SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 1586 Location: Oxfordshire, UK
Posted: Tue Feb 22, 2011 12:33 pm Post subject: A Bluestar from Germany... |
Limey and I have just completed a 1400 mile round trip in 56 hours!! I’m a little tired to say the least.
The trip in question was to collect my latest project. A Bluestar. I’ve had a Bluestar before but it was Diesel and just a run of the mill van. Not that Bluestars aren’t nice… they are but I wanted something a little more rare and with the extra parts. I wanted a petrol so that I could have air con and eventually after 3 years of looking, this turned up on ebay.de a few weeks ago.
After a lot of working out finances and talking to Kathryn (have to have the bosses approval!) I decided to put in a bid and lo and behold I won
It’s a 1989 2.1 DJ Bluestar with the following factory accessories.
Air Conditioning
Cruise Control
Electric windows
Electric mirrors
Central Locking
ABS
Power Steering (with Buschmeide replacement flexi pipes)
Westfalia towbar
Other things which have been added at a later date:
Webasto heater (air heater, not water)
Aux battery
240V heater with thermostat
Additional lighting (lots of it!)
Outside temperature digital display (housed in a factory heated set housing in front of the steering wheel
Amongst the parts which have been replaced in the last 6 years are:
New engine
All new brakes
Bilstein front shocks
Koni rear shocks
Fuel pump and relay
Exhaust silencer
Electric window motors and mechanisms
Speedometer
Also with the van came:
Camping cabinet
Awning (used once!)
Roof rack
Roof box
Bike rack (clamps to the tow-ball)
2 KW Generator
Fire extinguisher
Fly screen for sliding window
H&R springs and a set of Koni shocks
Lots of other spare parts…!
There is a long list of things which don’t work, including the air con, ABS, central locking (only the sliding door doesn’t operate), power steering pipes make an awful racket – have a feeling that whoever fitted them removed the first section of rubber pipe and this will quieten it back down, the rear seat is wrong – it was stolen along with the front window switch surround (drivers side) and carpet. There’s a little bit of rust on a few seams and especially around the lower B-pillar seams which need work now before they get too bad.
It drives fairly well and picks up very quickly. I have a feeling that there’s a gearbox or engine mount away as there’s a fairly heavy thud from the back as you accelerate and then decelerate.
Now the work begins…
I need a garage just to store this stuff!
One of the first things to go will be the rear lights. The stock Bluestar lights (they're smoked from the factory) are included. Then it'll be get it ready for an MOT and registration!
MG _________________ 1989 Syncro 16 S6 Westy Limey
1991 Syncro Lightweight SWB
1989 S8 Bluestar
1990 Tristar |
the caveman Samba Member
Joined: August 09, 2004 Posts: 874 Location: island state of Montreal
Posted: Tue Feb 22, 2011 1:26 pm Post subject: |
| how easily did your 16 incher pull the van and trailer all that way? |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 2080 Location: Cascadia
Posted: Tue Feb 22, 2011 1:34 pm Post subject: |
Nice score! Wish mine had ABS _________________ --Casey
'89 Bluestar
"Endeavor to persevere" |
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 2917 Location: E. Washinton
Posted: Tue Feb 22, 2011 2:12 pm Post subject: |
| the caveman wrote: | | how easily did your 16 incher pull the van and trailer all that way? |
x2
I want the trailer _________________ -Mike
67 Split Bus
86 westy- H4 powered
Subaru install
My Hightop install thread |
Posted: Tue Feb 22, 2011 2:27 pm Post subject: |
No problem. Fully loaded, I had to drop to third on the steepest hills but the speed never dropped below 50mph.
Oil temps never got above 95oC but I think that's to do with it being very cold out and my tweaking the AFM before setting off so it wasn't throwing fuel in.
Limey did 22mpg (that's imperial 4.546 litres to the gallon) over the trip.
1989 S8 Bluestar
1990 Tristar |
Posted: Tue Feb 22, 2011 2:29 pm Post subject: |
Future plans for this project include the following running gear:
Audi AAN engine (from Audi S6), 2.2 20V Turbo 230bhp.
Porsche 996 Carrera 4 gearbox, propshaft, front diff with VC.
Porsche 996 brakes all round.
Koni Coil over shocks and some form of rear anti-roll bar.
1989 S8 Bluestar
1990 Tristar |
Posted: Tue Feb 22, 2011 2:32 pm Post subject: |
| SyncroGhia wrote: | Future plans for this project include the following running gear:
MG |
Drool...the AAN is probably the sweetest petrol engine VAG ever produced _________________ --Casey
'89 Bluestar
Posted: Tue Feb 22, 2011 2:37 pm Post subject: |
Oh yeah, and pulling off the blacked out window film!
Not sure if I'll have to soak the window in hot water or just use a heat gun...
1989 S8 Bluestar
1990 Tristar |
jabba Samba Member
Joined: April 30, 2008 Posts: 92 Location: La Rochelle (FRANCE)
Posted: Tue Feb 22, 2011 4:40 pm Post subject: |
I gonna follow this "autobahn killer" new project.
