NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Mon Feb 07, 2011 8:53 am Post subject: Old VW Horns |
What is with POs and VW horns? My Thing is the fourth vintage AC VW that I have owned. Every one of them including this car had non-working horns or horns that were not working as installed in the factory. In the case of my Thing the PO had a button on the dash to work the horn with wires running through the luggage compartment.
When I bought the car he pointed this out and I just laughed and said Yes that is interesting.
Last weekend I decided to fix this. The old horn and wires were still there although one of the terminals on the old horn was broken off. Installed the new horn and attached the old wires. Pulled the steering wheel cover. The wire in the column was not connected to the steering wheel cover. Hooked it up - works fine. All of my other cars were a similar situation - bad horn, bad ground, broken wire, etc.
I am sure it took me less time to fix the original set up than the PO spent jury rigging the "fix".
What is so mystifying to people for something that is so incredibly simple? _________________ Ghia Owner Emeritus |
Semper_Dad Samba Member
Posted: Mon Feb 07, 2011 9:16 am Post subject: |
The horn wasn't working on my Thing when I bought it. PO never attempted to fix it. Once I got it home I popped the cover off found the wire had become disconnected from the cover. 2 minute fix. Easiest circuit to troubleshoot and fix. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Posted: Mon Feb 07, 2011 10:25 am Post subject: |
Semper_Dad. That is funny.
I know these cars often come with far greater problems and fixing the horn is minor in the scheme of things.
Just ranting, that is all. _________________ Ghia Owner Emeritus |
Van-go108 Samba Member
Joined: November 23, 2006 Posts: 2995 Location: Southwestern, NM
Posted: Mon Feb 07, 2011 10:52 am Post subject: |
I do need to work on my horn "Thing". It works and all but, that little "Meep, Meep" doesn't do anything for me. It's just a laughable little noise. I need to do an alternator conversion just for the power upgrade to put a proper horn. _________________ "Okay, so there's 6 beers and 5 of us. You know what this means don't you? 4 of you are going to have to leave."
1973 Thing
1957 Continental Mark II Click to view image |
booch Samba Member
Joined: July 03, 2008 Posts: 784 Location: Ambler, Pennsylvania
Posted: Mon Feb 07, 2011 11:05 am Post subject: Re: Old VW Horns |
NOVA Airhead wrote: |
In the case of my Thing the PO had a button on the dash to work the horn with wires running through the luggage compartment. |
Both of my Things and my 70 Beetle had this same setup when purchased. All of them had the same style button as well.
I am sure it took me less time to fix the original set up than the PO spent jury rigging the "fix". |
Agreed, not much to it to fix it the right way. _________________ Old City Oil Drippers Northeast |
Posted: Mon Feb 07, 2011 11:30 am Post subject: |
Van-go108 wrote: |
I do need to work on my horn "Thing". It works and all but, that little "Meep, Meep" doesn't do anything for me. It's just a laughable little noise. I need to do an alternator conversion just for the power upgrade to put a proper horn. |
Something to "inspire you"
LEGAL WARNING: This will get you a ticket in Washington State _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
tallman206 Samba Member
Joined: January 06, 2006 Posts: 316 Location: St.Petersburg Florida USA
Posted: Mon Feb 07, 2011 3:52 pm Post subject: |
I think that for the most part, electrical problems bewilder most owners, particularly when it comes to a rotating part (steering column horn wiring - how DO they do that?). Also, the horn being a ground-to-operate circuit seems to fool others. Really rather simple stuff.
I upgraded my horns using the very similar WOLO 306-2T horns.
Almost identical to the large Bosch horns used on many German vehicles.
Scuffed up the front grilles and painted the chrome bling to matte black.
Use a relay if you are going to put in both horns.
Underneath my front bumper - put a second bracket on for the right horn.
norcalmike Samba Member
Joined: May 14, 2005 Posts: 4784 Location: Marina, CA
Posted: Mon Feb 07, 2011 3:56 pm Post subject: |
i too have a button on my dash. never bothered to fix it. i will someday |
vws-microcars4jim Samba Member
Joined: September 25, 2005 Posts: 337 Location: Chicago
Posted: Mon Feb 07, 2011 5:16 pm Post subject: |
I have used an auxillary horn button as well, such as this one,
to command air horns. It gives me the choice of the stock beep-beep or a deafening blast. I really like and recommend the air horns.
I truly believe it has helped avoid a few accidents, such as waking up texting drivers wandering into my lane.
Semper_Dad wrote: |
LEGAL WARNING: This will get you a ticket in Washington State |
Does Washington state have a horn-decibel ordinance?
