Thext94's '67 Baja
Goto page Previous  1, 2, 3 ... 7, 8, 9, 10, 11  Next
thext94
thext94 is offline
PostPosted: Thu Sep 29, 2011 12:23 am    Post subject: Reply with quote
Started my welding class, it's Monday and Wednesday nights for 3 hours. Here's a couple first attempts at overlapping arc beads
We're learning arc, MIG, and TIG over the course of the class. Then afterward the plan is to take the certification test and get my license, make some money while going through the fire academy. I have my eye on a wider beam... Twisted Evil
Tyler
'67 Baja: http://www.thesamba.com/vw/forum/viewtopic.php?t=441376
'67 Class 11: http://www.thesamba.com/vw/forum/viewtopic.php?t=521883
View user's profile Send private message Send e-mail Twitter Gallery Classifieds Feedback
bomberbaja
bomberbaja is offline
PostPosted: Thu Sep 29, 2011 12:27 am    Post subject: Reply with quote
cool. what rod is that? 6013 I'm guessing?
thext94
thext94 is offline
PostPosted: Thu Sep 29, 2011 12:30 am    Post subject: Reply with quote
6010. We're starting with that and then moving onto 70something. Forgot what he said...but its thick haha
Tyler
chucky73
chucky73 is offline
PostPosted: Thu Sep 29, 2011 3:46 am    Post subject: Reply with quote
You will like the 7018, when you start burning it you will lay down some nice looking beeds.
UncleDirty
UncleDirty is offline
PostPosted: Sat Oct 01, 2011 8:15 am    Post subject: Reply with quote
Where are you taking your classes, El Camino? I only ask because I see you're from Manhattan. I'm from the So. Bay, we had a fantastic metal shop at Hawthorne High and a great welding program at SCROC in Torrance, that's where I learned the basics. Keep up the good work.
http://www.socalbajas.com/
thext94
thext94 is offline
PostPosted: Sat Oct 01, 2011 9:35 am    Post subject: Reply with quote
Taking it at SCROC, unfortunately my instructor told me that El Camino shut down a lot of their shop classes, I think including the welding course? They had a great set-up there from what I've heard. I chose SCROC though because as a high school student I get the $900 class for free. I think it's something every high school student should take advantage of. I'll be going to El Camino for the fire academy though
Tyler
petrol punk
petrol punk is offline
PostPosted: Sat Oct 01, 2011 7:36 pm    Post subject: Reply with quote
Interesting. We started with 7018 and moved on to 6010 in the classes I took. 7018 is nice, just have to hold a constant speed. And once you get real good the slag pretty much peels off without any effort. No more chunks of hot slag hitting your face when chipping.
'56 Euro Oval and '70 Beetle.
its gunna b bad
its gunna b bad is offline
PostPosted: Sat Oct 01, 2011 9:58 pm    Post subject: Reply with quote
I'm not too much help on VW's but I can help you with the welding/fabbing. I personally am an arc welder and choose it over wirefeed. Anyways, those 6010 beads are looking good, you have your heat set good because they are laying really flat. The very top bead right before you stopped(1.5 inches to the end) looks to be an excellent weld and thats what you should aim for. Just about all of those beads would be a good strong weld, they may just not look like your desired stack of dimes look. So you are doing a great job, when you start doing overhead and vertical you will get frustrated. But, once you get the hang of it(speed,heat,arc length, movement,etc) you will become very good, very quick. MIG is easy, im sure you would pass a test even now. TIG...tig is overexaggerated on how hard it is. I will admit sometimes it can be a pain to weld with one in certain positions.
Pointers:
your 6010 flats- try not to take such big movements with your stick back and forth
7018 flats- little tiny movements, barely any at all, beads look great
7018 vertical- turn your heat down(harder than 6010 vertical)
6010 vertical- I use big movements and hold the rod for a second in the spot
Im not sure how you were taught by your instructor but this is some of what I can give you from behind a computer screen. Hope this helped you and im glad you are taking the initiative to go and take a class and get certified.
dustymojave
dustymojave is offline
PostPosted: Mon Oct 03, 2011 9:05 am    Post subject: Reply with quote
Keep at it Tyler. Welding is a valuable skill to carry through life whether you make a living at it or not. It can pay well. But it will serve you well for building your own stuff and for your friends.
I've been teaching Warren (3gtech). He welded the rear bumper cage for his Baja and I went over it like an editor with an article for a magazine. I had him grind out welds which were not good enough and re-weld them. It looks pretty decent now.
Richard
A.R.T.S. Tech Inspection MORE/MDR
Bajas, Fiberglass Buggies and Rails built in the Mojave Desert
SoCalBajas Member
alexvw
alexvw is offline
PostPosted: Mon Oct 03, 2011 8:25 pm    Post subject: Reply with quote
What weber carb kit do you have exactly for your car? And am wondering if it was an easy install/adjustment
1995 Mitsubishi 3000GT SL
1974 Volkswagen Superbeetle
"No shit Jack !
