Stock 1600 DP rebuild, step by step
maboyce
maboyce is offline
PostPosted: Wed Jan 16, 2013 1:24 pm    Post subject: Reply with quote
I rechecked the valves, and found that the #1 and #4 exhaust valves were slightly tight. I readjusted them to 0.15 mm.
I ran the engine again to see if it made any difference to the chirping, and it didn't. I think it may be down to using a non-VW muffler, and as I said before, it's much less noticeable in person than in the video.
PatterBon
Samba Engine Connoisseur
PatterBon is offline
PostPosted: Wed Jan 16, 2013 4:32 pm    Post subject: Reply with quote
What brand of muffler are you using?
PNW Dub Folk & Kitsap dub Folk (KdF)
Austin Aircoolers VW Gang
2020 Ford F-150
1973 Standard Beetle
1969 Cessna 172K Airplane
1959 Karmann Ghia
US Army CH-47 Chinook Helicopter Repairer
maboyce
maboyce is offline
PostPosted: Wed Jan 16, 2013 6:00 pm    Post subject: Reply with quote
There's no writing on it anywhere - no idea. There's a pressed circle between the tail pipes that might have been a logo at one time, but doesn't seem to be now. From the construction of it, it was clearly very, very cheap.
sinful
sinful is offline
PostPosted: Wed Jan 16, 2013 6:55 pm    Post subject: Reply with quote
woho great job !
flyboat
flyboat is offline
PostPosted: Wed Jan 16, 2013 8:11 pm    Post subject: Reply with quote
There is another chirp that is related to the timing and carb adjustment. sometimes it takes a bit of fiddling to get it out. It usually is the carb more than the timing.. get it warm. Set the timeing, adjust the carb according to Bentley then set teh timiong again.
Great job and great persistance.
Loctite 518 is my gasket sealer/maker of choice, especially with aluminum. Thick enought to do teh job, thin enough to not cause problems.
79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car
thebornotaku
thebornotaku is offline
PostPosted: Thu Jan 17, 2013 12:48 am    Post subject: Reply with quote
This thread is awesome and aside from the disassembling/reassembling it's shown me just how easy VW engines really are and definitely giving me encouragement to go set up my workbench and start tearing in to my AE case...
1974 Super: "Diego"
ach60 Premium Member
ach60 is offline
PostPosted: Thu Jan 17, 2013 2:22 am    Post subject: Reply with quote
Why are the spark plugs so deep in the holes?
Good Luck
Al
View user's profile Send private message Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
maboyce
maboyce is offline
PostPosted: Thu Jan 17, 2013 8:57 am    Post subject: Reply with quote
They're probably just threaded in loosely in this picture.
fred69vert
Location: Home of the US Navy Atlantic Fleet, Norfolk, VA
fred69vert is offline
PostPosted: Fri Jan 18, 2013 6:03 am    Post subject: Reply with quote
I took this thread, copied and pasted, resized the pictures and ended up with a 68MB, 182 page Word document to go into my tech library.
Thanks for the informative thread........
I'm not losing my hair, it's just retired and relocating further south.
1969 VW convertible, "Heidi"
kcman
kcman is offline
PostPosted: Sat Mar 30, 2013 1:24 pm    Post subject: Reply with quote
Awesome job and thanks for sharing.
I have worked on my own bus and have had a blast so far, but I have not build my own engine yet. I think this post will help me a lot in getting that goal accomplished. Love the vw community and thanks again for the sharing and all the info on how to do this right!
http://www.vdubbs.com/ - THE PHOTO GALLERY FOR AIR COOLED VDUBBS
garfish
garfish is offline
PostPosted: Sat Mar 30, 2013 9:53 pm    Post subject: Reply with quote
I think I'll have to buy a couple of new ink cartridges but
I'm definitely printing this out and putting it in a binder. Kudos for your meticulousness!!
hethen57
hethen57 is offline
PostPosted: Thu Apr 11, 2013 10:21 am    Post subject: Reply with quote
Thanks so much for your detailed description of the process....after all the takedowns and rebuilds is there a happy ending to this story? ie, How does it run? Did you get the oil leaks solved? Shocked
69 Baja Bug
77 Bus
johnnypan
johnnypan is offline
PostPosted: Thu Apr 11, 2013 8:48 pm    Post subject: Reply with quote
He did an engine build thread in the 58 to 67 bug forum as well, "a correct assembly of a '67 engine"..another pic heavy hack job he had to take back apart a few times...seems he decided to toss in the towel,its a shame...he sure can paint pretty and glue parts together...the whole "mechanic" side of the equation eludes him..
hethen57
hethen57 is offline
PostPosted: Fri Apr 12, 2013 3:46 pm    Post subject: Reply with quote
That's too bad....it didn't sound like it was going well with multiple teardowns and rebuilds. However, the cleanliness of the worksite, the meticulousness, and the detail of the photos was still pretty darn good.
69 Baja Bug
77 Bus
maboyce
maboyce is offline
PostPosted: Fri Apr 12, 2013 5:04 pm    Post subject: Reply with quote
I didn't notice that I hadn't quite finished this thread.
I had to reseal the strainer plate with Hylomar one last time, and then replace the oil and zinc additive yet again.
I ran the engine again. It didn't leak, but when I checked the acorn nuts, they weren't as tight as they had been. So I tightened them, and that seemed to kill the leak permanently.
Since I don't have a Beetle myself any more, I sold the engine within a few days of the last post here. With my parts cost covered, I feel I got a good deal on a very valuable learning experience.
I think the biggest thing I learned is not to use aftermarket parts, or even parts from multiple years if at all possible. The other engine hasn't given me nearly as much aggravation as this one did, and it's because all the pieces were made to fit together. I thought that this would be the easy engine, that I would build and sell 'really quick', and the other one would give more trouble, but it's the opposite.
Thanks to everyone who posted encouraging things, and who enjoyed reading along over the past several years.
AustinVonZweigart
AustinVonZweigart is offline
PostPosted: Sat Jun 08, 2013 3:51 pm    Post subject: Reply with quote
Such a great help thanks!
View user's profile Send private message Twitter Instagram Classifieds Feedback
Johnnybgoood
Johnnybgoood is offline
PostPosted: Fri Jun 21, 2013 3:01 pm    Post subject: Reply with quote
is the cam plug on the back installed wrong? on my engine it is dished in, cup side facing out.
ghi66
ghi66 is offline
PostPosted: Sun Sep 22, 2013 3:57 am    Post subject: Re: Stock 1600 DP rebuild, step by step Reply with quote
Briiliant reference and build Smile
Busdriver79
Busdriver79 is offline
PostPosted: Sun Sep 22, 2013 7:08 am    Post subject: Reply with quote
The exhaust "chirping" in the video can be adjusted by moving the tailpipes either a bit inward or by pulling them out a little...Awesome thread ! Very Happy
1970VWGUY
1970VWGUY is offline
PostPosted: Mon Sep 23, 2013 6:20 pm    Post subject: Reply with quote
I have a question that's been bugging me...no pun intended...with all the crap you put on all the joints from those tubes of stuff....why and how could any oil be leaking unless that stuff is worthless...
And I thought that's what gaskets were for ...to seal the mating surfaces...some gaskets do not require any type of stuff on them...
Not being smart just trying to understand what's going wrong with all the leakage..
Page 7 of 9
