first_one_a_65 Samba Member
Joined: January 22, 2010 Posts: 204 Location: bay area, california
Posted: Sun Nov 21, 2010 12:27 pm Post subject: 1960 Nose Cone |
is there anywhere i can find a 1960 nose cone for my '63 trans? the car had a 63 nose cone and it didnt quite fit properly and it tilted the engine up about an inch so my cooling tin wouldnt fit correctly. i think i broke the front trans mount and since im allready pulling the transaxle i might as well correct that too.
thanks.
-alex |
58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Sun Nov 21, 2010 1:19 pm Post subject: |
a 60 trans is a split case trans....don't think you can swap it to a later type trans. _________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project |
Posted: Sun Nov 21, 2010 1:30 pm Post subject: |
| DAMN.. i was thinking about that. ive never looked at the cones to compare. so how could i make this trans bolt up square? |
58Dub Samba Member
Posted: Sun Nov 21, 2010 1:32 pm Post subject: |
I think the first thing would be to figure out what is not right. Why isn't it in there straight. Otherwise, you can always fab up a bracket to move the front mount up or down. _________________ 58 Beetle (now just a pile of parts in the corner)
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Sun Nov 21, 2010 3:26 pm Post subject: |
| first_one_a_65 wrote: |
59-67 bus nose cone and hockey stick -use with 1960 beetle front mount rubber. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
Posted: Sun Nov 21, 2010 3:28 pm Post subject: Re: 1960 Nose Cone |
thanks.
-alex |
1959-1967 bus nosecone and 59-67 bus hockey stick. use 1960 beetle front rubber mount. _________________ Admin note: Bill Passed away - July, 2017
www.sv2s.com
SBS #100
fabricator john Samba Member
Joined: October 09, 2009 Posts: 510 Location: manassas va. now Venice Fl.
Posted: Sun Nov 21, 2010 4:58 pm Post subject: |
| yup bus cone stock 60 mount .....john |
Posted: Sun Nov 21, 2010 9:55 pm Post subject: |
and thatll all bolt up with no modification? id really like to go this route then. i dont want to cut my mount off to weld up a newer one.
-alex |
Posted: Mon Nov 22, 2010 9:08 pm Post subject: |
| and what else would i need? gasket wise or sealer or any modifications? |
lovethatconvertible Samba Member
Joined: August 22, 2008 Posts: 1434 Location: Las Vegas N. V.
Posted: Tue Nov 23, 2010 8:45 am Post subject: |
1- Bus Nose cone
2- Bus Hockey Stick
3- 1960 Front Trans. Mount
4- Nose Cone Gasket
5- Might as well Replace Rear Trans. Cradle Mounts
6- If you Find a New Bus Hockey Stick, I've heard they are Dimpled on Both sides. But if you Get a used one you'll have to dimple it on the other side, Just make sure you don't drill too big of a dimple. It will affect your Shifting, ask me how I know. Thank You PO
7- Gasket Sealer
Assemble and Drive
I am running the same set-up in my 60'
Just wanted to add that I believe there is a thread on putting the dimple in the hockey stick. You might want to do a search as I think it's not exactly 180 degrees from the original one. I'll see if I can find it. |
Posted: Tue Nov 23, 2010 10:43 am Post subject: |
| sweet thanks guys. ive been looking for a thread on this but havent really seen one about the dimpling. this seems like a lot better way to go than cutting off my original mount. |
Posted: Tue Nov 23, 2010 11:40 am Post subject: |
| Yes That's the Thread. Good luck on your Quest. |
Posted: Tue Nov 23, 2010 12:45 pm Post subject: |
| will update once i start. any particular places i should buy through?ive been looking through the classifieds and have seen some parts |
fiveohnick Samba Member
Joined: June 23, 2009 Posts: 37 Location: Napa valley
Posted: Wed Nov 24, 2010 12:58 pm Post subject: |
I had that same problem back in the day when I put a 67 trans in my 1960. When I got my car it had a 63? trans in it already but if I can remember correctly the motor was not in the engine bay the way it should have been. So When Iput my new motor and 67 trans I made an adapter plate out of 1/2" plate and the stock oval 67 mount. First I drilled the holes in the plate to fit the studs in the 60 pan. Then I put the 67 trans in with a case bolted on along with some tin. I moved the trans around until I got the motor and tin fitted the best I could. Once I got that, I marked where the 67 mount would bolt to the plate and then drilled the holes for the mount. Its been a long time since then ('9 but I think I changed the rear crossmember over to the 67 as well.
Why do the 1960s have so many one year issues?? |
Posted: Wed Nov 24, 2010 3:15 pm Post subject: |
Because they are cool Anyway I remember reading somewhere that they slanted the engine and transmission 2 degrees from previous years, hence the 1960 one year only dip stick with the red painted handle. My info could be a little off maybe one of the Samba Masters could ring in on this. |
mark_85226 Samba Member
Joined: January 21, 2008 Posts: 112 Location: Chandler, Arizona
Posted: Wed Nov 24, 2010 3:58 pm Post subject: |
has anyone tried this Rancho type II nose cone kit?? its a little pricey, comes complete with predrilled hockey stick...
http://www.thesamba.com/vw/classifieds/detail.php?id=1032574 |
Posted: Wed Nov 24, 2010 10:30 pm Post subject: |
| id say well worth it ,years ago my buddy had a 60 drag car ,we needed the "majic" nosecone, after callin around for a couple o weeks ,pre net days , we drove an hour to walk way up in the woods in the dark and pull a motor and trans out of a split bus that was in the ground with no wheels on it , got the part but what an adventure! 124.00 for a brand new one with the stick and a nice seal ? worth every penny ! was glad to see sombody finally makin them................................john |
Posted: Fri Nov 26, 2010 1:23 pm Post subject: |
| hmmmmm that rancho kit looks nice..lol im having trouble finding a stock 1960 rubber mount. any suggestions? |
