Central Syncronizer Samba Member
Joined: November 19, 2008 Posts: 302 Location: Vancouver
Posted: Sun Nov 07, 2010 7:17 pm Post subject: complete brake line replacement threads? |
After some searching I've read quite a bit of info on replacing the flex lines and adding bigger brake kits and so on but there doesn't seem to be a lot on replacing the steel lines.
I'm eventually going to do the whole system and am hoping that there might be some recommendations for good flaring tools and tubing benders etc or a good thread tutorial that I've missed.
someday I'll master the search function....
cheers
Jay _________________ Ongoing restoration/maintenance of my syncro double cab (and soon Westy):
http://88syncrodoka.blogspot.com/ |
motelvw Samba Member
Posted: Sun Nov 07, 2010 7:54 pm Post subject: |
The bees knees. Top drawer, really.
Thanks,
vwmike333 Samba Member
Joined: November 16, 2004 Posts: 68 Location: Uxbridge, MA
Posted: Sat Jan 14, 2012 7:19 am Post subject: Complete Brake line replacement |
I've been doing some research of my own and come up with some info;
all hard lines are 4.7mm (3/16 inches) diameter
all tubing nuts are M10X1.0 threads
all tubing flaring is ISO bubble flare
ETKA shows the following parts info for LHD/ non- ABS,
1. Master cylinder to front tee 1850mm (72.8 inches)
2. Master cylinder to rear brake pressure reducer 2130mm (83.8 inches)
3. Front tee to left brake hose 140mm (5.5 inches)
4. Left front brake hose to left front caliper 350mm (13.8inches)
5. Front tee to right front brake hose 950mm (37.4 inches)
6. Right front brake hose to right front caliper 350mm(13.8inches)
7. Brake pressure reducer to rear tee 2900mm (114.2inches)
8. Rear tee to left rear brake hose 623mm (24.5inches)
9.Rear tee to right rear brake hose 285mm (11.2 inches)
10.Left rear brake hose to left rear wheel cylinder 550mm (21.6 inches)
11.Right rear brake hose to right rear wheel cyl. 550mm (21.6 inches)
Total length 3/16" line required 10678mm(420.4inches)
or 35 feet
(These measurements are from flare-to-flare (add 1 inch total when cutting each line to allow additional length for flaring each end of the tubing) (11 inches)
So, if you plan to buy enough to do the whole van, you will need to buy two 25-foot coils of brake line. Right now, Napa and Carquest have a sale on it so it's between $23 and $29 per coil. I can't recommend attempting to flare the poly-coated line, it's hard to hold and slips out of the tool while flaring. I bought the copper-nickel line for $29 on sale at Carquest. Napa doesn't sell the copper-nickel but does sell plain and poly-coated line coils. It bends easily and won't corrode for many years.
Napa does sell a professional ISO flaring tool for $96 with a lifetime warrantee.
Also, I'm now ordering 20 tubing nuts thru Fedhillusa.com for $1 apiece plus shipping. http://store.fedhillusa.com/m13.aspx
Vancafe and Bus Depot has the hoses for $13 front and $12 rear, plus shipping. They also have the line clips (6 needed?), hose clips (2 needed?) and retaining springs (6 needed) for $1.50 to $2.80 each Airhead parts and Cip1 has the brass brake tees for $6 each plus shipping.
Flexible brake hose specs;
1. Left/right front brake hoses M10X1.0 female/female 400mm (15.75 in)
2. Left/right rear brake hoses M10X1.0 female/female 160mm(6.3inches)
This should help fill the gaps in missing information for this job.
Mike B. |
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Sat Jan 14, 2012 7:45 am Post subject: |
Thanks for the info man! |
Joined: January 03, 2010 Posts: 297 Location: Amesbury, MA
Posted: Sat Jan 14, 2012 10:01 am Post subject: |
I have recently done this and was going to buy the length of tubing but ended up buying pre-cut lengths at FLAPS, the Metric kind, a simple tube bending tool
My intial efforts were ugly, but by the end, the tubing looked mercedes quality..
great upper body excercise..
Sam _________________ 2001 eurovn weekender 207k fresh batteries |
Posted: Sat Jan 14, 2012 5:13 pm Post subject: |
purplepeopleeater wrote: |
You're very welcome!
I ended up buying the tubing nuts from Carquest when I went today to buy the other coil of line. They wanted $1.22 each over Napa's $1.69.
The sale on the copper-nickel line at Carquest is until 2/28/2012.
Now I need the two brass tees, all four flex hoses and two new rear wheel cylinders and I'll borrow the flaring tool from my buddy.
When it finally happens, I'll post progress..... |
rubbachicken Samba Member
Posted: Sun Jan 15, 2012 7:19 am Post subject: |
vwmike333 wrote: |
do you know how much it was ?
i'm on my last piece, i like to keep spare on board,for just incase _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
Posted: Sun Jan 15, 2012 7:39 am Post subject: |
The sale on the copper-nickel line at Carquest is until 2/28/2012.[/b]
[/quote]
i'm on my last piece, i like to keep spare on board,for just incase[/quote]
I paid $27.50, which is nearly half the normal price. |
Posted: Sat Jan 21, 2012 7:50 am Post subject: |
I ended up buying a Double Flaring tool kit from Harbor Freight after reading how to cheat and make a bubble flare with a double flare tool. It was only $19.99 at HF, and I also picked up the set of Tubing benders for .99. These are wire springs of various diameters that are slipped over the line (before flaring!) to bend it to the needed shape. The nice thing about them is that you can bend complex shapes easily while preventing tubing collapse from flattening out on the bends. After bending is done, just slip them off the tubing and slide the tubing nuts over each end, then make your bubble flares. According to many sources, the copper-nickel line bends like a dream, so, I'm looking forward to doing the lines.
