67 Beetle aftermarket turn signal switch wiring
Page: Previous  1, 2
collin coburn
collin coburn is offline
PostPosted: Sun Nov 23, 2014 1:55 pm    Post subject: Reply with quote
so the new relay came so now it works,i think. when i press the button on the turn signal switch the high beams flash and then go back to low beams. how do they switch and stay on highbeams?
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Sun Nov 23, 2014 2:18 pm    Post subject: Reply with quote
You have the wrong relay.. or its connected wrong.
The one you have is a flash to pass relay... you need a true dimmer relay.
READ THIS and links within SAME PROBLEM. http://www.thesamba.com/vw/forum/viewtopic.php?t=609295&highlight=dimmer+relay
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
collin coburn
PostPosted: Mon Nov 24, 2014 12:54 am    Post subject: Reply with quote
so i checked out everything on the link you sent, all i found was that its for the flash to pass, with i could have it stay on high beams... oh well
Page: Previous  1, 2
Page 2 of 2
