nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Sun Apr 17, 2016 1:05 pm Post subject: Re: Cable brake information |
German Krew wrote: |
Not a cable brake question but I have enjoyed this thread when I first started restoring my standard.
So my question is anyone know who rerivets brake shoes?
Thanks,
Mark |
I took my linings and shoes over to a local truck brake equipment shop where they have just the right rivet press to do the job.
They also happen to turn drums, and sell brake parts. Maybe you have one of these types of businesses in your area? |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Mon Apr 18, 2016 8:29 am Post subject: Re: Cable brake information |
Thanks,
Mark |
http://brakematerialsandparts.webs.com/brakerelining.htm |
blood Samba Member
Joined: October 01, 2015 Posts: 50 Location: nashville tn
Posted: Mon Apr 18, 2016 4:23 pm Post subject: Re: Cable brake information |
Dear kubel 42, A couple of comments. Hand brake pressure rod has two pieces, the rod itself which should not be two hard to fab up and the adjuster piece which is a little harder to make. You will need a small lathe to make that part. You can see photos of these in this thread. I can get you dimensions on both parts but it will take me some time. do you have a complete hand brake assembly? If so the long rod can be made out of round stock with a slot for the handbrake cut into the back end and the forward end threaded female for the adjuster. It is quite tight where the rod passes by the gear change lever so attention should be paid on the rod outer diameter. The pedal pressure rod comes in two variations, My car had the wrong one in it which caused the cables to exit the guide tubes at an upwward angle. The one I bought to replace was for the later version and fits properly but who knows what vintage my pan really is. My car is supposed to be a late 44. Make sure you get the right one. I would not trust it until you measure. I can get you the dimension the guide tubes to the rectangular base that the brake pedal rod rests on if you like. My opinion would be to keep the brakes period correct if possible. If you are not that skilled at fabrication I would bet someone close to you could assist. Best of luck David, PS let me know if you need those dimensions. |
Brezelfahrer Samba Member
Joined: March 26, 2010 Posts: 65 Location: Vlaanderen
Posted: Thu Aug 11, 2016 6:00 am Post subject: Re: Cable brake information |
Anyone in the know how the re-install the pedalcluster.
If there is luck involved for hooking in the brakepedal, than I am very unlucky today...
I had a look with a simple endoscope, but it gives no clues.
Any trick is welcome!
Thanks _________________ 1952 typ 1 european standard
1959 typ 1 european standard sunroof |
blood Samba Member
Posted: Thu Aug 11, 2016 8:56 am Post subject: Re: Cable brake information |
Pull the brake push rod out the front of the frame head and reinstall it once the cluster is bolted in place with the clutch cable hooked up and secured in the rear. David |
Two Glove Boxes Samba Member
Posted: Sat Jul 08, 2017 9:47 pm Post subject: Re: Cable brake information |
usariemen wrote: |
If you can restore a car then you can do that yourself. Itīs easy. |
You were right it was really easy!
As long as you don't swing to hard on the NOS linings. HAHA
Thanks,
Mark |
rod_vw Samba Member
Joined: December 20, 2006 Posts: 416 Location: Shropshire, UK
Posted: Wed Jul 12, 2017 12:02 pm Post subject: Re: Cable brake information |
Those of us that are 'old school' have riveted brake shoes hundreds of times. As you say don't get too enthusiastic or you will crack the linings.
I've not seen this thread before although it begins many years ago, it is an excellent production by Nancy, better than most workshop manuals have ever managed. Congratulations Nancy.
My own experience with VW cable brakes goes back to the early 1970s, long before the luxury of the internet but back then many people had first hand experience of mechanical brakes in various guises. _________________ Rod,
Please visit http://www.historicvws.org.uk
https://www.facebook.com/historicvwclub/
1946 Beetle (Back on the road after over 50 years! Last major outing - Hessisch Oldendorf 2022)
2016 T6 Selfbuild Camper and a LWB MAN TGE in build. |
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 986 Location: Bath, England
Posted: Wed Jul 12, 2017 2:05 pm Post subject: Re: Cable brake information |
As you say, us 'old school' types had to rivet on our own brake linings for many years, as the brake shoe sets available from VW seemed so expensive at the time. In contrast, I used to buy the lining sets, complete with rivets from VW themselves, which were inexpensive.
I still have some sets somewhere, including clutch linings, but in these asbestos free days, they are probably best left alone, if we want to live to be 100, although the damage may already be done! Having said that, I was always sensible about handling the material, and never blew the brake drums out with compressd air, etc, as the dangers were well known about, even in the 1970's. There was a good booklet called 'Asbestos Kills' by Nancy Tait I recall reading with interest. https://en.wikipedia.org/wiki/Nancy_Tait
Anyway, back on the subject of rivets, to I used to use an M8 x 30 ish bolt, held vertically on a solid piece of wood, with the 13mm head gripped by a pair of Mole/Vice grips, and use a narrow centrepunch to 1st splay out the hollow centre of the opposite end, and then a fatter centrepunch, eventually using a fat ended chisel to form a nice circular pattern of flattened metal.
