WHAT CAN I DO TO 1600CC ENGINE TO MAKE IT BEAT A HONDA
[email protected]
emceeneo24r@aol.com is offline
PostPosted: Mon Feb 03, 2003 10:44 am    Post subject: WHAT CAN I DO TO 1600CC ENGINE TO MAKE IT BEAT A HONDA Reply with quote
WHAT IS THE BEST THING I COULD DO TO MAKE MY 1600 HALL SOME ASS AND BE CHEAP AND AFFORDABLE AND BEAT A HONDA
Jeff H
Jeff H is offline
PostPosted: Mon Feb 03, 2003 10:51 am    Post subject: WHAT CAN I DO TO 1600CC ENGINE TO MAKE IT BEAT A HONDA Reply with quote
Hey;
Those three questions don't have the same answer.
Is your goal to be fast or affordable? The more speed you're looking for, the more expensive everything gets.
JSH
truckersmike
Elder Sambanite
truckersmike is offline
PostPosted: Mon Feb 03, 2003 2:27 pm    Post subject: WHAT CAN I DO TO 1600CC ENGINE TO MAKE IT BEAT A HONDA Reply with quote
aircooled.net has a section for upgrading a stock engine to get more performance but with out tearing it up.
PostPosted: Mon Feb 03, 2003 2:29 pm    Post subject: WHAT CAN I DO TO 1600CC ENGINE TO MAKE IT BEAT A HONDA Reply with quote
What model Honda? I don't have much trouble beating most Civics with my bone-stock 1500cc Notchback, I am simply a better driver.
Please don't type in all caps.
TRACKMAGIC
TRACKMAGIC is offline
PostPosted: Mon Feb 03, 2003 5:06 pm    Post subject: WHAT CAN I DO TO 1600CC ENGINE TO MAKE IT BEAT A HONDA Reply with quote
come on Everett, you know you couldn't beat a HONDA! I bet all the ones you race are 11 second cars that would whip your ass...they just missed 8th and 11th gear...you should have known that.
[email protected]
PostPosted: Mon Feb 03, 2003 5:27 pm    Post subject: WHAT CAN I DO TO 1600CC ENGINE TO MAKE IT BEAT A HONDA Reply with quote
A TRACK I BET YOU DRIVE A HONDA
Flyer20200
Flyer20200 is offline
PostPosted: Mon Feb 03, 2003 6:21 pm    Post subject: WHAT CAN I DO TO 1600CC ENGINE TO MAKE IT BEAT A HONDA Reply with quote
Buy some literature. VW Performance Handbook by Keith Seume, found here http://www.amazon.com/exec/obidos/tg/detail/-/0760...p;n=507846 , is awesome. Breaks it down in three classes: mild street, fast road, and all out ass whoopin(i think it is all out street actually). It also has tips about wheels. Overall best book I've seen that has good pictures and will show you what results you will get. Definetly should be on the top of your list...
[email protected]
hoxviii@aol.com is offline
PostPosted: Mon Feb 03, 2003 8:08 pm    Post subject: WHAT CAN I DO TO 1600CC ENGINE TO MAKE IT BEAT A HONDA Reply with quote
if you want a honda eater out of a 1600 you need to know if you want it to be a short haul eater or a long haul eater. A short haul eater isn't easy with a 1600 as you need GOBS of torque, but it's fairly easy to build a 145 mph 1600. Put on a set of p&p DP heads, ARP rod bolts, HD valve springs, get a CW crank, a 2500-6000 RPM cam or so, either dual weber 40's or a Weber 38/38 progressive, then get the whole thing zero balanced to 10k. The duals will spread your power out a bit more, the 38/38 will be kinda weak off the line, but once the second barrel kicks in hold onto your hat. Using all stock or stock mod parts on the longblock(except the rod bolts) this motor is good to 7500RPM (that's when rods start to break)and should make about 65-70 hp at the crank.
ice baller
ice baller is offline
PostPosted: Mon Feb 03, 2003 11:16 pm    Post subject: WHAT CAN I DO TO 1600CC ENGINE TO MAKE IT BEAT A HONDA Reply with quote
GO WITH THIS> Dual kadrons, 110 cam, cut ur heads, go with a fat boy, .009 dis. adjust ur timing & ur vavles to .004mm, that sounds about right, I have smoked some VW and Hondas, (lol , boy where they surprized)
