mightymouse Samba Member
Posted: Mon Dec 20, 2010 5:56 pm Post subject: |
| Clatter wrote: | When you said the lifter bores were wrong,
You mean they needed decked to clear the foot at full lift,
Or that they were not square to the cam bore?
What was done to them?
Sleeved?
Nice build detail shots.
I learned something!
Thanks.
P.S.
You don't like the small, 1" square plates that go under the heads?
The ones with the 4 small tabs? |
The lifter bores were high, yeah they needed decked. But they werent all at the same height. Just machined them down so i had enough room.
The little tins that go in the heads are near impossible to get. The heads didnt come with them, and i dont have any sets to squeeze in there. So i dont mind not running them, cause in the last 15 years of not having them, ive never seen any adverse effects.
But yes i do like them, when i can find some.
I wonder if the new head designs have superceded the need for them? Cause all new heads dont have them. And havent for YEARS last time i looked.
hmm....  _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7557 Location: Whittier,CA
Posted: Mon Dec 20, 2010 6:10 pm Post subject: |
MM, is this what you are looking for?:
http://www.zwerks.ca/
Bottom of the page, photo on the right. _________________
| Mitey62 wrote: | | Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
| RockCrusher wrote: | JB weld the case halves....that'll keep the fretting to a minimum.  |
Posted: Mon Dec 20, 2010 6:14 pm Post subject: |
| DarthWeber wrote: | MM, is this what you are looking for?:
Bottom of the page, photo on the right. |
sweet! Thanks man. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
auslander Samba Member
Joined: January 07, 2003 Posts: 1746 Location: Heart Of Dixie
Posted: Tue Dec 21, 2010 2:20 pm Post subject: |
Nice build, damn near what im going to build. Have been going back and fourth with the Engle 120 and Web 218 _________________ Wandering
66 POS Bus
69 Class 11 Beetle
!!! F**k Cancer !!!
Time's Tide will Smother You
"You can't throw a rock in Long Beach without hitting a tweaker" Steve Tucci |
Posted: Tue Dec 21, 2010 3:19 pm Post subject: |
| auslander wrote: | | Nice build, damn near what im going to build. Have been going back and fourth with the Engle 120 and Web 218 |
After seeing the web 218, i was VERY unhappy with it. Its a tiny lobed rampy bastard like an engle VZ cam. I will never advise one again. Lifter boss destroyer type.
I know many are running it with no issues, but i just dislike the cams profile.
id run a web 163 or 110. Both are very similar to engle 120. though i would call first and see what the cam profile looks like. I like nice big lobes, not tiny rampy reground looking ones.
Depends on your heads for sure. Whos heads youll be running, and what cam they suggest to go with them etc. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Rome Samba Member
Joined: June 02, 2004 Posts: 3303 Location: Pearl River, NY
Posted: Thu Dec 23, 2010 5:03 pm Post subject: |
| Thanks for providing the details and the excellent sharp photos! Though I'm not clear- if you used thickwall 92's which have cylinders which require engine case bores ("spigot") for 94, yet you used cylinder bore for 90.5 in the case, did you machine down the thickwall 92's bases to fit into the 90.5 spigot? |
Posted: Thu Dec 23, 2010 5:23 pm Post subject: |
Tims heads, 40x35 i think they recommended the fk7 can't really remember, lol _________________ Wandering
66 POS Bus
69 Class 11 Beetle
!!! F**k Cancer !!!
Posted: Thu Dec 23, 2010 8:12 pm Post subject: |
| Rome wrote: | | Thanks for providing the details and the excellent sharp photos! Though I'm not clear- if you used thickwall 92's which have cylinders which require engine case bores ("spigot") for 94, yet you used cylinder bore for 90.5 in the case, did you machine down the thickwall 92's bases to fit into the 90.5 spigot? |
Yup, you can get the 92 thicks with the base machined down to 90.5. They came out great. Actually i think he did them at the old 92 diameter, before 90.5 and 92 were same size. Cause he specified he did the bases at 92, and i had CB do the case at 92.
90.5 was never mentioned.
but the cyls fit into the case perfect, like stock. I should have measured that.... oh well. lol.
Jetting it now, just stopped up stairs for a sec.  _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
ARTIFACT Samba Member
Joined: June 19, 2009 Posts: 814 Location: SANTA CRUZ
Posted: Thu Jan 06, 2011 2:59 pm Post subject: |
Let us know if you have updates on this build and how it runs etc  _________________ L331 Horizon Blue January 1957 Canadian Deluxe Oval Beetle
| drscope wrote: | | The older car has 10 to 20 years more experiance in figuring out how to piss you off! the newer cars are still learning. |
Posted: Thu Jan 06, 2011 3:06 pm Post subject: |
He is driving it every day so it may be some time before i can get a vid of how it runs. That and i dont know how long the trans is going to last..lol
He and i both are VERY happy with it. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Posted: Sat Mar 26, 2011 11:54 am Post subject: |
Any updates on how things are going with the 2085?
