
first you have to know what you want. than you can find out how to get it.
wishes
1956 oval 1192cc 36hp Supercharged 70HP at 3900RPM / 150NM at 2000RPM @ 13 psi
1960 1641cc Twin scroll turbocharged, intercooled @17 psi 318nm/3430rpm 160hp/4790rpm
with cb2280 cheater cam 222°@ 0.05"
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Fri Dec 03, 2010 4:40 pm    Post subject: Reply with quote
Hello-
I'm in the same boat. I've been slowly collecting parts for an engine that's a 356 1600 wannabe (356 crank rods, 82.5mm pistons, Zenith carbs, and modified Okrasa heads). Experimenting with DesktopDyno has helped, but I still feel very uncomfortable committing to a particular head/cam. What would be a good resource for this kind of information?
Thanks,
Paul
My dog's vet has all my car money (http://sagecenters.com/)
Rwoodshvac
PostPosted: Sun Dec 05, 2010 1:23 pm    Post subject: Reply with quote
Thanks for the information. I guess with what you have provided i need to wait and see what the final head confiduration will be.
As far as carbs go at this point i have in the works a set of Solex 34PBICs and a set of Solex 40 PICB. I am leaning towards the 40s as that is what Porsche used in there 1500 Super. And my engijne is going to be close to that . Same Crank/Pistons/Cam I may run a little more Compression Ratio.
Again thanks for sharing with me
48 Aluminum Case
Porsche 356 B Rods
Gene Burg Sump
Rwoodshvac
PostPosted: Sun Dec 05, 2010 1:42 pm    Post subject: Reply with quote
Just found this Picture of a set of Okrasa manifolds that Oval56 modified.
Im not sure what he increased the size to. But i beleive they were modified to fit a set of 40 PCIBs
48 Aluminum Case
Porsche 356 B Rods
Gene Burg Sump
Rwoodshvac
PostPosted: Thu Dec 30, 2010 7:40 am    Post subject: Porssche Pistons Reply with quote
After balancing the Rods i decided it would be wise to do the pistons. Then i thought why not do the pistons and pins as a matched pair. So that is what i am doing . I matched the piston and pins to get combos with the least weight spread. Now my thoughts are to remove any needed materital from the Pins and not the pistons to get the matched pairs to .5 of a gram. What are your thoughts on removing the weight from the pins?
48 Aluminum Case
Porsche 356 B Rods
Gene Burg Sump
Rwoodshvac
PostPosted: Tue Jan 04, 2011 6:54 am    Post subject: Reply with quote
Update on the Body. Ready to start putting things together. Fresh Red Coral paint
48 Aluminum Case
Porsche 356 B Rods
Gene Burg Sump
oval56
oval56 is offline
PostPosted: Tue Jan 04, 2011 7:57 am    Post subject: Reply with quote
i modified my manifolts op to the 40 pbic's to gat a matching port down to that point where theh 2 tubes hit the singel one... i also had the idea of bigger manifolds, but it make than sens if you can do bigger valves and bigger ports... my valve is 37mm my ports are 36mm my tubes are 29mm
what do i get is a better vacuum flow trough the manifold
the thing is, waht goal of hp do you have and how hard would you like to go on the border of what is possible or what not.
the main point is rockerratio + cam.. and if you do not modifie your rockerarm ratio, all other points will make not much sens.
i have made some lasercuts flanges down for okrasa heads stud pattern for 35x1,5mm tubes means 32mm inside diameter! - they are availible
www.oval56.com
www.dbkvw.com
Rwoodshvac
PostPosted: Mon Jan 24, 2011 2:46 pm    Post subject: Reply with quote
Update: I am waiting on my head work to be completed to finish my build. In the meantime i Rebuilt restored an orignal 56/57 period correcrt Oval Fuel Pump > I am ahppy with the results.
Nice and Fresh looking
48 Aluminum Case
Porsche 356 B Rods
Gene Burg Sump
Flavio
Flavio is offline
PostPosted: Mon Jan 24, 2011 3:58 pm    Post subject: Reply with quote
Hello Rwoodshvac
And,.... after the carb are you going to rebuilt the fuel pump ? Laughing Wink
Nice thread, by the way.
gimmesomeshelter
PostPosted: Mon Jan 24, 2011 5:13 pm    Post subject: Reply with quote
Hello-
Did you have to put in a stronger spring to accomodate the fuel needs of your carbs?
Thanks,
Paul
petrol punk
petrol punk is offline
PostPosted: Mon Jan 24, 2011 5:34 pm    Post subject: Reply with quote
gimmesomeshelter wrote:
Hello-
Thanks,
Paul
Would putting a stronger spring in the fuel pump increase flow? My understanding was that you increase flow by removing excess gaskets.
'56 Euro Oval and '70 Beetle.
gimmesomeshelter
PostPosted: Mon Jan 24, 2011 5:40 pm    Post subject: Reply with quote
Hello-
I don't know. I always assumed it was done with a stronger spring because the Judson guys do it that way.
Paul
Rwoodshvac
PostPosted: Tue Jan 25, 2011 1:40 pm    Post subject: Reply with quote
Paul
You are spot on. The only way i have read to increase fuel flow is to use a Judson Spring. I have not heard of the gasket trick.
Here is a picture of the Judson spring, i have a picture of the stock and the Judson side by side i will post later i think it is still in my camera . You can pick Judson springs up here on the Samba
Thanks for the correction on Carb/Fuel pump
More info comming on my carbs
48 Aluminum Case
Porsche 356 B Rods
Gene Burg Sump
Rwoodshvac
PostPosted: Tue Feb 01, 2011 8:42 am    Post subject: Reply with quote
Here is a Picture to compare a stock 1957 36 hp spring to a Judson Spring that is designed to provide more fuel delivery from stock fuel pump . There is a big difference in the stiffness
48 Aluminum Case
Porsche 356 B Rods
Gene Burg Sump
caseydenise
caseydenise is offline
PostPosted: Tue Feb 01, 2011 8:45 am    Post subject: Reply with quote
Where did you get the rebuild items for your fuel pump?
great thread Very Happy
That is badass
Russ Wolfe
Russ Wolfe is offline
PostPosted: Tue Feb 01, 2011 9:51 am    Post subject: Reply with quote
Changing the spring is the way VW did it for the Type 3 dual carb pumps.
Up with the push rod, and the diaphragm is pulled down. Push rod retracts, and the diaphragm goes up, because of the spring, Pushing gas out of the pump to the carb. Heavier spring = Higher pressure.
Gary: OK. Ima poop.
Page 4 of 10
