wvbowtieman Samba Member
Posted: Sat May 05, 2012 7:59 pm Post subject: |
Installed the shroud onto the motor today. Ran the oil pressure hard line . Oil temperature sending unit. Oil pressure idiot light sender. Weber progressive 2 barrel and intake. Made a aluminum throttle return spring bracket.
Spark plugs and wires.
Heat riser tubes.
Alternator/ Fan assembly.
Bosch Blue Coil.
Posted: Sun May 06, 2012 6:55 pm Post subject: |
Nice weather this afternoon. Painted the ( "Cow Catcher" ) front body support/headlight support. Painted the 1"x2" body lift with Summit Racing semi gloss black chassis paint. This paint is really good looking stuff and durable. Just need to give a week or more cure.
Posted: Sun May 13, 2012 3:48 pm Post subject: |
Not much work this weekend. Touched up some welding and prepped the Roll Bar/Cage and rear bumper/motor cage for the black epoxy primer.
Asked by my local VW Club (WAGENFOLKS) to bring out the rolling chassis.
Posted: Wed May 23, 2012 7:01 pm Post subject: |
Got my new wheels in today. AR Torque Thrust TTO 15"x5" w/ 2- 3/4" backspace. New 155/80/15 BFGOODRICH RADIAL TA's. Returned my tires back under the front fenders.
Before with 215/70/14 tires and 14"x7" rims.
After....Set wheels in approx: 2" on each side.
joescoolcustoms Samba Member
Posted: Wed May 23, 2012 7:23 pm Post subject: |
Looks good!
The Knock-Offs are the bomb. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Tue May 29, 2012 2:08 pm Post subject: |
Started working on the body this week. Cracked hood is the only damage to the 40 year old NOS body.
Dash section/Hood was poorly attached. Removed old glass and reattached with new fiberglass.
Sanding down original 40 year old Gelcoat and filling in imperfections.
Hopefully some primer and some paint sprayed by the weekend.
ChadCook Samba Member
Joined: January 09, 2011 Posts: 764 Location: Charles Town
Posted: Tue May 29, 2012 9:09 pm Post subject: |
Looking good. I was watching that body in the classified section for months. When I was ready to purchase a buggy, it was gone. Do you plan to have it done in time to go to the Outer Banks this fall with Joe? |
Posted: Wed May 30, 2012 9:10 pm Post subject: |
ChadCook wrote: |
Yes Chad my plans are to be at the MOTB with this Buggy. This body was a NOS undrilled/ uncut body but has been a PITA to get prepped for paint. Hundreds of little shrinkage cracks in the Gelcoat all over this body from setting in the elements for 40 years. It would have been easier to just buy a new body but they seem a little plain looking...IMO.
My goal is to be painted and running by July 15 2012 give or take a week.
I used some high build primer today on the body and layed down over a gallon of primer and could still see hundreds of cracks. Let it dry and spent another 8 hours filling and sanding out cracks and imperfections. This is the days end results after another application of high build primer.
It looks pretty dang good now... |
gr8cobbler Samba Member
Joined: May 04, 2006 Posts: 916 Location: Midlife Crisis, Midwest
Posted: Thu May 31, 2012 5:07 am Post subject: |
X2 Looking good indeed, but I was impressed with the black wet sand pictures.
Wish mine was at this stage, I'm no fan of sanding and don't trust my ability to detect what will show up in the final paint and what won't. Too many hours invested to have to do it more than once.
Keep up the good work, looks like you are well on track to meet your deadline _________________ Gary
Being a cheap old fart is just a front for my actual lack of money. |
Posted: Fri Jun 01, 2012 6:35 pm Post subject: |
The body is finally ready for paint. I would have liked to have painted today but we had thunderstorms and high winds.
Went ahead and layed out the tail lights and drilled out and test fitted the 1958 Chevrolet tail lights with LED's.
Built a home made paint booth....
Eryk Samba Member
Joined: June 03, 2009 Posts: 100 Location: Lancaster, CA
Posted: Wed Jun 06, 2012 8:10 pm Post subject: |
Got my new seat covers for my 914 Porsche seats. From Iggee Fashion Auto Seat Covers. Look Sweet and easy to install.
Posted: Wed Jun 06, 2012 8:50 pm Post subject: |
Nice Fit!
Glad you were the guinea pig first. Looks like I will buy a set from Iggee also. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
riNR Samba Member
Joined: June 28, 2006 Posts: 1223 Location: Whitby, Ontario, Canada
Posted: Thu Jun 07, 2012 4:19 am Post subject: |
Nice build. I really like that body style, but then I don't see what the big whoo haaa about Manx bodies is either. |
Posted: Sat Jun 09, 2012 7:33 pm Post subject: |
Last weekend I applied the base paint and had a few set backs. I had broke through the primer in several areas while wet sanding and the origional black was showing through the paint.
The temperature was also very cool for June at 70 degrees and had several runs in the base paint. I decided to walk away for a week and regroup.
Sanded down the runs in the base paint with 400 grit wet/dry paper and resprayed approxamately 4 coats of high build primer. After a few hours I went ahead and wet sanded primer with a well used 400 grit sand paper and prepared to try to lay down some base paint and not run the paint this time.
Temperature today was a little on the warm side at 90 degrees but my garage thermometer was at 85 degrees so I decided to lay down some paint.
First base paint down and ran. Sanded runs out.
Well here it is....I am very happy with the results today.
4 liberal coats of base and 8 coats of clear!
BOOOOWAAAAAAA!!!!!!!! |
Posted: Sat Jun 09, 2012 7:53 pm Post subject: |
Is it the camera, or is it the paint? I do not see orange peal. It looks dipped and wet!
So, should I come pick up the body dolly, or should I just bring my body over there? _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Sat Jun 09, 2012 8:06 pm Post subject: |
joescoolcustoms wrote: |
So, should I come pick up the body dolly, or should I just bring my body over there? |
There is no orange peel...You are looking at dry paint. It came out AWWWWWSSSSSOME!!!!! I think it is as good or better than the Corvette paint. You could get by without buffing. |
crack monkey Samba Member
Posted: Sat Jun 09, 2012 8:08 pm Post subject: |
Wow! Great color.
What are your plans for inside the tub? |
Posted: Sat Jun 09, 2012 8:21 pm Post subject: |
crack monkey wrote: |
Wow! Great color.
I plan on using a spray on bed liner with no rubber added. It will go on semi gloss black with just a hammered paint look... but tough. The gel coat inside the tub is really cracked up so this will be easy fix. I wll also cover the outside of the tub with the same bedliner. If it does not look good I will make some custom inside panels later. |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Sat Jun 09, 2012 8:37 pm Post subject: |
Awesome. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