I love the step by step photos and descriptions... Very informative for my 2074 build  _________________ L331 Horizon Blue January 1957 Canadian Deluxe Oval Beetle
Posted: Sat Mar 26, 2011 2:42 pm Post subject: |
He drives it every day. Like a madman no less. LOL.
I havent even seen it back to have a look. Did 2nd oil change and its been in use.
I need to get a video as promised. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
crazybaja1 Samba Member
Posted: Wed Mar 20, 2013 1:48 pm Post subject: |
Hi
Is there any updates?
It's very intresting.. _________________ 91' Vanagon (165h.p 2008 legacy engine)
72' Baja bug in proces
71' Squareback originall not restored |
Posted: Wed Mar 20, 2013 4:12 pm Post subject: |
We just had lunch and i mentioned to him the other day, sheesh i need to get a vid of the singlecab motor man. I need to follow through on the thread.
Come home and there it is... bumped. lol.
Ill do my best to get some vid soon. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
mrblyoung Samba Member
Joined: August 26, 2006 Posts: 555 Location: Turlock, CA
Posted: Thu Mar 21, 2013 11:32 am Post subject: |
| mightymouse wrote: | We just had lunch and i mentioned to him the other day, sheesh i need to get a vid of the singlecab motor man. I need to follow through on the thread.
Ill do my best to get some vid soon. |
Awesome. Been wanting to see a video of this bad boy for like a year now. |
offrdbus70 Samba Member
Joined: August 23, 2006 Posts: 478 Location: Pine Valley-SD
Posted: Thu Mar 21, 2013 7:44 pm Post subject: |
Hey MM ever tried a Norris cam? I have a 407s in my 2276 bus. I started with the 120 but my head builder (Tuttle) said to try the Norris. I do like it much better. It has loads of bottom end and comes on hard at 4000 rpm. Try one!
MG |
grayghost Samba Member
Posted: Tue Apr 16, 2013 6:50 pm Post subject: |
I posted some questions about a somewhat similar combo last night, and was wondering how many mpg do you think this motor gets and how fast 1/4 mile would it run in a 62 bug with 4.12 r&p and stock ratio 1-3 with a .82 4th (26.5" tire)?
I was thinking of running the Los Panchitos heads but with single springs, but wasn't sure of what cam would work well and be easy on the valve train, and at the same time maybe squeeze out some more mpg. I will be running the dual 40 HPMX carbs.
Thanks |
pigzsnout Samba Member
Joined: March 11, 2009 Posts: 51 Location: Biloxi, MS
Posted: Wed Apr 17, 2013 7:03 am Post subject: |
| offrdbus70 wrote: | Hey MM ever tried a Norris cam? I have a 407s in my 2276 bus. I started with the 120 but my head builder (Tuttle) said to try the Norris. I do like it much better. It has loads of bottom end and comes on hard at 4000 rpm. Try one!
MG |
Im kind of waiting MM to respond to this. Im using this thread as an exact template for my motor build. I know he built this motor for a bus and mine is going in a vert but im intersdted to know if he or his customer are completely satisfied with the cam selection or if they have a recommendation to go another route.I have a feeling that the w120 is selected by default in a lot of cases but other manufacfurers like web-cam are somewhat less known but have more state-of-the-art engineering into their cam grinds. |
ALB Samba Member
Joined: August 05, 2008 Posts: 2637 Location: beautiful suburban .....
Posted: Wed Apr 17, 2013 7:59 am Post subject: |
| pigzsnout wrote: | | offrdbus70 wrote: | Hey MM ever tried a Norris cam? I have a 407s in my 2276 bus. I started with the 120 but my head builder (Tuttle) said to try the Norris. I do like it much better. It has loads of bottom end and comes on hard at 4000 rpm. Try one!
MG |
The 407S seems better because if has a few degrees less duration than the W120, so the powerband happens a little lower in the rpm range (where we do most of our driving). For a heavy vehicle like a bus it's extremely beneficial, but in a lighter bug it can be not as important. It all depends on where you want the powerband.
As usual, just my 2 1/2 cents (I'm Canadian, eh). Al _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
Slalombuggy- Now I understand my trust issues... |
Joined: August 03, 2002 Posts: 7050 Location: Salt Lake City, Utah
Posted: Wed Apr 17, 2013 8:14 am Post subject: |
with single springs just put a W110 in it and worry about other stuff. _________________ Please do NOT send me Private Messages through the Samba PM System (I will not see them). Send me an e-mail to john at aircooled dot net
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON THE NEW WEBSITE, vwparts.aircooled.net |