I would challenge an officer's ticketing for use of those horns posted, within reason. |
SgtSamy Samba Member
Joined: July 10, 2010 Posts: 734 Location: Miami, Florida
Posted: Mon Feb 07, 2011 5:24 pm Post subject: |
vws-microcars4jim wrote: |
Semper_Dad wrote: |
Texting drivers are trully a danger on the road. |
Posted: Mon Feb 07, 2011 5:31 pm Post subject: |
RCW 46.37.380
Horns, warning devices, and theft alarms.
(1) Every motor vehicle when operated upon a highway shall be equipped with a horn in good working order and capable of emitting sound audible under normal conditions from a distance of not less than two hundred feet, but no horn or other warning device may emit an unreasonably loud or harsh sound or a whistle. The driver of a motor vehicle shall when reasonably necessary to insure safe operation give audible warning with his or her horn but shall not otherwise use such horn when upon a highway.
(2) No vehicle may be equipped with nor may any person use upon a vehicle any siren, whistle, or bell, except as otherwise permitted in this section.
(3) It is permissible for any vehicle to be equipped with a theft alarm signal device so long as it is so arranged that it cannot be used by the driver as an ordinary warning signal. Such a theft alarm signal device may use a whistle, bell, horn, or other audible signal but shall not use a siren.
(4) Any authorized emergency vehicle may be equipped with a siren, whistle, or bell capable of emitting sound audible under normal conditions from a distance of not less than five hundred feet and of a type conforming to rules adopted by the state patrol, but the siren shall not be used except when the vehicle is operated in response to an emergency call or in the immediate pursuit of an actual or suspected violator of the law, in which latter events the driver of the vehicle shall sound the siren when reasonably necessary to warn pedestrians and other drivers of its approach.
I've seen tickets issued for unduly loud horns used for the purpose of "scaring" or "alarming" pedestrians or other drivers. Usually not written unless someone complains. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
waxhead Samba Member
Joined: January 19, 2004 Posts: 946 Location: Philly 'burbs
Posted: Tue Feb 08, 2011 7:49 am Post subject: |
A mystery indeed. My old Ghia had the same 'button mounted on the dash' fix. If the PO was handy enough to rig that up, you would think he could have figured out how to fix the stock horn button. _________________ Mike B. |
Rev. Scott Samba Member
Joined: June 04, 2006 Posts: 770 Location: Philo, Ca.
Posted: Tue Feb 08, 2011 8:39 am Post subject: |
i have bets as to weather or not the horn works. _________________ "I haven't seen one of those since I was shootin' at 'em!" |
oasis Samba Member
Posted: Tue Feb 08, 2011 9:26 am Post subject: |
I love it when laws use words like normal, unreasonable, and harsh without actually defining these words.
Unreasonably loud? Someone is about to hit you by unlawfully invading your lane-space, and your horn blows them back where they belong -- seems like a good "reason" to be that loud by action and results to me. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI |
Posted: Tue Feb 08, 2011 9:53 am Post subject: |
oasis wrote: |
Unreasonably loud? Someone is about to hit you by unlawfully invading your lane-space, and your horn blows them back where they belong -- seems like a good "reason" to be that loud by action and results to me. |
Shades of "grey" keep life interesting _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Tue Feb 08, 2011 10:37 am Post subject: |
For those worried about the law - mid-'70's Buicks and Cadillacs had really loud deep stock horns. If used to substitute the Thing's horn, I'm sure they would pass muster. |
74 Cosa Samba Member
Joined: June 06, 2006 Posts: 535 Location: The Midwest
Posted: Thu Feb 10, 2011 11:46 am Post subject: |
....as for the horn button, I bet it's a missing ground wire that jumpers the flex coupling on the steering column. |
lukesky Samba Member
Joined: July 12, 2006 Posts: 246 Location: See The Rabbits, IA
Posted: Wed Jun 29, 2011 6:06 am Post subject: |
Hi, all. I was going to rig up a dash button myself because I've got a really bad connection between the 4 contact points under the steering wheel cover and the black wire that comes up through the middle of the steering column. I can tell that the cover itself is in 2 pieces, but I can't figure out how to get them apart without breaking off whatever tabs hold it together.
I get a pretty good sound when I jump the black wire to the contact points on the steering wheel, but when I put the cover back on, I either get nothing or the sound of the AFLAC duck being strangled to death.
Any ideas? (I'll try to post pics later) Thanks. _________________ You get what you get, and you don't throw a fit.
-Gabi |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
Posted: Wed Jun 29, 2011 6:30 am Post subject: |
lukesky wrote: |
Any ideas? (I'll try to post pics later) Thanks. |
Without pics Not sure I completely understand your post. The cover should kind of pull up and turn to remove. Its a bit hard to describe but you don't want to force it. There should be a single terminal on the back side of the cover that the block wire hooks to. If all of this is there and the horn works fine when you ground the black wire to the column then your contacts on the cover are the problem. _________________ Ghia Owner Emeritus |