Very nice choice Mike! _________________ vanagon 1,9 tdi pd 130 hp |
ThorAlex Samba Member
Posted: Tue Feb 22, 2011 5:55 pm Post subject: |
DJ with a cat? Never seen that before, do you know anything about it? Nice van BTW, and i love your projects! _________________ Currently vanless
Ex-vans:
1990 Caravelle coach 1.6TD
1986 Transporter Double cab syncro 2.1 112hp |
78BayDriver Samba Member
Posted: Tue Feb 22, 2011 6:54 pm Post subject: |
Soak the tint, or find yourself some tint remover spray, no heat gun. And I want the tail lights, shipped to Maryland.... Lemme know... PM me.. _________________ 1987 Vanagon GL 2.1 Flat Stanley (present)
1991 Golf GTi Forest Green
1981 Vanagon L 1.6 Diesel
1978 BayWindow Bus
1974 Bus
1990 Jetta
1979 Dasher Wagon
1972 Beetle |
James 93SLC Samba Member
Joined: January 21, 2009 Posts: 914 Location: NE Ohio
Posted: Tue Feb 22, 2011 7:33 pm Post subject: |
Nice find.
Curious about the ABS setup. Can you get some pics of the system (if it's readily accessible)? I've heard of Vanagon's with ABS but have not seen any pictures. _________________ -------------------------
91 Vanagon Carat
93 Corrado SLC
Photos: http://picasaweb.google.com/slc.corrado
tencentlife "Sometimes a pooka is a problem and sometimes it's just a pooka" |
Posted: Wed Feb 23, 2011 1:55 am Post subject: |
| ThorAlex wrote: | | DJ with a cat? Never seen that before, do you know anything about it? Nice van BTW, and i love your projects! |
I've not come across it before either. I have a feeling that the van will have come with an MV but the engine was replaced in 2004 (15,000 KM ago) with a DJ so I expect that it's running the MV Digifant system. I've often wondered how this would work out... now I get to play with it!
The cat will be removed asap as we don't need them over here. That should free up some hp
Thanks 78BayDriver, I'll try that. I need to remove the rear window anyway as the tailgate needs painting so I'll do that then. The sliding windows are slightly more tricky. Will PM re rear lights.
James, the ABS sits under the drivers seat and takes up space where the aux battery would have been fitted. There is an extra light on the dash just above the handbrake warning light which should come on when the igntion is switched on and then go out once the engine is running. There are a lot more brake pipes!! I'll get some photos up.
Cheers Jabba, I'm looking forward to getting the engine/gearbox installed.
1989 S8 Bluestar
1990 Tristar |
vwlovr Samba Member
Joined: May 21, 2006 Posts: 1092 Location: on the road
Posted: Wed Feb 23, 2011 3:02 am Post subject: |
definitely jealous. i would love to take on this exact project.
so why not go full porsche? $$$? not that the audi motor is a slouch, but still.
also, is it difficult to match the R&P's of the carrera 4 and syncro front diff?
and with all this talk of the ABS are you going to be able to keep it ABS when moving up to bigger brakes?
cheers! |
jabba Samba Member
Posted: Wed Feb 23, 2011 4:25 am Post subject: |
Mike,
The next time you cross France don't miss to tell me. In June, with few of my friend we organise a meeting near La Rochelle if you want to come you're welcome.
Stéphane. _________________ vanagon 1,9 tdi pd 130 hp |
Posted: Wed Feb 23, 2011 5:11 am Post subject: |
I'll be using the 996 front diff as well and 996 sized tyres.
Reason for not using the 996 engine? Money! They fetch silly money and have an achillies heel (intermediate shaft support bearing) which goes regularly and writes off the engine. I think a new engine from Porsche is now over £20K!! On top of that, the wiring and ECU etc involved is expensive. You have to go to Porsche to get everything coded up.
Stephane, thanks for that. I will do. These trips tend to be just hours of driving with very little time for breaks.
1989 S8 Bluestar
1990 Tristar |
Sebastian S Samba Member
Posted: Wed Feb 23, 2011 5:50 am Post subject: |
| SyncroGhia wrote: | | ThorAlex wrote: | | DJ with a cat? Never seen that before, do you know anything about it? Nice van BTW, and i love your projects! |
The cat will be removed asap as we don't need them over here. That should free up some hp |
Have you taken a closer look on that cat? I did the same assumption when I got my Doka (also with a DJ), thought it was a cat, but on closer inspection it turned out to be a second silencer which was a option for the T3 and would make sense on a Bluestar!
Nice bluestar! |
Posted: Wed Feb 23, 2011 5:57 am Post subject: |
Hi,
Yes it's a CAT, there's a receipt for 1400 DM for it in the file of stuff which came with the van.
1989 S8 Bluestar
1990 Tristar |
Posted: Fri Feb 25, 2011 11:15 am Post subject: |
I wish I could get this thing unloaded and start getting it ready for an MOT... but I've got other stuff on for the next 2 weeks
I managed to give it a wash today. Looking better for it!
I also had it running long enough to realise that we have a fuel leak and I think a coolant leak... then it ran out of fuel!
I have since removed the rear lights and put the stock ones back in. More photos when I have something more interesting to post
1989 S8 Bluestar
1990 Tristar |
r39o Samba Polizei
Posted: Fri Feb 25, 2011 11:32 am Post subject: |
The ABS is rare. You do not see it in the North American market versions. The rest of the options seem to be standard for what we would see in the US. I do not miss it.
Save the cat, put in an empty one. Works fine.
Not sure what else is different in the DJ, other than the compression ratio being higher than the MV.
It is easy to spot if you have the MV Digifant or the DJ Digijet installed by a quick lookie see.
Keep having fun.... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
1990 Multivan EJ 22 running well...
