How do I remove dash from 1974 Super beetle?
alexvw
alexvw is offline
PostPosted: Sun Feb 20, 2011 5:20 pm    Post subject: How do I remove dash from 1974 Super beetle? Reply with quote
Wondering how I remove the dash from a 74' SB so I can add a toggle switch. Thanks. Very Happy
Joel
Joel is offline
PostPosted: Sun Feb 20, 2011 6:22 pm    Post subject: Reply with quote
That is a lot of work just to mount a toggle switch, I doubt anyone has ever removed the dash just to add a switch, you can access all the areas to mount a switch without removing the dash
Removing the dash isn't a huge job but still over kill for just for a switch addition.
Anyway here's whats involved.
http://www.superbeetlesonly.com/forum/index.php?showtopic=6982
You can see it had a push button for the washer fitted between the fresh air knobs where the blank plug was and the dash wouldn't have been removed for that.
Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
alexvw
alexvw is offline
PostPosted: Sun Feb 20, 2011 7:01 pm    Post subject: Reply with quote
Well I just got some lights for it and wanted to mount a switch somewhere in the dash, are there any plates that can be removed from it so I can cut a whole for a switch? Thanks.
Joel
Joel is offline
PostPosted: Sun Feb 20, 2011 7:49 pm    Post subject: Reply with quote
Plenty of spots in the switch panel which is easily removed.
pop the end cap/cover bits off, theres 2 screws under each and 1 screw under the rubber plug below the speedo.
Some cars the steering column stops the panel coming out easy, others it comes out fine so u may need to loosen that off abit.
But its not hard to drill the hole through then reach up behind and mount the switch either
Alot less work that removing the dash.
