Stock IRS Trailing Arm Beef-up Kit
Meco
Meco is offline
PostPosted: Sun Jan 09, 2011 1:29 pm    Post subject: Stock IRS Trailing Arm Beef-up Kit Reply with quote
I have a '63 pan that has been converted to IRS rear(building a fiberglass dune buggy), and want to run reinforced stock IRS trailing arms. The reason for stock arms, is that I want to retain the original shock mount location on the arm itself. I have seen the weld-on plate beef-up kits for stock trailing arms, but was wondering if anyone knew if the stock shock mounts need to be removed if you use this kit. Also would the arm interfere with the rear shock tower on this early pan(I hear that the bigger aftermarket boxed arms will)? Maybe it's pointless to reinforce a stock arm if you dont reinforce the shock mount? I have no clue.
baja5
baja5 is offline
PostPosted: Sun Jan 09, 2011 1:45 pm    Post subject: Reply with quote
The beef up kit normally would relocate the lower shock mount to the top of the arm, on the newly plated section. However, if you are creative you can still use the lower mount. Here is a pic of Mike Adams' car. It's tough to see but you can see in the pic where the rounded out section of the arm is where the shock goes.
http://www.wix.com/baja5s/nightrun
AZ-BUG
AZ-BUG is offline
PostPosted: Sun Jan 09, 2011 7:25 pm    Post subject: Reply with quote
There is/was a tube kit for sale (can't remember where), however should be relatively easy to do yourself, or at least to get more ideas...
dixon_cass
dixon_cass is offline
PostPosted: Sun Jan 09, 2011 8:24 pm    Post subject: Reply with quote
wow how does the axle have room to move? looks cool though
Meco
Meco is offline
PostPosted: Mon Jan 10, 2011 12:47 pm    Post subject: Reply with quote
Thanks for the pictures, guys. That helped a lot.
shred625
shred625 is offline
PostPosted: Mon Jan 10, 2011 2:20 pm    Post subject: Reply with quote
I am sure you could also make the plated kit work out fine with a little modification.
“It takes a big man to cry, but it takes a bigger man to laugh at that man.”
~ Jack Handey
wbrown45
wbrown45 is offline
PostPosted: Mon Jan 10, 2011 4:19 pm    Post subject: Reply with quote
Brandwood cars in Phoenix beefed up my stock arms so that I could retain the stock shock location. I really like them.
OK Thang
