ovalhobo Samba Member
Joined: January 25, 2010 Posts: 257 Location: Prince George, BC, Canada
Posted: Fri Feb 25, 2011 12:53 pm Post subject: Phosphoric acid at Home Depot in Canada? |
Hi.
I went to Home Depot (in Canada) and asked about phosphoric acid. They looked at me like I had two heads. They had no idea what I was talking about.
Would any of you happen to know the name brand of this product in Canada (and if it can be purchased at Home Depot in Canada). I do know about Rust Converter etc (which are available and I have used); however, these products tend to come in small containers, usually in spray cans, and are quote expensive. I'm looking for the larger containers.
Thanks so much for your help. _________________ 1956 pgsg bus
1954 oval
1955 oval
1960 beetle
1965 Canadian standard beetle |
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8206 Location: San Dimas
Posted: Fri Feb 25, 2011 1:05 pm Post subject: |
When i asked i got the same response...Its called "Prep and Etch" Gallon container for about $15 in USA. |
Posted: Fri Feb 25, 2011 1:07 pm Post subject: |
Thanks!
I wonder if they have that product in Canada. I'll check this weekend. _________________ 1956 pgsg bus
1954 oval
1955 oval
1960 beetle
Thrasher22 Samba Member
Joined: October 05, 2010 Posts: 858 Location: Calgary, Canada
Posted: Sat Feb 26, 2011 2:32 pm Post subject: |
I got the exact same response Let me know what you find, I still need to pick some up. |
Posted: Sun Feb 27, 2011 5:03 pm Post subject: |
Well, I went there today. I asked about Prep and Etch and Ospho. They had neither. Where else they might have this stuff in Canada? _________________ 1956 pgsg bus
1954 oval
1955 oval
1960 beetle
hpw Samba Member
Posted: Sun Feb 27, 2011 5:47 pm Post subject: |
ovalhobo wrote: |
Well, I went there today. I asked about Prep and Etch and Ospho. They had neither. Where else they might have this stuff in Canada? |
After a quick search on the Kleanstrip website, see if this helps.
http://www.wmbarr.com/kleanstrip/kleanstrip_wheretobuy.html |
Posted: Sun Feb 27, 2011 8:31 pm Post subject: |
Thanks. I'll ask for that product. I'll also check Wally Mart. I see that these products are available in USA nation wide, but I'm not so sure about Canada. I wonder if they'd ship this stuff over the boarder? _________________ 1956 pgsg bus
1954 oval
1955 oval
1960 beetle
TonysGarage Banned
Joined: December 11, 2010 Posts: 419 Location: Orange County, CA
Posted: Sun Feb 27, 2011 9:10 pm Post subject: |
the problem with asking people that work at home depot is...most of them are IDIOTS!
ive asked for phosphoric acid before and they had no idea what it is---they'll stock it in the paint department..near acetone, laquer thinner, etc...just read the bottle...dont ever ask someone that works there _________________ I dont take shortcuts, i put care and pride into all i do--for a fair price of course |
tspot100 Samba Member
Posted: Mon Feb 28, 2011 11:47 am Post subject: |
try tractor supply warehouse if you have them in canada. they stock gallons of "milk stone remover" guess what the main ingredient is???? phosphoric acid. highest percentage i have seen. cheap too, around 10$ per gallon. couldn;t find ospho locally ...i had to mail order a case... |
guy dagenais Samba Member
Joined: October 21, 2005 Posts: 154 Location: Montreal
Posted: Wed Mar 02, 2011 5:21 pm Post subject: |
Hi Ovalhobo
I live in Montreal and the product that you want is :
SURF-PRO Rust Buster and Primer (it's phosphoric acid).
I use it and it works well.
I've bought mine at Canadian Tire
This product is made in Ste-Julie, Québec (KOSMIC SURF PRO INC)
Guy
EV Carthago diesel |
engineerscott Samba Member
Posted: Fri Mar 04, 2011 9:39 pm Post subject: |
Another product that Home Depot carries (at least in the U.S.) is Ospho. In a 1 gallon concentrate bottle. It is phosphoric acid and surfactants and is used as a metal pre-treat prior to painting.
This is what you are looking for:
http://www.google.com/products/catalog?rls=ig&...EUQ8wIwAg# |
Posted: Sat Mar 05, 2011 10:55 am Post subject: |
I asked for Ospho at Home Depot. They looked in their computer and came up with nothing. I'm guessing they don't sell this in their Canadian stores? I will search Crappy Tire for Surf-Pro next. Thanks everyone! _________________ 1956 pgsg bus
1954 oval
1955 oval
1960 beetle
Posted: Mon Apr 18, 2011 10:55 am Post subject: |
Though I'd bump this for other stuck Canadians.
I picked up a bottle of stuff called Rust-mort at a local autobody supply in Calgary last weekend. Its 75% phosphoric acid and seems to do the trick...
Wasn't cheap, I paid $40ish for around 700ml. This shop tends to have pretty high prices normally though. |
Posted: Mon Apr 18, 2011 7:04 pm Post subject: |
Ayoye!
That's really expensive, I paid around 10$ for same amount at Canadian Tire for the other product (Rust Buster) |
Posted: Wed Apr 20, 2011 10:46 am Post subject: |
I didn't see that last time I was at Can tire... The horrible music they're usually playing at the one near my house usually means I'm in a huge rush to get out haha. I have to go buy more MIG wire tonight, so I'll take a look. |
chift Samba Member
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21474 Location: Oklahoma City
Posted: Wed Oct 05, 2016 9:02 am Post subject: Re: Phosphoric acid at Home Depot in Canada? |
Rust Check has less Phosphoric acid (listed as 15% to 30%....than Ospho which lists 45%.
But....Rust check also lists about 7% Tannic acid which is also the other chemical that does really well for converting. Some information notes that tannic acid converted rust...which is ferric tannate....may be a little more stable and rust resistant than those that use only phosphoric acid.
You should try some and let us know how it works.
Also....interestingly enough...I have noted that Jasco prep and primer is listed ...and appears to be so.,...about 2.5X stronger than Ospho.
In reality...its NOT a higher concentration.....its just more EFFICIENT.
Jasco lists 37.5% Phosphoric acid.
Ospho lists about 45% phosphoric acid.
However...the difference...is that Ospho is mainly water, a polymer solution somewhere in there and the phosphoric acid.
The Jasco and several other rust converters.....also have ethylene glycol monobutyl ether.....which is used as a wetting and flow agent to make the solution PENETRATE deeper into textures and microscopic fissures....and it has this in place of a lot of the water in Ospho.
Ray |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4893 Location: Southern AB
Posted: Wed Oct 12, 2016 4:17 pm Post subject: Re: Phosphoric acid at Home Depot in Canada? |
Thanks for losting that. I could not remember the name of that product.
Picklex 20 has very little phosphoric acid ...less than 10%.....but ai believe it uses Tannic acid and wetting agents....and is also d3signed to be a,very sloooow soak. I have heard good things about it....but its slow. Ray |
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Sat Nov 05, 2016 12:06 pm Post subject: Re: Phosphoric acid at Home Depot in Canada? |
Here's another one: 30% phosphoric acid: "Krud Kutter The Must For Rust Spray Gel Formula" its $12.99 for a 946ml bottle at Canadian Tire. Its apparently made by Rustoleum. Haven't tried it, and the instructions don't really say what to do with the surface after treatment, and befor painting .... _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
