myk648 Samba Member
Joined: November 12, 2002 Posts: 550 Location: Xenia, Ohio
Posted: Sun Feb 09, 2003 1:29 pm Post subject: Engine case numbers |
I recently came across an old engine case. I was wondering how to determine what the case originally came out of. The number on it is AK 005733. Any info would be greatly appreciated. Thanx! |
myk648 Samba Member
Posted: Sun Feb 09, 2003 1:58 pm Post subject: Engine case numbers |
The other number I found on it is 211,101,102E. |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Sun Feb 09, 2003 2:21 pm Post subject: Engine case numbers |
Should be a 73 or 74 dual releif with 8mm head stud factory case inserts...
the 211 101 102 E is a generic type part casting # meaning that it is perhaps a 3 point style rear mount that could be used in other applications which require an engine mount bar.
Does it say AS-41 or AS 41 on it?
has it ever been align bored? ( look for numbers stamped on the oil cooler "pad" and on the rear circle around the crank main seal. Sounds like a good case if it has not been machined to much or rear main thrust area beat out. |
Posted: Sun Feb 09, 2003 2:22 pm Post subject: Engine case numbers |
Sorry or AS-21???? |
myk648 Samba Member
Posted: Sun Feb 09, 2003 4:09 pm Post subject: Engine case numbers |
It says AS 41. |
Posted: Sun Feb 09, 2003 4:44 pm Post subject: Engine case numbers |
Cool, no biggie, some stuff written about the AS-21 ( the rating of the magnesium alloy used in the casting of the case) being better ( ie hardier material)
But still if it checks out for cracks/ machine tolerances/ not warped on center main, then it is a decent case for a project rebuild. |
myk648 Samba Member
Posted: Sun Feb 09, 2003 4:54 pm Post subject: Engine case numbers |
Thanks for your help. That is what I'm planning to do with it(rebuild). I figure if I've got a built motor setting around, then I've got an excuse to buy another car! |
68railbuggy Samba Member
Joined: October 29, 2011 Posts: 1 Location: HENDERSONVILLE,NC
Posted: Sat Jan 21, 2012 8:55 pm Post subject: engine number |
i hvae an engine case with AK003682 on it...any information on it would be helpful. thanks in advance |
