sonofamitch Samba Member
Joined: May 27, 2012 Posts: 325 Location: Evergreen, CO
Posted: Mon Apr 13, 2015 1:28 pm Post subject: |
If you don't feel like cutting out the battery tray, you can temporarily fix it with some fiberglass cloth, POR15, and plate of steel. Cut the cloth to fit (put multiple layers down) and cover the hell out of it with the POR. once dried get a piece of steel to fit the shape of the tray. I did it on my bus and it's holding up great. _________________ '77 Westy 2.0L FI
http://www.thesamba.com/vw/forum/viewtopic.php?t=568454&highlight= |
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
Posted: Mon Apr 13, 2015 1:34 pm Post subject: |
Nice! Thanks for the advice, sonofamitch. I was planning on neutralizing the rust, slapping on some rustoleum, trimming a license plate, add some rivets and some seam sealer for a temporary fix. But I hadn't considered fiberglass!
I REALLY don't want to weld in a new tray on account of my lovely original paint.
Did I say lovely OG paint?
I mean it will be when I get around to waxing again
@Stu, everything's going slow right now. Saving up some more dough. I've been super f*cking depressed and its hard to stay motivated. _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Mon Apr 13, 2015 10:08 pm Post subject: |
You can get that tray in without burning your paint. Just weld in the areas not adjacent to exterior paint.
Here is my experience:http://www.thesamba.com/vw/forum/viewtopic.php?t=5...ttery+tray _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Mon Apr 13, 2015 11:47 pm Post subject: |
Not sure if you got my call, but give me a call when you can soon. ..let's talk. Keep moving forward buddy! You can do this, I know it! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Tcash Samba Member
Posted: Tue Apr 14, 2015 9:42 am Post subject: |
Thanks for the tips, Gentlemen. I may just get extra long battery cables and keep the battery on the Driver's side for now. A buddy of mine runs his battery there in his split window and it works just fine. At least until I can afford some materials and time to fix it correctly. _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
Posted: Thu Apr 16, 2015 9:50 am Post subject: Help from the pros! |
Good day gentlemen (and ladies).
I need to determine if these parts need replacing, and I am unfamiliar with how they wear or when they need to be replaced. I don't want to do this again for 7-10 years if it can be helped, so please keep that in mind when judging condition.
I have a type 4 GE engine and a 6 rib transmission. If you need pictures of anything else, like the throw out bearing or related hardware, I can get those pics tonight.
Also, the bus has sat for so long in it's current position, I didn't notice a tree growing out and into it. lol
ᏣᎳᎩᎯ ᎠᏰᎵ
riverside66 Samba Member
Joined: June 04, 2008 Posts: 218 Location: Sparta, NC
Posted: Thu Apr 16, 2015 4:24 pm Post subject: |
Treed!
This van is the jam and I can't wait to see it on the road!
BTW keep it up with all the photos! They're great |
Posted: Fri Apr 17, 2015 6:32 am Post subject: |
riverside66 wrote: |
Treed!
Lol thanks man! It's a panty-popper for sure. I have many, many good things in store for this bus this year after the engine install. _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
Abscate Samba Member
Posted: Fri Apr 17, 2015 8:08 am Post subject: |
Tony
In rough order of increasing cost
1 Throw out bearing - you replace it, unless you know it to be under one year old. Cheap, and wear item.
2 Clutch disc - a careful inspection for fluid contamination, depth of lining (make about 12 measurements around radius and compare to new) and scuffing or chatter marks on the lining. If it is within 80% of new - reuse. Clutches last as long as you don't abuse them on these cars, with stock engines.
3 Clutch plate -clean it up, check the surface for flatness (spec?) and signs of chatter. If none, reuse. Carefully check each finger for 'springiness' to see if there are any 'outliers' but my guess is that is good to reuse. _________________ .ssS! |
Posted: Fri Apr 17, 2015 8:55 am Post subject: |
Abscate wrote: |
Tony
3 Clutch plate -clean it up, check the surface for flatness (spec?) and signs of chatter. If none, reuse. Carefully check each finger for 'springiness' to see if there are any 'outliers' but my guess is that is good to reuse. |
Excellent advice, Abscate. Thanks!
I feel like I know enough now to make an educated decision after some time going through everything. _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
Posted: Fri Apr 17, 2015 11:16 am Post subject: |
8mm is spec on clutch discs for something. If you can get an 8mm wrench over the edge you may want to replace it.
