GERMANAIRE Samba Member
Joined: August 25, 2007 Posts: 689 Location: BUFORD,GA.
Posted: Fri Dec 17, 2010 6:43 pm Post subject: Dual M/C-New Saco Disc Brakes-New Rear W/Cylinders Leaking!! |
I have a 61 Deluxe 15 Window and have put all new brake set up from New Dual Circuit M/C to New Saco Disc Brake Set up also all new hard lines and soft lines and New Rear Drums and Wheel Cylinders. I have been trying to bleed them like I normaly have done to my other cars but having a little trouble with this set up. The new rear wheel cylinders are leaking every time I start to get pressure in the system they are new why is this happening.
Here is my pats set up: Dual M/C part #113611015BD
Saco 4 piston disc brake set up
Type 3 W/Cylinder # 22 stamped on them
New Drums and Brake shoes
All new hard lines and soft lines with no leaks anywhere except for rear wheel cylinders on both sides.
Any Help will be Appreciated, Thanks in Advance, Peter |
Cuņado Wear Samba Member
Joined: December 10, 2006 Posts: 1145 Location: The "O"
Posted: Fri Dec 17, 2010 7:19 pm Post subject: |
I also have 15 delux and did disc brakes all around. i was gonna do the same set up in back as you. but same problem. also when i did my vert same thing. i could never get a good answer from anyone or shop so i just did disc all around. alot more cost but better piece of mine in the long run. i think just the quality of parts are just no good. for awhile i use to try to look at other cars to see if they leaked. and most of them did. i think its just a vw thing.im sure someone has the answer but i could never get it. i know this didnt help much. but just want to let you know i fill
your frustration. i have been there. _________________
Bulli Klinik wrote: |
I may be a little late to the party, but what the hell is Cunado Wear? |
Looking for front kick panels for late 63' Deluxe Basalt Gray
60' Double Cab
63' 15 Window Deluxe
Split 66' Samba Member
Joined: October 07, 2010 Posts: 1257 Location: Bay Area, California
Have the shoes been all the way adjusted out before pumping up the system?
Who made your rear w/cylinders? German, Brazil or China? _________________ "OG = Original German" -- TheSamba.com dictionary |
Posted: Fri Dec 17, 2010 7:27 pm Post subject: |
Was in the garage looking over everything again and noticed I had the emergency brake on while bleeding the brakes . Removed the ebrake and removed the wheels and drums and to a look and everythingn looks in place just leaking but new . cleaned it all out replaced the drums and adjusted the brakes so the drum was tight evenly on both sides. Will try again tomorrow. Wish me Luck! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Fri Dec 17, 2010 8:29 pm Post subject: |
Did you bleed the fronts first??
You should take the rears apart to inspect the cylinder seals to make sure they are not all jambed up. _________________ In Stereo, Where Available! |
Ian Samba Moderator
Posted: Fri Dec 17, 2010 8:41 pm Post subject: |
there really isn't much to a wheel cylinder...take it apart and figure out why it's leaking.
did you replace the hard lines going to the wheel cylinders?? all of the new lines' flares i've seen recently are garbage and leak...even if you tighten the piss out of the flare nut, they will leak because they are formed improperly...probably by slave labor _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012
**ACHTUNG DO NOT USE AA BRAND PRODUCTS OR BUY ANYTHING FROM PACIFIC PARTS INTERNATIONAL IN CALIFORNIA** |
Posted: Fri Dec 17, 2010 8:48 pm Post subject: |
I started bleeding the rear passenger side then moved to the drivers rear side then passenger front then driver front. I will open cylinders tomorrow and check them. Its kind of trippy cause they are both leaking and both new but I will check them out tomorrow. |
Ian Samba Moderator
Posted: Fri Dec 17, 2010 8:49 pm Post subject: |
are you sure they are leaking from inside the drum and not from where the hard line screws in? _________________ All your Buses are belong to us.
Posted: Fri Dec 17, 2010 8:53 pm Post subject: |
Yeah its dry on the out side where it screws in but I pulled off the drum and there was a puddle on the bottom of the drum and I can see it leaking from the bottom of the seal. |
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Sat Dec 18, 2010 10:29 am Post subject: |
What is this master cylinder? The 113 part number sounds like bug/ghia. Pics?
