3 psi Electric Fuel pump & 32/36 DFAV
Gadgetman728
Gadgetman728 is offline
PostPosted: Thu Jan 06, 2011 9:09 pm    Post subject: 3 psi Electric Fuel pump & 32/36 DFAV Reply with quote
My mechanical fuel pump died today. I'm thinking about ordering the purolator pro# 42S Part # 1008 from Appletree for 44 bucks.
Do I need to get a pressure regulator too or will the 3 PSI advertised be ok for a Weber 32/36 DFAV?
1600DP DR, Mild cam, empi 4 into 1 with a turbo muffler.
Gadgetman728
PostPosted: Fri Jan 07, 2011 7:36 am    Post subject: Reply with quote
anyone?
shred625
shred625 is offline
PostPosted: Fri Jan 07, 2011 9:06 am    Post subject: Reply with quote
I have a mechanical with an electric backup as required for racing class 9. I dont know about the pump you are talking about but I was talking to someone at FAT and he said that 3lbs is the max. They insisted that it is a must to run a regulator.
I know its not much but that is all I got.
“It takes a big man to cry, but it takes a bigger man to laugh at that man.”
~ Jack Handey
tanner_122
tanner_122 is offline
PostPosted: Fri Jan 07, 2011 10:44 am    Post subject: Reply with quote
ya my oldd motor had duel dell 40's on it i ran a holly Red pump but i had a regulator set at 3 PSI
91 jeep Cherokee "TANK"
Gadgetman728
PostPosted: Fri Jan 07, 2011 8:50 pm    Post subject: Thanks Reply with quote
Thanks guys.
The filter was plugged, replaced, buggy started. I still want to go electric and will include a regulator in the process.
This is the greatest forum ever. I dig my sand rail better than any of the bikes I've had.
greg mgm
greg mgm is offline
PostPosted: Sat Jan 08, 2011 12:43 pm    Post subject: Reply with quote
My buggy came with a low pressure electric pump on it and It runs great....no issues. It's nice if the car sits for weeks/ months, turn the key on for a few seconds and the carbs top up with gas. Then it starts right up.
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sat Jan 08, 2011 12:46 pm    Post subject: Reply with quote
$20 and you get a new mechanical fuel pump.
Don't have to worry about the pump running on after an accident. It shuts off with the engine.
Gary: OK. Ima poop.
spize909
spize909 is offline
PostPosted: Sat Jan 08, 2011 6:54 pm    Post subject: Reply with quote
So being new to this VW thing I was prompted to go out and see if I had a regulator in in-line that I somehow could have missed.
As I figured no regulator and I am running the Purolator pump that the op listed. If I remember correctly my pressure is about 4 lbs.....
What is the purpose of the regulator? Consistant fuel flow?
Why do I need one?
Forgot tot mention, I'm running dual IDA 48's.
Gadgetman728
PostPosted: Sun Jan 09, 2011 9:28 am    Post subject: regulator Reply with quote
It's my understanding that too High fuel pressure is as bad as too Low fuel pressure. Run what the carb Manu. recommends.
spize909
spize909 is offline
PostPosted: Sun Jan 09, 2011 11:43 am    Post subject: Reply with quote
OK then. I will need to get a regulator. The buggy was running crappy at the end of our last trip and I just replaced the element in the fuel filter and I have a tad over 5psi from the fuel pump. I thought that's what it was usually at.
I did a little research and it seems the dual 48's should be at 3-3.5 to run properly.
I have read the chrome ones with the dial are junk. Any recommendations on a capable regulator that won't break the bank? I'll be having to purchase some AN fittings as well so it's going to get fairly expensive.
Sorry if I hijacked the thread.........it all seems to go together.
Gadgetman728
PostPosted: Mon Jan 10, 2011 4:04 am    Post subject: pressure regulator Reply with quote
After a bit of surfing, I found some Holly Fuel regulators for about $36. The come in a couple of PSI ratings, choose the one for your carb. Most of the popular parts houses have them. I found them with minimal trouble.
spize909
spize909 is offline
PostPosted: Mon Jan 10, 2011 7:53 am    Post subject: Re: pressure regulator Reply with quote
Saw them. My local supplier has them as well and that's probably what I will go with.