The positive side was that the lining material was ideal for good braking, but with the rivet head in place, it reduced the useable height of the brake lining, and therefore service life, whilst frequently scoring the drums if left in situ too long. 'Modern' bonded 'cardboard' linings obvously don't do this until down to the brake shoe itself, and are relatively cheap for what they are, relegating the skills of us 'old skool' types to the dustbin of time, along with the likes of gas lamp lighters, and stage coach drivers! |
Telephunken Samba Member
Joined: November 23, 2004 Posts: 274 Location: Northern California
Posted: Wed Jul 26, 2017 10:44 pm Post subject: Re: Cable brake information |
Great thread Nancy! this is very useful as I am going to be assembling the cable brakes on my 47 pan soon. I actually was looking at all the pieces tonight studying how they all go together. Your pics and Diagram was very helpful to confirm some of the things I had already suspected but wasn't sure of; the one thing I am missing is the return spring. does anyone know how much tension it needs to have obviously I can probably buy something from my local hardware store that would work, I would need to know how much tension it needs....i also dont have the little cover...
Nancy, I remember you and I talking at Kelly Park about the grease coming out the front tubes and making a huge mess. so once I get everything together should I use a grease gun on the Zerts, and if so should I watch for the grease coming out the front of the tubes and then stop? what's the best procedure??
--Shawn |
Posted: Fri Aug 04, 2017 10:58 am Post subject: Re: Cable brake information |
Telephunken wrote: |
--Shawn |
Yes, definitely grease the zerks. I think what happens is over time more and more grease gets added so it has to go somewhere and out the front is the path of least resistance.
I think you just want to keep an eye on it and clean it up when enough gets in there to start forcing some out the front. I'ts not unlike greasing king pins or torsion springs.
I add a pump of grease each year when it comes out of storage for the winter or when I adjust the brakes. |
Posted: Fri Aug 04, 2017 8:32 pm Post subject: Re: Cable brake information |
Does anyone know where I can locate these two particular pieces to complete my cable breaks one is the return spring that hooks to the front of the break push rod the other is the small clip that goes just under the cotter pin....
Posted: Sat Aug 05, 2017 6:57 am Post subject: Re: Cable brake information |
I'd start with a WTB ad here. I do see people swapping out the entire braking system for juice brakes every so often so look for those ads.
The little piece under the cotter pin is spring steel so you may be able to make that piece. |
Posted: Sat Aug 05, 2017 7:23 pm Post subject: Re: Cable brake information |
Thanks Nancy. I think I located the spring steel piece from the friend I'm already getting parts from; and the spring I think is available from the place in eastern Europe that sells the Type 82 parts. i'm waiting for a reply from my email to them. |
Posted: Mon Apr 23, 2018 11:56 pm Post subject: Re: Cable brake information |
blood wrote: |
Thanks to Davids tips, we managed to get everything back in place and working!! Thanks man!
Here a little picture of the restored rear brake:
rod_vw Samba Member
Posted: Tue Apr 24, 2018 2:05 am Post subject: Re: Cable brake information |
When I looked at that picture something looked wrong so the manual was consulted, here is the relevant page. Note the retaining bar across the shoes and the way in which the springs are placed.
Posted: Tue Apr 24, 2018 9:04 am Post subject: Re: Cable brake information |
rod_vw wrote: |
When I looked at that picture something looked wrong so the manual was consulted, here is the relevant page. Note the retaining bar across the shoes and the way in which the springs are placed. |
Hello Rod
you are right! I placed the retaining bar earlier and noticed that the spring was slightly out of position. In the manual they first mount the spring and then spread the shoes to get them in the final position.
Thanks for the info!!
Regards,
Peter _________________ 1952 typ 1 european standard
Posted: Tue Apr 24, 2018 9:54 am Post subject: Re: Cable brake information |
The front shoe looks looks flipped upside down too. Wrong side? |
a1steaksauce Samba Member
Posted: Tue Apr 24, 2018 11:05 am Post subject: Re: Cable brake information |
nlorntson wrote: |
Yup. Wrong side. |
Posted: Wed Apr 25, 2018 10:24 am Post subject: Re: Cable brake information |
that was the last of the three differences
and the right side is correct from the first time!!
installed the two brakedrums and now it is ready for a good adjustment of all 4 brakes!
I had the shoes relined and glued, as the old ones always cracked on the rivets by time, and the glued version has a little more cm2 of stopping power... _________________ 1952 typ 1 european standard
JWDII Samba Member
Posted: Wed Apr 25, 2018 12:19 pm Post subject: Re: Cable brake information |
a1steaksauce wrote: |
nlorntson wrote: |
Yup. Wrong side. |
Glad to see you still around steak sauce! _________________ this space for rent. |
