How much power?
volkyoo
volkyoo is offline
PostPosted: Mon Jan 03, 2011 9:26 pm    Post subject: How much power? Reply with quote
how much power do you think its needed to do a burnout (as simple as is) in a bug with 17 inches tires. we saw a guy overhere doing that and me and some folks are arguing about that. some say it may be a 1776 engine, the other one says stroker(but im sure its no stroker), the other 1914.... what do you think????
Altema
Altema is offline
PostPosted: Mon Jan 03, 2011 9:29 pm    Post subject: Reply with quote
Depends on whether or not they had a line lock on the front brakes. Got a video?
DarthWeber
DarthWeber is offline
PostPosted: Mon Jan 03, 2011 10:13 pm    Post subject: Reply with quote
With water under the tires, a 36 HP engine could fry them hides!
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
earthquake
earthquake is offline
PostPosted: Mon Jan 03, 2011 10:19 pm    Post subject: Reply with quote
I did a burn out with a battery powered fork lift once, because some one said it could not be done.
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
SRP1
SRP1 is offline
PostPosted: Mon Jan 03, 2011 10:30 pm    Post subject: Reply with quote
Who cares, go do a bigger one and own him.
A little trans fluid under the tires will do it.... Very Happy
volkyoo
volkyoo is offline
PostPosted: Mon Jan 03, 2011 10:36 pm    Post subject: Reply with quote
ok , i know that the engine isnt stock and it is dual carbed(hpmx),i have seen the car at the shop but dont know the owner, we(me and pals) were cruising(large avenue for cruising) and find the guy stopped at the light we were at the opossite side, it wasnt raining , no wet floor . the guy was trying to show off, and as soon as light went green, the guy made a drag like start burning a lot of rubber and making some white smoke,for several meters , so no braking, so Rolling Eyes i know it isnt a burnout but the thing that calls my attention is that hes running 17 " tires .
so now what do you guys think???
gerg
a.k.a. 6volt65
gerg is offline
PostPosted: Mon Jan 03, 2011 10:47 pm    Post subject: Reply with quote
Gearing? Tire size? Dry or wet ground?
Gerg
. . . I got 99 problems and my bus ain't one . . .
'65 Sunroof Beetle
'65 Vert
'60 Singlecab
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger Gallery Classifieds Feedback
volkyoo
volkyoo is offline
PostPosted: Mon Jan 03, 2011 10:54 pm    Post subject: Reply with quote
gearing?? : idk the guy
tire size?: 17 "
dry or wet ground? : dry.
midtravelmidengine
midtravelmidengine is offline
PostPosted: Mon Jan 03, 2011 11:01 pm    Post subject: Reply with quote
My buddy's 1776 in his '72 baja will spin his 30 x 9.5 x 15's about 15' on a hard launch, dry ground...
modok wrote:
And I know you don't know because if you did you would know the reason for my knowing you didn't.
youngnstudly wrote:
I just wasn't sure if I should recommend the 1/3 race cam, the 1/2 race cam, or the 5/8 race cam instead...guess it depends on how much of the race he wants to lead???
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Mon Jan 03, 2011 11:11 pm    Post subject: Reply with quote
My bone stock 1600 would do a pretty nasty smoke show if I dumped the clutch from a dead stop, but my tires at the time weren't that great. That was only in one gear though, the 1915 turbo I have now will light rubber through 3 gears. Laughing
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
RockCrusher
RockCrusher is offline
PostPosted: Mon Jan 03, 2011 11:41 pm    Post subject: Reply with quote
The nephews floor sleeper with progressive, header/stinger, copper feramic whatever clutch disc and poor man's posi would do smokers and donuts like crazy in his 64' before it got wrecked. Doesn't take huge power to start it and even less once you get it going good.
RC
[email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly.
wildman1
wildman1 is offline
PostPosted: Tue Jan 04, 2011 9:14 am    Post subject: Reply with quote
The lower the tire profile the less resistance the tread has on the ground. No sidewall flex equals easier to spin. Just like a 17" tire that would most likely be a 45 series, sometimes less on such a vehicle.
If this person was smoking 15" tires with say, 65 series that would be more impressive. Assuming he didn't inflate those tires to the max for easy spinning. Shocked
I would hunt him down and find out what he packed in the back. Wink
DarthWeber
PostPosted: Tue Jan 04, 2011 10:14 am    Post subject: Reply with quote
A stroker crank and 100 or more ft/lbs of torque will let you fry any size wheel combo as far as you like. Burnouts are all about torque anyways, not HP.
volkyoo
volkyoo is offline
PostPosted: Tue Jan 04, 2011 10:36 am    Post subject: Reply with quote
i know its no stroker, for sure, about the tires they re low profile 17 " , i saw his shortblock at the shop once and notice no cilynder spacers.
Stripped66
Stripped66 is offline
PostPosted: Tue Jan 04, 2011 10:46 am    Post subject: Reply with quote
Low profile tires and moderate-to-high tire pressure will allow just about any engine combo to light them up.
66brm wrote:
Bodacious wrote:
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor.
I don't think electrickery works that way
Altema
Altema is offline
PostPosted: Tue Jan 04, 2011 11:30 am    Post subject: Reply with quote
So let's just say it was a 1776 with about 85 to 100 hp and call it a day Laughing
Paul
wildman1
wildman1 is offline
PostPosted: Tue Jan 04, 2011 11:59 am    Post subject: Reply with quote
volkyoo, I have no spacers on my stroker! He could have custom piston pin height allowing everything to remain as narrow as stock, or narrower. Wink
ralf
ralf is offline
PostPosted: Tue Jan 04, 2011 12:07 pm    Post subject: Reply with quote
right on...
i used to run 45series 16inchers on my dad's 1300 bug
and could do nice burn outs (driving out of the university) hahahahaha
but always had 35psi on the rear tires.. just to be sure
sigh..... kids (when i was one LOL)
Flow Through a Curved Conduit
porting my SP head for my brother's project
https://youtu.be/OS_mVjQuqgk
volkyoo
volkyoo is offline
PostPosted: Tue Jan 04, 2011 4:09 pm    Post subject: Reply with quote
ok, but the mechanics over here dont have those skills. and probably this i s why that guy dosnt have a stroker. in the entire island i have just seen 1 stroker(2332 dual 48 ida) in a buggy and his best time is 13.7..... Rolling Eyes
DarthWeber
PostPosted: Tue Jan 04, 2011 6:14 pm    Post subject: Reply with quote
No offense Volkyoo but what is the purpose of this thread? Do you want to build a motor to do a longer burnout than the other guy? Why don't you just walk up to the guy and ask him about his motor?
Just wondering.