I'd suggest just getting a new one and resurface the flywheel...new motor deserves a new clutch _________________ Stuart Zickefoose
206-841-7324
[email protected] |
airschooled Air-Schooled
Posted: Fri Apr 17, 2015 11:24 am Post subject: |
Stuartzickefoose wrote: |
I'd suggest just getting a new one and resurface the flywheel...new motor deserves a new clutch |
Wilson says 7mm wrench is trash on the clutch disk. I've never been able to fit an 8mm around any disk I've had though. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Fri Apr 17, 2015 1:27 pm Post subject: |
asiab3 wrote: |
Wilson says 7mm wrench is trash on the clutch disk. I've never been able to fit an 8mm around any disk I've had though. |
That's probably what I meant _________________ Stuart Zickefoose
206-841-7324
[email protected] |
bugger101 Samba Member
Joined: September 04, 2010 Posts: 1559 Location: orlando
Tcash Samba Member
Posted: Fri Apr 17, 2015 5:17 pm Post subject: |
asiab3 wrote: |
That's probably what I meant |
Bentley: "There should be at least 2.00 mm (about 1/16 in.) of friction material remaining above the rivet heads. Runout should not exceed 0.50 mm (.020 in.)".
Tcash |
Posted: Mon Apr 20, 2015 2:01 pm Post subject: |
Thanks T!
So, in my never-ending search to rescue 1978 Champagne Edition II's from returning to the earth (or meeting an untimely end with a crusher) I am going to look at this bad boy this evening with one of my Air-Cooled Partners in Crime:
My checklist:
Clothes to get dirty in: CHECK
Thin refrigerator magnet: CHECK
Trailer: CHECK
Cash: CHECK
I will report more on my findings this evening / tomorrow _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
shugon29 Samba Member
Posted: Tue Apr 21, 2015 2:46 am Post subject: |
Tony the champagne edition saver!!!!!!
I am looking for pics ..........and maybe you will throw us some bones......
wish you luck,
Gal |
Posted: Tue Apr 21, 2015 7:48 am Post subject: |
Hey Gal! How are you doing buddy?
Yes we did an Oklahoma Bus Pull on April 20th...heh... and got it home yesterday evening. It's really complete, a spectacular bus. Dry frame, OG paint underneath. A/C is more complete than I've ever seen before.
That's Jared, who rode to the hospital in this bus when he was 5 years old with a broken arm. That's his 48-52 Ford Tractor, too. Really nice guy, it was a pleasure meeting him.
Champagne Sunsets, nothing like them in the world.
Barnacle'd all over, and very, very cool.
Chrome rear bumper! I made a promise to myself that none of these parts would be transferred to my bus.
We are going to get this one back up and running if the compression tests good. _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
Posted: Tue Apr 21, 2015 8:50 pm Post subject: New 1978 CEII Transporter |
I always like to see before and after photos, build threads, etc.
Brought home the new bus yesterday. Super stoked.
Came with A/C, as did the other Champagne passenger buses I have picked up. I always thought this view, with the rear seat down, is super cool.
Gonna pop off a door handle to get the key code. Off comes the card:
This bus came with a full set of brown leatherette covered interior and door panels. They were not all installed, which saved most of them from water damage!
A pile of dirty loot to sort.
Original jack in plastic bag, a major score:
Owner's manual, VW Warranty booklet, and instructions for whatever old stereo was in it.
Unobtanium: An original Champagne Edition middle seat kick panel, although it's classified under the 'Janky' category:
Now, the restoration segment of tonight's thrilling episode!
I pulled the dash cluster to give it a refresher. Unfortunately the seals on this bus bit the dust a long time ago, resulting in things being pretty gritty on the inside. I am not surprised
stinky:
a bunch of little bolts around the edges:
Apart she comes:
Really happy this was included. This is the before shot. On my bus, I popped the ring that hold the glass to the clock instrument. It's a shitload of work, prying that little ring off, tiny bit by tiny little bitty bit. So I cleaned just the outer face of this glass, and it's a heck of a lot better than it was.
It was really grimy. Now all I need is a new brake light lens, which coincidentally is the exact same on the 73/74 VW Thing. It's only $6, what are you waiting for!? http://www.thethingshop.com/LENS-BRAKE-WARNING-LIGHT/productinfo/113919232L/
Aaah...clear glass in the dash makes me a happy man. _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
