Stock 1600 DP rebuild, step by step
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8, 9
eschmi
eschmi is offline
PostPosted: Tue Jun 30, 2015 10:02 pm    Post subject: Reply with quote
that's why I was asking to be 100% sure, I've had people tell me to paint the inside too but I thought it'd end up getting the oil as you said, that's why I asked even though it's kind of a stupid question. I'd rather consult multiple sources to make the right decision than mess it up and screw up an engine.
Keithinky
Keithinky is offline
PostPosted: Thu Apr 21, 2016 12:56 pm    Post subject: Re: Stock 1600 DP rebuild, step by step Reply with quote
Maboyce,
Awesome. Thanks for putting this on the samba for all of us. Looking at how thorough you were I can see it was very time consuming- engine work and writing, pic posting.
Thank you. Keith
TheDon
TheDon is offline
PostPosted: Wed Dec 27, 2017 9:20 am    Post subject: Re: Stock 1600 DP rebuild, step by step Reply with quote
I am so glad the thread author used the photo hosting on TS for all of his detailed photos. I just ordered the same book and have a single port engine to rebuild. This thread is great
lawn ninja wrote:
Every time I crush a fat chick I feel like a I save baby kittens and baby kittens are important to everyone.
dagen_1
dagen_1 is offline
PostPosted: Thu Jan 11, 2018 8:11 am    Post subject: Re: Stock 1600 DP rebuild, step by step Reply with quote
still a valuable thread in 2018. thanks for the detailed posts and pictures.
many thanks!
74 Super Beetle
firengine103
firengine103 is offline
PostPosted: Tue Oct 09, 2018 11:41 am    Post subject: Re: Stock 1600 DP rebuild, step by step Reply with quote
Great thread, Thank you!! Jim E. OKC
loctiteis
loctiteis is offline
PostPosted: Sat Feb 26, 2022 2:44 pm    Post subject: Reply with quote
[quote="maboyce"]Exhaust system and tinware
Last year at this point I noticed a broken-off tin screw on one of the cylinder heads. I had to use the mig-welded nut trick to remove it, and then clean up the hole with a tap.
I recommend filing bolt top,placing good fitting washer over, welding connection,then tacking nut or bolt to washer, letting cool, then penetrating oil and work back and forth a bit before removing entirely. then use broken bolt with small zip cut slot through thread length as chaser,saves time on chasing the rest.
Great post,following with interest and concentration.
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Sun Feb 27, 2022 9:25 am    Post subject: Re: Stock 1600 DP rebuild, step by step Reply with quote
Here’s what I did using only a die grinder and a drill.
https://www.thesamba.com/vw/forum/viewtopic.php?t=666653&highlight=
Page 9 of 9
