FLUX Samba Member
Joined: October 20, 2010 Posts: 176 Location: Nashua, New Hampshire
Posted: Sun Jan 09, 2011 4:33 pm Post subject: Oil temperature and air temperature meters? |
I was wondering if any of you fellows had a good idea as to where I could find an oil temp sensor and gauge for my van. Also, I was wondering if it's possible to get an air temp sensor mounted in the engine bay or even near the thermostat to get a temp reading from the heads. Any ideas? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
El_Güero Samba Member
Posted: Sun Jan 09, 2011 5:07 pm Post subject: Re: Oil temperature and air temperature meters? |
FLUX wrote: |
Ive personally done this on a 1600 DP monitoring for months trough all kinds of driving and found that the only thing you really understand with a temp sensor mesuring airflow temp mounted in the exact location as the thermostat is that idle air is hotter than reved engine air, it will not warn you against a sudent head failiure with the speed you need. instead i did find helpfull knowing the oil temp (wich reacts exactly opposite to the air flow temp) but you will find yourself in a drowning sea of other people disenting ass to location of the sender and temp readings meaning anything other than "hot oil VS VERY Hot oil".
Good luck. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21518 Location: Oklahoma City
Posted: Sun Jan 09, 2011 5:54 pm Post subject: |
The cylinder head temperature is almost as important if not more ...than oil temperature. You can have cool oil and overheating heads. Ray |
