Airkewld Samba Member
Joined: November 14, 2003 Posts: 3149 Location: Goodyear, AZ USA
coolrydes Samba Member
Posted: Tue Nov 05, 2013 10:29 am Post subject: |
Empi 17's in chrome....
_________________ Kevin "Coolrydes" Zagar
COOLRYDES So-Cal CUSTOMS
MENDEOLA SUSPENSION
THE HOME OF STYLE AND PERFORMANCE
www.CoolRydescustoms.com |
littlebuggie Samba Member
Joined: March 23, 2004 Posts: 698 Location: California
Posted: Sun Nov 24, 2013 11:53 am Post subject: |
17x4.5" fronts
17x7 rears
_________________ Subi swaps welcome! |
Rich's 50 Samba Member
Joined: February 18, 2004 Posts: 10781 Location: San Diego, CA
Posted: Sun Nov 24, 2013 9:30 pm Post subject: |
Sweet bro^^^^^ |
vegasquare Samba Member
Joined: January 19, 2009 Posts: 51 Location: Las Vegas
Posted: Sun Nov 24, 2013 10:38 pm Post subject: |
TripWire Samba Member
Joined: November 14, 2007 Posts: 75 Location: Naples, Florida
Posted: Tue Nov 26, 2013 6:27 pm Post subject: |
Posted: Tue Nov 26, 2013 6:33 pm Post subject: |
Posted: Tue Nov 26, 2013 9:14 pm Post subject: |
One Word
"SANO" _________________ Kevin "Coolrydes" Zagar
MENDEOLA SUSPENSION
bjoy Samba Member
Posted: Wed Nov 27, 2013 5:34 am Post subject: |
^ good lord, that thing is smooth... |
Posted: Sat Nov 30, 2013 12:50 pm Post subject: |
Posted: Sat Nov 30, 2013 1:11 pm Post subject: |
Are those 165/35/17 tires on the fronts? I have been looking at those for another project of mine. BTW your square is bad ass... but I don't need to tell you that... |
Posted: Sat Nov 30, 2013 1:17 pm Post subject: |
^^^^ Your notch is badass!! It would be cool to be parked next to you at a show.. Stunning car..
The tires are 165/40/17 Look on ebay for the tires.. I don't know if they make 35's wouldn't be any side wall left... _________________ Subi swaps welcome! |
Posted: Sat Nov 30, 2013 1:23 pm Post subject: |
littlebuggie wrote: |
The tires are 165/40/17 Look on ebay for the tires.. I don't know if they make 35's wouldn't be any side wall left... |
Check it out... 165/35/17's... and they are super affordable too...
http://www.ebay.com/itm/280435680934?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 |
Posted: Sat Nov 30, 2013 1:26 pm Post subject: |
That's the same shop I got my tires from. Find their website, they are cheaper on their web site. It will take 2 weeks, the ship from europe _________________ Subi swaps welcome! |
Dogo Samba Member
Posted: Sat Nov 30, 2013 6:45 pm Post subject: |
Sweet baby Jesus... that's beautiful
What tire sizes are you running? |
Posted: Sun Dec 01, 2013 6:51 pm Post subject: |
Dogo wrote: |
Fronts= 185/35/17
Rears= 195/40/17 |
pfcmooney Samba Member
Joined: December 07, 2011 Posts: 219 Location: New Brockton, AL
Posted: Fri Dec 13, 2013 6:14 am Post subject: |
Any of you running a 4" Beam have to tub your inner wall or anything? What kind of fabrication did you have to do?? I'm going air and 17"s and was wondering before I got the body painted if there were anything I needed to know about tubbing the front or what have you.
Awesome looking cars guys! _________________ Thinking comes from not knowing... |
tim3 Samba Member
Joined: February 01, 2004 Posts: 547 Location: Los Angeles, CA
Posted: Sat Dec 14, 2013 11:46 pm Post subject: |
Quote: |
Any of you running a 4" Beam have to tub your inner wall or anything? What kind of fabrication did you have to do?? I'm going air and 17"s and was wondering before I got the body painted if there were anything I needed to know about tubbing the front or what have you. |
If you are speaking of a type3 then you dont have to do anything to your car to run 17" wheels that are 7" wide like the porsche replicas.. you just have to change your bolt pattern if you are 4 lug..
Currently those wheels on the notchback could easily just be bolted right up without a narrowed beam or shorter rear axles..
as for other cars they are all different.. bugs are pretty easy and there is lots of info on how to put bags on a bug,,, type 3 bagged requires a ton of work.. either mod your stock front beam or replace it with a bagged type 1 beam.. the rear im guessing you need to pull the torsion bars.. _________________ Click to view image |
Posted: Sun Dec 15, 2013 6:24 pm Post subject: |
tim3 wrote: |
as for other cars they are all different.. bugs are pretty easy and there is lots of info on how to put bags on a bug,,, type 3 bagged requires a ton of work.. either mod your stock front beam or replace it with a bagged type 1 beam.. the rear im guessing you need to pull the torsion bars.. |
Thanks for the reply! However I'm no curious on how to put bags on a bug, I'm just wondering if there are any body modifications to make when running 17" wheels REALLY low, such as a bag setup. I've seen some people have to tub the front end, but is it necessary? _________________ Thinking comes from not knowing... |
Posted: Mon Dec 16, 2013 3:19 pm Post subject: |
pfcmooney wrote: |
tim3 wrote: |
Thanks for the reply! However I'm no curious on how to put bags on a bug, I'm just wondering if there are any body modifications to make when running 17" wheels REALLY low, such as a bag setup. I've seen some people have to tub the front end, but is it necessary? |
There is no reason to tub the front end. My car (the black notch above) only has an 1 1/2" of ground clearance in the front and only rubs slightly at full lock. I could lower it more but then it would be completely undriveable! The only modification I made to the front is reworking the bottom beam attachment bolts so they don't hang down so low and cause ground clearance issues. I also had to slightly modify my spare tire pan to get a little more clearance.
If you are thinking of going with an air bag system most people go with the type 1 beam setup. Still no body mods are needed unless you decide to go crazy narrow or run a very wide front wheel. Also, something that is never mentioned about the type 1 beam conversion... it shortens your wheel base. I learned that the hard way. I installed a type 1 beam in my car and it looked completely wrong from a straight side shot. That's when I realized the wheel was sitting too far back in the front wheel well. |