An old mechanic told me his secret for matching the bends of a line. He said to duct tape the end of the old and new lines together, then bend the first bend to match. Then duct tape after the bend to hold them together. Now, bend the next angle to match, and duct tape them together after that bend, working like this till you're at the end of the line. I was able to use this method to do my 3/8" power steering high-pressure steel line that had rusted through on my '87 Westy. I was surprised at how well it worked on this particularly long and complex-shaped hardline. It went in like a stock part, which is NLA.
I plan to remove all of my old brake lines and make them up like this, so I have a "kit" of new lines and fittings, but if it's too hard to do it this way, I may just do one at a time. I could also make up a pre-made kit (or kits) to sell to others, but it may be hard to ship the longer lines without cutting or bending them in half for smaller packaging. |
Larry Davick Samba Member
Joined: August 31, 2011 Posts: 75 Location: Fremont, California U.S.A.
Posted: Sat Jan 21, 2012 8:24 am Post subject: |
That's a great tip!
The steel-copper lines from Poly Armour will easily bend by hand without kinking and they are nearly as corrosion resistant as stainless. _________________ 1981 Westy Automatic
Sleeping Beauty |
Posted: Sat Jan 21, 2012 8:42 am Post subject: Re: Complete Brake line replacement |
vwmike333 wrote: |
Correction, according to Airhead parts;
Front brake hoses are 460mm long for all years.
Rear brake hoses are 160mm long for 2WD '86 and '87 years only. All other years/ 4WD are 180mm long.
I guess the VW ETKA leaves some of theses details out, or I read it wrong... |
vweggie Samba Member
Joined: May 01, 2007 Posts: 219 Location: End of the road, Vancouver Island
Posted: Tue Feb 28, 2012 11:06 pm Post subject: |
vwmike333. I'm going to be replacing the steel lines on my van soon, once the hardware arrives from Fedhill. Did you pre-bend all your lines before installing or snake them in bending as you install the line? It seems like it would be difficult to get some of the lines into place if they were pre-bent. I'm thinking of the passenger side front to the tee and the line from the master cylinder to the same tee.
Would it would be easier if I disconnected some of those coolant hoses? _________________ 1990 Multivan 2.1 AT |
morymob Samba Member
Posted: Wed Feb 29, 2012 5:04 am Post subject: |
If in good shape i re-use the line nuts, keep extras, and if a dia fit problem a quick pass with correct drill will correct minor problem. Problem here is getting new nuts. |
danfromsyr Samba Member
Posted: Wed Feb 29, 2012 7:16 am Post subject: |
FWIW
Both Advanced & pepboys in my area have new metric brake line nuts ina blister pack hanging by the brake fitting parts.. often behind the counter.
and they're farily reasonably priced..
morymob wrote: |
Abscate wrote: |
msinabottle Samba Member
Posted: Wed Feb 29, 2012 2:52 pm Post subject: Query... |
Can you make the same double flare that is known as the Metric Bubble Flare with that Harbor Freight double-flare tool? I are new to this.
I'm thinking of Winston's fuel lines, and piggy-backing on the thought here. My thought is dampened, grommeted metal fuel lines, minimizing yet another Vanagon issue.
James 93SLC Samba Member
Joined: January 21, 2009 Posts: 937 Location: NE Ohio
Posted: Wed Feb 29, 2012 4:00 pm Post subject: Re: Query... |
msinabottle wrote: |
Can you make the same double flare that is known as the Metric Bubble Flare with that Harbor Freight double-flare tool? I are new to this. |
An ISO bubble flare is basically just the first step of a standard inverted double flare (you just don't bend in the flare). HOWEVER from my research the bubble flare you end up with doesn't have the same angle as a genuine ISO bubble flare. Does it work?....yes and no. Most of the time it does, but you can still have one that leaks. Personally I would get a tool that does the ISO bubble flair. They cost the same as the inverted flare tool. _________________ -------------------------
91 Vanagon Carat
93 Corrado SLC
Photos: http://picasaweb.google.com/slc.corrado
tencentlife "Sometimes a pooka is a problem and sometimes it's just a pooka" |
Posted: Thu Mar 01, 2012 11:01 pm Post subject: Re: Query... |
Best! |
You can! Have a look here :
edit: trying to imbed video _________________ 1990 Multivan 2.1 AT |
Posted: Fri Mar 02, 2012 7:33 am Post subject: Re: Query... |
vweggie wrote: |
Best! |
You can! |
Here is a nice PDF showing the specs on the double flare and ISO bubble flare.
http://www.fedhillusa.com/webnuts/common%20flares6.pdf
I agree that a double flare tool can make a bubble flare in a pinch, but I'd still use the correct tool for the job. My brakes are not an area that I want to skimp on _________________ -------------------------
91 Vanagon Carat
93 Corrado SLC
Posted: Fri Mar 02, 2012 1:14 pm Post subject: Thank you! |
The input and advice are most welcome. I figure if Chris/10centlife has gone to as much metal fuel line as he can in his engine compartments, it's a good precedent to follow, likewise, indeed, for the brake lines. It's a matter, I think, of getting the tool and having the courage to get going on the project.
Thank you!
