Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Thu Feb 17, 2011 10:44 am Post subject: |
andy198712 wrote: |
any ideas? |
You're testing without the timer switch, right? Both red and gray need +12v. |
andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Thu Feb 17, 2011 11:39 am Post subject: |
Captain Spalding wrote: |
andy198712 wrote: |
any ideas? |
ohhhhh what a willy!!
so i need to touch the grey on the pos to get it to go? |
Posted: Fri Jan 18, 2013 3:21 pm Post subject: |
so after a couple years of happy use! thanks to the forum
i would love to have the temp regulator so i can just turn it on, set my temp ish and leave it on instead of having to keep turning it on and off....
what would i need? just the sensor? or any kind of thermostat that would break the circuit at X a selected temp? _________________
Alstrup wrote: |
I like 5,5inchers in the rear at least. |
Posted: Sat Dec 06, 2014 11:45 am Post subject: |
had a lot of welding work done on the bug, and its been off the road a good 12 months plus, not just refitted the eber today, need to plumb and wire it back in, this page was helpful hopefully sort it monday!
The temp switch is proving hard to find! i'm tempted to find a small digi one on ebay or the like, then use that to make or break the blue wires of the temp switch on the Eber right?
Thanks _________________
Alstrup wrote: |
Semper_Dad Samba Member
Posted: Sat Dec 06, 2014 6:06 pm Post subject: |
andy198712 wrote: |
Thanks |
Check out this setup. Rectangular display on dash
Tallman
_________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Posted: Sun Dec 07, 2014 1:18 am Post subject: |
That's a cool little display, fits in well! Seen a couple on eBay, mostly from Hong Kong it seems and cheap so worth a shot! _________________
Alstrup wrote: |
Posted: Sun Dec 07, 2014 12:04 pm Post subject: |
I'm confused. Is it the timer switch you need or the temperature regulating switch? |
Posted: Mon Dec 08, 2014 3:43 am Post subject: |
temp reg switch, does that splice into the blue wires? which on mine are joined?
cheers _________________
Alstrup wrote: |
Posted: Tue Dec 09, 2014 2:03 pm Post subject: |
Thanks
Those were the kind i was looking at on ebay, you can get them a lot cheaper under £10 i think... so worth a shot maybe.... worst case i'm £10 out of pocket and back to square one! _________________
Alstrup wrote: |
Posted: Thu Dec 11, 2014 11:33 am Post subject: |
Finished wiring it in today and its lovely to have heat again!
i tested the pump off the car with a battery and got it clicking nicely, so when i connected it to my small bore fuel line (from a model shop, although check the line is safe for petrol and not just nitro) it started on the first go and ran beautifully!
i got the power wired into a permanent live (so it can do its cool down)
and the switch wired to ignition live.
as mines a BN4 i have it ducted to a hole i cut in the footwell between the driver and passenger, using silver foil style ducting. but its a bodge at best and not sealing well, so i'm thinking of making a step down adapter to fit on the outlet of the heater, and route that to a dash grill maybe.... the ones by the speedo.
any thoughts on that?
Alstrup wrote: |
Posted: Thu Dec 11, 2014 12:37 pm Post subject: |
There's more to it than just getting the heater to turn on and off. How are you regulating the temperature? |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2769 Location: The World's Motor Capital
Posted: Thu Dec 11, 2014 3:22 pm Post subject: |
This is how I did it in a '71 Super Beetle when it was my daily driver for a few years:
The big black box is a 7 day timer which would allow up to 3 on and off events per day. I think the run time (when automatically switched on) was 45 minutes.
The timer was actually manufactured by Hella.
The knob to the left of the timer was an off-on linear potentiometer which controlled a little electronic thermostat mounted in the trunk. The little black blip poking through the grille above the timer is the actual temperature sensor (thermistor) wired to the thermostat.
http://www.apogeekits.com/electronic-kits-intermediate/thermostat.htm
The heater was a BN2 which, unlike the BN4, has no thermostatic control of its own; it is simply on or off.
When I retired, and no longer needed the timer, I switched the IP to this:
The off-on potentiometer was used to trigger a relay to run the heater.
The thermistor (temp sensor) is now its natural blue color.
That car also had a key fob remote to start the heater, which was probably more practical than the timer, just because I could warm up the car at any time without going outside.
That was a cool car, if I was Jay Leno, I would still have it. |
Posted: Thu Dec 11, 2014 10:17 pm Post subject: |
Mondshine that's pretty slick. The question I have for you, and for Andy, is how do you calibrate it? With the BN-4 heater regulator switch, you calibrate on and off set points by measuring the temperature at the heater input and output ducts. If left uncalibrated, what's to prevent the BN-4 from overheating and popping the safety fuse? |
Posted: Fri Dec 12, 2014 7:34 am Post subject: |
Captain-
I don't know the answer to your question. The only adjustment I ever made was the fuel mixture. I don't think the heater ever ran continuously for over an hour, because the car warmed up pretty quickly, and the thermostat would switch the heater off.
This BN2 was not a standard unit. It came from the personal stash of the great Ark Mirvis (aka "The Heaterman"). It had electronic controls for fuel and ignition, a combination glow/spark plug, and used a standard automotive coil. Photo:
The fuel and ignition control modules can be seen just below the ignition coil. Inside the white circle (on the fuel control module) was a small hole revealing a screw head potentiometer to adjust fuel mixture.
I consider Ark Mirvis to be one of the world's foremost authorities on Eberspacher and SW heaters.
I actually visited him once when he lived in Hopatcong, NJ. Unfortunately, he moved back to Europe many years ago, and seems to have disappeared. I have searched for "the lost Ark" without success.
All I have left of that car, that heater, and "The Heaterman" are fond memories.
Good luck, Mondshine |
Posted: Thu Dec 18, 2014 9:49 am Post subject: |
How do you mean? i used the fray switch wire, turn it on, when it gets to an ok temp i turn it off (fan stays on) then turn it on again ect.... _________________
Alstrup wrote: |
Posted: Thu Dec 18, 2014 9:52 am Post subject: |
mondshine wrote: |
Thats very cool! i could do with something like that pot in my air stream and use the pot to control the temp right...?
thanks _________________
Alstrup wrote: |
Posted: Thu Dec 18, 2014 9:53 am Post subject: |
i honesty didn't know that ?? i just thought the safety was there to prevent the BN4 overheating, but i didn't realise you needed or could calibrate it? _________________
Alstrup wrote: |
Posted: Thu Dec 18, 2014 9:55 am Post subject: |
mondshine wrote: |
Captain-
Thats one very slick heater indeed! _________________
Alstrup wrote: |
Posted: Thu Dec 18, 2014 11:32 am Post subject: |
andy198712 wrote: |
thanks |
Andy-
I don't think so. The air temperature of the heater output is probably outside the range of that thermostat.
When I had this same BN2 installed in my '71 Squareback, the heater inlet and outlet ducts (3" Schedule 30 PVC pipe) were about 30" long each. I did experience some overheating problems in the Squareback, which only occurred with the ducts connected, probably because they were too restrictive.
I solved the problem with a snap action thermo-switch, I think it was this:
http://www.grainger.com/product/Adjustable-Limit-6...?$smthumb$
You can see it in the outlet duct to the left of the heater.
It is possible that the same result can be had by tampering with the overheat switch on the heater itself, but I never tried it.
