wicked1lbc Samba Member
Lostnfound Samba Member
Joined: May 03, 2009 Posts: 236 Location: Stratford, Connecticut
Posted: Tue Apr 17, 2012 11:51 am Post subject: |
Computers must not like you. _________________ -Patrick- |
j-sou Samba Member
Posted: Wed Jul 18, 2012 12:27 pm Post subject: |
It's come a long way since page 1. Great progress. Love the new tire/wheel set up and the streetable 2276 turbo.
And always loved that Zed's Dead remix too |
1low65 Samba Member
Joined: March 15, 2011 Posts: 476 Location: hampton, va
Posted: Wed Feb 20, 2013 11:31 am Post subject: |
I seen this thing shittin and gettin down military highway today. Sounded good. _________________ Nobody goes harder than the RadikalBugz, Team Angora Racing, The Panscrapers and MeanBugz. Those guys make me feel like a pussy with my 2.5 inches of ground clearance..... |
1low65 Samba Member
Posted: Wed Feb 20, 2013 5:02 pm Post subject: |
Lol, na i didn't catch that. I managed to see you as soon as you turned onto military highway. _________________ Nobody goes harder than the RadikalBugz, Team Angora Racing, The Panscrapers and MeanBugz. Those guys make me feel like a pussy with my 2.5 inches of ground clearance..... |
SirTimTIm Samba Member
Joined: September 23, 2009 Posts: 66 Location: Sacramento
Posted: Thu Feb 21, 2013 1:43 am Post subject: |
Dang that's a great looking bug, sits nice and I like the wheels. I'd paint the inside of your doors black though. Just my 2 cents. |
Posted: Thu Aug 01, 2013 8:06 am Post subject: |
So I didnt post any pix of the new race tranny but its in 3rd gear is nice and short. Rhino case and everything has been upgraded as well as axles
last hp upgrade: PROPERLY Turboprepped Dual 45mm Dellorto DRLA's
Here u can see all the removed internals. Emulsion tubes, Pump Jets, Main and Secondary Venturies, Paper gaskets, Needle Valves, and Bearing seals.
Overall pix showing all new rubber gaskets.
Dellorto update kit removes both venturies and replaces them with more efficient fuel bars you can also see the shorter air correction jets installed.
http://i1134.photobucket.com/albums/m614/wicked1lbc/20130727_223221_zpscb709178.jpg
Hard to see here but the outer Bearing seals were replaced and inner ones were also installed (machining required) to stop fuel from leaking under boost.
Also had to trim out the Carb/Manifold gaskets for increased flow
BIG BEEF manifolds to match
These are all things you should look for when purchasing a set of "turboprepped" Dellortos from somewhere. Here are the new specs for these. all parts purchased from CB Performance.
4- npn-throttle shaft seals-$7.95 each
4-#3309- DRLA turbo emulsion tubes-$22.95 each
1-#7346- DRLA update kit, required for blow through use-$138.95
2-#7214-.250 needle and seat-$8.95each
4-#7210-.60 idle jets-$2.95 each
4-#7213-.155 A/C jets-$3.95 each
4-#7209-.185 main jets-$2.95 each
4-#7211-.33 pump jet-$4.50 each
4-#7273- throttle plate spindle brg-$8.95 each
8-#734-throttle plate securing screw-$1.95 each
2-#3037-Turbo rubber gasket kit-$19.95 each
4-NPN- 33mm modulator rings-$13.95 each[img][/img] _________________ http://www.facebook.com/pages/Vintage-VDubz/158714140852567
64 Bug -- http://www.thesamba.com/vw/forum/viewtopic.php?t=446680
2276cc Turbo
Freeway Flyer Tranny
Matte Black with Spikes
Miklo ¡Chale!
Joined: August 27, 2008 Posts: 2058 Location: Antelope Valley, Ca
Posted: Thu Aug 01, 2013 9:43 am Post subject: |
I dig the hood spikes.
Mean looking bug man! _________________ ✠Miklo✠
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote: |
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche... |
63Ragtop NZ Samba Member
Joined: December 04, 2007 Posts: 895 Location: West Auckland
Posted: Tue Sep 10, 2013 6:43 pm Post subject: |
any updates bro?
how are the new carbs? _________________ If you can't join them, beat them! |
