Cadudeman Samba Member
Joined: January 26, 2011 Posts: 60 Location: Riverside, CA.
Posted: Tue Feb 22, 2011 9:48 pm Post subject: |
Printed the troubleshooting manual and it lead us to the wire that is supposed to come out of the DR and go to the starter was re-routed to the dash area. The car had an alarm so I'm guessing that wire was part of it. We ran the wire back to the starter and the fuel pump operates as it should.
I'm just getting started on replacing the fuel lines around the fuels pump(s)? I guess the the smaller pump is to supply the Eberspacher heater with fuel?
At this point I suppose I should pull the fuel tank and give it a good cleaning.
Is there a 'good' way to remove the existing fuel line clamps? I don't think my way is so good, but I guess it works.
I can see where the supply/return lines go into the tunnel up front but I haven't made it to the engine area yet. Is the line in the tunnel all steel? Are these something that should be replaced also?
Ed _________________ Ed |
jhicken Samba Member
Joined: October 24, 2003 Posts: 9466 Location: Fallbrook, CA
Posted: Sat Jan 29, 2011 8:49 pm Post subject: |
That's to bad, properly set up the FI can be near perfect. I've got 240k on the original FI on my '79. Also, removing it will reduce the value. You might try getting it to run before you start tearing it all apart, providing the car is not stolen.
Before you get into it, make sure the car is legal. If the VIN on the title does not start with a 157 or 158, it's possible that the car is stolen.
-jeffrey _________________ Der Kleiner Kampfwagens |
Posted: Sat Jan 29, 2011 7:55 pm Post subject: |
I plan on getting rid of the fuel injection anyway. I don't like it. _________________ Ed |
Posted: Sat Jan 29, 2011 7:10 pm Post subject: |
As noted in you other post, you ca is either a '77 or '78. Read Randy's link, it shouldn't be hard to diagnose and fix.
Posted: Sat Jan 29, 2011 6:50 pm Post subject: |
Thanks. I'll have to do a little reading. I tried it thru the side, then popped the top off and tried it that way. Neither worked. I guess the relay is my next destination . . . _________________ Ed |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Jan 29, 2011 6:19 pm Post subject: |
Cadudeman wrote: |
I have the ground wire connected, still no juice to the pump. I went to get some parts today and the guy there said to take the top off of the box to the left of the air filter and rotate the 'air mix' valve with the key on and I should hear the fuel pump. Still nothing.
Is there a way to test the double relay? Or just replace it? |
Whoa!, stop right now and don't go back to that shop!
You can depress the flap in the AFM with a screwdriver or chopstick through the square intake hole visible when you remove the air filter element, when the key is on you should hear the fuel pump run up front (very quiet).
Have you looked at any of the stuff Randy posted or these troubleshooting manuals yet??, the type 2 one works for beetle too, same stuff, different locations _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Jan 29, 2011 5:39 pm Post subject: |
Is there a way to test the double relay? Or just replace it? _________________ Ed |
Posted: Sat Jan 29, 2011 12:47 pm Post subject: |
How about some photos of this mystery car?
Canada didn't get Km speedos until 1977. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
finefettle Samba Member
Joined: October 13, 2006 Posts: 699 Location: Shelburne,Vermont
Posted: Sat Jan 29, 2011 12:32 pm Post subject: |
Photo of Brain and Double relay
Posted: Fri Jan 28, 2011 11:22 am Post subject: |
19super73 wrote: |
The PO must have installed an FI system in the car as '75 was the first year of factory FI Beetles. |
It is a possibility that the fuel injection was added after production, hell, the whole motor could be a transplant for all I know.
Let me ask this since I'm not a VW expert, is the '75 or later' fuel injection implementation a U.S. only situation, or was it global? Did foreign designated bugs have fuel injection before '75?
I believe this car came from Canada and the speedometer is km, not mph, I wouldn't think that was typical for a U.S. car.
Once again, all I know right now is the VIN starts with 111, it's fuel injected and the VIN # tells me it's '"1971 - UK Historic class".
I would definitely like to have my facts straight when describing this car but I'm not quite there . . . . yet.
19super73 Hardcore Stock Nazi
Joined: October 18, 2007 Posts: 4351 Location: Cité Soleil
vw_hank Samba Member
Joined: February 07, 2001 Posts: 5371 Location: Everett WA
Posted: Fri Jan 28, 2011 1:37 am Post subject: Re: L-Jet in 1975 |
old DKP driver wrote: |
L-Jetronic came on the bug in 1975 |
I was close I know my 71 square back was FI _________________ 1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods! |
Posted: Fri Jan 28, 2011 1:31 am Post subject: |
Cadudeman wrote: |
My friend said the same thing about the year and he thought injection came out in 74. I took the vin off the dashboard, maybe it's an imposter. Would there be another number somewhere else to confirm? |
thats the right # for A 71.. I think my 72 has the 111 vin because it was belt in 10/71? _________________ 1302s sunroof..
Posted: Thu Jan 27, 2011 8:50 pm Post subject: |
Cadudeman wrote: |
I also need to change the soft fuel lines, they leaked when I tested the pump.......... then I can move to next inevitable problem, right? |
Right, remember Fi runs at big pressure and flow so a little leak turns into a major fire in the blink of an eye, change all the soft lines before you do too much more. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Jan 27, 2011 7:51 pm Post subject: |
busdaddy wrote: |
Cadudeman wrote: |
So I need to remove the 'seat back' to get to it? |
You need to fold the seat back forward and usually remove the cardboard cover over the right fenderwell. Is the little brown wire attached to the negative battery terminal? |
There's a sticker under the dash for a stereo that was installed and it 's place called Ralph's in Vancouver, BC. I'm pretty sure this car is a transplant from the Great White North, that would explain the Eberspacher heater in the trunk. _________________ Ed |
Posted: Thu Jan 27, 2011 7:39 pm Post subject: |
JerryMCarter1 wrote: |
no fi in 71
sorry |
Well all I have now is a VIN # and a car with fuel injection. Maybe the VIN plate is a fake. When I search the VIN, it says the car is a 1971 -UK Historic Tax Class. That's all I got. _________________ Ed |
Posted: Thu Jan 27, 2011 7:32 pm Post subject: |
Found it. I didn't see the brown ground, that could be the problem right there. I'll when I have more light tomorrow. I also need to change the soft fuel lines, they leaked when I tested the pump.
I hope it's one of the 2, bad wire or bad relay, then I can move to next inevitable problem, right? _________________ Ed |
JerryMCarter1 Samba Member
Joined: January 07, 2007 Posts: 6199 Location: N.W. Phoenix
Posted: Thu Jan 27, 2011 7:14 pm Post subject: |
no fi in 71
sorry |
Posted: Thu Jan 27, 2011 5:52 pm Post subject: |
Cadudeman wrote: |
You need to fold the seat back forward and usually remove the cardboard cover over the right fenderwell. Is the little brown wire attached to the negative battery terminal? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Thu Jan 27, 2011 5:46 pm Post subject: |
You can see it thru the rear window (driver side)
if its a factory FI system. _________________ V.W.owner since 1967 |
