Blackoutt Samba Member
Joined: March 03, 2012 Posts: 127 Location: Waterford, MI
Posted: Mon Apr 09, 2012 11:39 am Post subject: Kennedy adapter for ecotec |
| Hey guys, so I'm getting ready to order the adapter plate from Kennedy. Did you guys that are running the Eco swap do different clutches or anything?? Just curious if you guys recommend anything special?? |
72Pstroke Samba Member
Joined: April 04, 2011 Posts: 68 Location: North Idaho
Posted: Mon Apr 09, 2012 1:38 pm Post subject: |
I used their Stage 1 pressure plate and organic clutch. It seems to be working fine so far. I have a stock type 1 tranny and it is my daily driver, so I don't want the clutch to be too aggressive.
Tim |
Posted: Mon Apr 09, 2012 2:39 pm Post subject: |
| So im looking at about $600 at the end of it? Obviously I need the adapter plate w/ flywheel $465 + pressure plate $99 +clutch ~ $40?? |
budnick Samba Member
Joined: July 18, 2010 Posts: 26 Location: Clarksville TN, Sierra Vista AZ
Posted: Mon Apr 09, 2012 3:56 pm Post subject: |
Heres how I did it.
Adapter from Phil's Bug Shack in northern Kentucky $250
(military discount )
New stock clutch disk $18
2100lbs empi pressure plate $70
Have 8500 miles on it with few problems. Clutch slipped a little at WOT in first and second for the first week or so but since has held the power perfectly. Just get new flanged head 10.9 bolts from fastenal ($24) and remember to use the correct sealant on the flywheel bolts or you will be leaking oil. |
Posted: Mon Apr 09, 2012 4:05 pm Post subject: |
| Do you know what the plate runs without military discount lol? And I'm assuming that's just the plate, no flywheel? |
Posted: Mon Apr 09, 2012 4:40 pm Post subject: |
| 250 was for the machined aluminum alloy plate with threaded inserts, modified 200mm flywheel, and hardware. I said to get the flanged hardware from fastenal because I had stretched the bolts provided in the kit. Call them and see. I got a discount not only because I was military but drove to his shop and dealt with the owner face to face and handed him cash. I would do it again if I had to. |
JesterGrin_1 Samba Member
Joined: April 05, 2012 Posts: 17 Location: san antonio
Posted: Mon Apr 09, 2012 5:48 pm Post subject: |
Just a wild question but can you use your existing Pressure Plate and Clutch Disc or do you have to get new ones?
You see I have a good 2400 Pound Pressure Plate and a Berg 3 puck disc. |
Adrenaline Junky Samba Member
Joined: April 11, 2006 Posts: 257 Location: Roseville, CA
Posted: Mon Apr 09, 2012 6:35 pm Post subject: |
Kennedy hooked me up with the adapter, flywheel, 2 stage pressure plate and 6 puck clutch. They were quick turn around (3 weeks) and fit like a glove.
That 2 stage is stiff, but i'll tell you something. When you dump the clutch, there is no slip. You just grab the steering wheel and hang on I'm also using a hydraulic clutch setup.
Quote: 25% more torque can be transmitted if a metallic (6 pad) disc is used. It is not recommended for street use due to harsh engagement.
KEP STAGE II 220 ft. lb.
Works good in well hopped up VW sand buggies and most other competition VW uses where the driver is determined to either win or break. |
Mr. Unpopular Samba Member
Joined: September 20, 2005 Posts: 3324 Location: Tampa Florida
Posted: Tue Apr 10, 2012 8:06 am Post subject: |
| JesterGrin_1 wrote: |
As long as it matches your flywheel you're fine.
The first adapter I bought was for a bug flywheel. The second was for a bus flywheel since it went into our bay window bus with a stock 6 rib.
Both were used with the old clutch pressure plates (they were in good shape).
The bus doesn't slip at all. Granted I don't beat on it, but the bus weighs 3500 lbs. _________________ Reasons to hate me:
FloriDUH resident
I'm a male nurse
I have a late model bug (with only 3 bolts holding the motor in)
I have a rail buggy (with no front brakes or shocks)
I have a late bay Westy (It's got a water-cooled motor) |