The orifice passages inside the cylinder might be affecting the rear? On my bug, when converting to all disc brakes, nothing ever worked right until I put the "new " late bug 4 wheel disc master cylinder. It looks like stock, but internally it is not. The fact that both sides just happen to be leaking at the same time makes me suspect something might be getting too much pressure, if thats possible with a wheel cylinder. |
GDOG57 Samba Member
Joined: March 19, 2006 Posts: 1065 Location: Gilbert,Arizona
Posted: Sat Dec 18, 2010 4:02 pm Post subject: |
Too much pressure,from a master cylinder is not possible. The pressure pushes the seals against the sides of the wheel cylinder,making the seal.
I would return those wheel cylinders where you bought them. _________________ '57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
'57 type 2 panel ( L31 dove blue) project daily driver,Singleport 1955cc
'69 Squareback (L30A Royal Red) |
Posted: Sat Dec 18, 2010 5:00 pm Post subject: |
GDOG57 wrote: |
I would return those wheel cylinders where you bought them. |
I just took the drums off of both sides and the brake assembly and tried moving the ends of the wheel cylinders and the one on the drivers side one side was stuck and the other was hard to move on the passenger side they would move but kind of crusty so I opened both up and both had minor rust rings inside so much for new wheel cylinders . Being that they where new never tested them . I will get new ones and get back with outcome. As for pressure being disc in front and drum in rear would it be able to blow out the rear wheel cylinders? Hopefully these leaks are from the seizing of the wheel cylinders and these new ones that I will check out and test will solve the problem.
Is anybody running this set up and do you have any leaking problems? |
GDOG57 Samba Member
Posted: Sat Dec 18, 2010 5:28 pm Post subject: |
Replace those wheel cylinders and you will be good to go. _________________ '57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
Posted: Sat Dec 18, 2010 5:36 pm Post subject: |
GDOG57 wrote: |
Replace those wheel cylinders and you will be good to go. |
Thanks Bro!! |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Sun Dec 19, 2010 6:51 am Post subject: |
GERMANAIRE wrote: |
GDOG57 wrote: |
Thanks Bro!! |
dual master needs front right then front left then right rear then left rear.
please stop bleeding like single circuit master. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
Posted: Sun Dec 19, 2010 11:52 am Post subject: |
[quote="bill may"]
GERMANAIRE wrote: |
GDOG57 wrote: |
Thanks Bro!! |
please stop bleeding like single circuit master.[/quote
Thank You for the heads up as I was still doing them like the single circuit
master. Iwill be putting in some new wheel cylinders this week and post
the outcome. Thanks Again, Peter |
Posted: Mon Dec 20, 2010 9:58 am Post subject: |
Has any body used the chinese wheel cylinders it seems that is all anyone has in the area and I am not to sure about that brand.
I am carrying my kids in this bus and want something reliable. |
Posted: Mon Dec 20, 2010 11:15 am Post subject: |
I try to stay away from China and Brazilian parts but if I have no other choice, I'd pick Brazilian.
I just bought some T3 w/cylinders that are Varga or brazilian, from ISP west:
http://www.vwispwest.com/home.php
I would guess they have more. I was unable to find ATE or German anywhere.
EDIT: That is incorrect, come to remember, ISP West did have the German ones, they were near $80 a piece and are said to leak after sitting for awhile, like the Brazilian; I picked the $20 Brazilian ones after hearing that. _________________ "OG = Original German" -- TheSamba.com dictionary |
Posted: Mon Dec 20, 2010 12:16 pm Post subject: |
Split 66' wrote: |
EDIT: That is incorrect, come to remember, ISP West did have the German ones, they were near $80 a piece and are said to leak after sitting for awhile, like the Brazilian; I picked the $20 Brazilian ones after hearing that. |
Just got of the phone with Jbugs and got them shipped today USPS Priority so hopefully before Christmas. and I got the Brazilian ones to. Thanks for the heads up and Happy Holidays!! |
DiggerD Samba Member
Joined: August 11, 2006 Posts: 278 Location: North Georgia
Posted: Mon Dec 20, 2010 4:27 pm Post subject: |
Clyde at Athens German Aircooled usually has Brazilian brake parts in stock. I got some front wheel cylinders from him a couple of months ago. Since he is close by, you can save alot on shipping and help out a local vendor at the same time! _________________ 63 Beetle
66 Deluxe Bus |