That will tell you if they are the same
Such a bunch of wizards ! ! ! !
Jerry"
http://www.thesamba.com/vw/forum/viewtopic.php?t=475355&highlight=
thext94
thext94 is offline
PostPosted: Mon Oct 03, 2011 10:22 pm    Post subject: Reply with quote
Pointers:
Thanks for the tips guys, just got back from another class doing some more practice. Really enjoying it
I can't help with the install because it was on the engine when I bought the baja, but I've done a number of adjustments on the carb and it's not difficult at all. Especially if you use the tip manual I found online, I can link it to you if you end up using the same carb. Let's just say I had never touched a carb and I managed to tune it exactly how I wanted
Tyler
alexvw
alexvw is offline
PostPosted: Tue Oct 04, 2011 5:51 pm    Post subject: Reply with quote
Do you know what kind of distributor you have, and is your carb a weber progressive? Smile
"No shit Jack !
Jerry"
thext94
thext94 is offline
PostPosted: Tue Oct 04, 2011 9:01 pm    Post subject: Reply with quote
The distributor is a Bosch, and I don't have a Progressive, I'm running a Weber 44 IDF. Or 40...is there any difference in appearance between the 40 and the 44? I really can't see anything
Tyler
Nachodaddy77
Nachodaddy77 is offline
PostPosted: Sun Oct 16, 2011 10:41 am    Post subject: Reply with quote
What's the link for the carb tuning my weber 40 is kicking my ass
my build page http://www.thesamba.com/vw/forum/viewtopic.php?t=386544
thext94
thext94 is offline
PostPosted: Sun Oct 16, 2011 9:35 pm    Post subject: Reply with quote
Here ya go
http://www.redlineweber.com/html/Tech/idf_adjustment_controls.htm
This will basically set it back to normal, and then you can adjust your idle speed to what you like best. I ended up leaving it low like they suggest
Tyler
thext94
thext94 is offline
PostPosted: Sun Nov 06, 2011 6:05 pm    Post subject: Reply with quote
It isn't fun car news, but I've moved onto MIG because that's the one I really want to perfect before I start building up my car
Also cleaned it up yesterday. Engine polishing, got rid of any old mud, armor all...it's too clean. Taking it back to Parker next weekend, having my neighbor do a quick tune-up and then thanksgiving weekend I will be taking videos of the first ride of the season. Bring this thread back to life...
Taking some footage this weekend of my friend's truck so I can start playing around with Final Cut Pro. If it turns out decent I'll link it on here. Car news to come, I promise
Tyler
Bashr52
Bashr52 is offline
PostPosted: Mon Nov 07, 2011 8:06 am    Post subject: Reply with quote
drnewman wrote:
With the regular beetle lower control arms the ball joint is facing upwards so when you come down from a jump the spindle is pushed away from the balljoint and spindle. With the thing lower control arms the balljoint is facing downwards so when you land from a jump the ballloint is forced towards the spindle, stronger by design. As far as the spindles go, they actually have a lift built into them compared to the bug spindle. the spindles and lower arms are a bolt on addition to a bug balljoint beam.
It's not a cheap upgrade (roughly $500-$600 from my research), but i always thought it would be the best upgrade to make to a bug beam, hence the reason I'm saving up for the upgrade. You not only gain lift in the front (average around 3"), but you gain a stronger balljoint design.
I welcome any other opinions on this, but it seems your ride is so far along that it may benefit from such an upgrade.
All you have to do to run Thing spindles on bug/ghia arms is press in the corect balljoints (you don't need to spring for the Thing arms). Thing spindles take a larger diameter balljoint, which is where I believe they get some of their strength from. The spindles are cast with about a 2.5" lift over bug/ghia parts though. I'm running ghia spindles and discs on my 73 street Thing. All I did was add ghia balljoints and caster nuts. The last set of Thing spindels I sold went for $250 IIRC.
poomwah
poomwah is offline
PostPosted: Mon Nov 07, 2011 11:04 am    Post subject: Reply with quote
nice job on the welding, but I want to see more pics of the car Razz
Rocco- my build thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=479675
thext94
thext94 is offline
PostPosted: Wed Nov 16, 2011 11:03 pm    Post subject: Reply with quote
Here's a quick video of some clips I threw together from the past couple months. The bug is in there a couple times, more of a fun editing project
Tyler
geoffwg
geoffwg is offline
PostPosted: Thu Nov 17, 2011 12:23 pm    Post subject: Reply with quote
cool vid!
im looking for editing software where did you come across final cut pro?
speed cost money.... how fast do you want to go?
http://www.thesamba.com/vw/forum/viewtopic.php?t=474256
Page 8 of 11
