Shanedante0917 Samba Member
Joined: December 20, 2010 Posts: 13 Location: Redding
Posted: Mon Dec 20, 2010 3:39 pm Post subject: SVDA or DVDA |
Okay, so when I went buy the local Volkswagen mechanic. They overlooked everything and he said I was going to want to change my distributer to an electronic ignition, so I was looking how to do that up and I have been noticing a lot of the 009, SVDA or DVDA distributer. I already decided I don't want the 009, but what distributer would be best for a 1973 bus with a single carburetor? I read that the 1973 should have a DVDA? Not sure about anything though. |
Posted: Mon Dec 20, 2010 3:45 pm Post subject: |
If you have gone to a not stock carburetor you might as well use a SVDA distributor as you will not have all the correct hook ups for the DVDA distributor. |
Randy in Maine Samba Member
Posted: Mon Dec 20, 2010 6:26 pm Post subject: |
Can you buy one like that with an electronic ignition? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Dec 20, 2010 6:29 pm Post subject: |
Randy in Maine wrote: |
an get the petronics installed by them. |
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Dec 20, 2010 6:32 pm Post subject: |
For the record they are a "points replacement module", not really a true electronic igniton.
But that is what you want to have so that you don't have to fuss with points. |
SGKent Samba Member
Posted: Mon Dec 20, 2010 8:49 pm Post subject: Re: SVDA or DVDA |
Shanedante0917 wrote: |
Take a picture of your carb and post it. Pay special attention to what vacuum nipples it has. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5417 Location: Holland, MI
Posted: Tue Apr 22, 2014 5:47 pm Post subject: |
Wildthings wrote: |
I thought the vacuum retard ports on the carbs were just bellow the throttle plates, which is just the intake manifold vacuum, right?
So, if you are using carbs that do not have the retard port, won't connecting the retard line to an intake manifold have the same effect? _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Posted: Tue Apr 22, 2014 7:12 pm Post subject: |
Vanapplebomb wrote: |
Wildthings wrote: |
So, if you are using carbs that do not have the retard port, won't connecting the retard line to an intake manifold have the same effect? |
By correct hook up I would be meaning the correct vacuum single. I suspect with some carbs using the DVDA dizzy would be plug and play, while with others most people would never get the idle and progression correct. The carb and dizzy have to work well together for the engine to run well across the board. |
richparker Samba Member
Joined: November 24, 2011 Posts: 6986 Location: Durango, CO
Posted: Tue Apr 22, 2014 8:22 pm Post subject: |
Wildthings wrote: |
Wildthings wrote: |
So for something like an IDF that plays well with svda distributors, it should then also play well with the dvda if the retard line is hooked to the intake manifold ? _________________ 1800 Type 4 Berrien 295
Posted: Tue Apr 22, 2014 9:47 pm Post subject: |
So for something like an IDF that plays well with svda distributors, it should then also play well with the dvda if the retard line is hooked to the intake manifold ? |
A DVDA distributor is going to require that the carb pass more air at idle than what would be required with a SVDA dizzy. If this requires opening the throttle plates too far, you may get a bog coming off idle. I can't say how it will work, but can say that most people don't try to make it work. |
airschooled Air-Schooled
Posted: Tue Apr 22, 2014 9:48 pm Post subject: |
Wildthings wrote: |
The 34pict3 had a hole drilled in the throttle plate for this reason. Perhaps that could be drilled out on your setup? _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Tue Apr 22, 2014 11:31 pm Post subject: |
Wildthings wrote: |
Wildthings wrote: |
That's a crap shoot these days. Plenty of those out there who went and ponied up for an SVDA to run with their IDF's and found out the vacuum side has no effect rendering them to what's essentially a 009. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Wed Apr 23, 2014 3:57 pm Post subject: |
Pertronix distributors perhaps? I know a lot of people have had issues with the advance on them... Never heard of anyone having that sort of trouble with other distributors. _________________ 1800 Type 4 Berrien 295
