ctroutma Samba Member
Joined: October 13, 2005 Posts: 158 Location: Atlanta, Ga
Posted: Sat Mar 05, 2011 11:57 am Post subject: Beginner Paint Job - Questions |
I am currently in the process of painting my 1965 Bus. I stripped it to bare metal and applied two coats of etching metal primer. Then I applied one coat of high build K-36 primer, but unfortunately don't have enough in the budget for a second coat.
My concern is how flat and how much coverage I need on the high build before I can apply the base coat. The primer has some texture to it, and I have wet sanded twice with 400 grit.
I'm trying to determine if I can apply the base coat as is, or if I should use the money to put a second primer coat and leave it that way till I have more money for base coat. Does the primer have to be flat and shiny? What are the surface requirements for applying the base coat? _________________ 1965 EZ Camper |
dawerks Samba Member
Posted: Sat Mar 05, 2011 1:27 pm Post subject: |
Put some water on the primer. The way it looks wet is how the paint will look AT it's best. If you are happy with it, you can go ahead and paint it. 400 grit is the surface requirement for basecoat unless it has metallic (then it's 600?)
But, that is the absolute best it will look. Paint is not going to hide anything, it will probably make things look worse
Buses are huge, props for taking it down to metal! And all that sanding, not so fun. _________________ "There is only one sin; disconnection from self." |
Posted: Sat Mar 05, 2011 1:30 pm Post subject: |
Definitely not fun, especially since I had to chemically strip and scrape off the mobile home roofing paint that had been painted on there. Looks pretty good, but still not sure yet. Thanks! _________________ 1965 EZ Camper |
schell '59 Samba Member
Posted: Sat Mar 05, 2011 1:42 pm Post subject: |
so true,it does suck!!! but the real shops earn their money and what your experiencing is what it takes and then some...
it ain't easy,though some shops pretend to be hero's it really separates the men from the boys for sure!
to get that old girl straight you have to fill and poly surfacer(the thick sprayable stuff) primer won't cut it.
buses and american muscle cars look like "wash" boards as the panels are relieved behind wit glues and bracing,sucking in the panel over the years...iwouldn't stress out to much as it'll come back later on in life if it just primed and colored...the poly and fillers will keep this look down for years,depends if your doing a shower or a driver...
get tid of all the "peel" in your primer coat,just before it shows burn through...you really should reprime but it's your call. ans yep 600 will be good for the adhesion on your base,put a tad slower reducer to if your temp is warm as it will help "bite" into the catalized primer...
good luck and toss in some pics of her!! _________________ WWW.401RESTOS.COM
see my "gallery" for more pics other than the website. |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Sat Mar 05, 2011 4:57 pm Post subject: |
Man that would suck for you to have done all the work, just to skip an important step over $80 worth of primer. I think that even if the primer is smooth, and I doubt it is, you will be happy with the low spots that are left. I would say even if you have to wait a couple weeks to save for more primer, save for it and do it right and you will be much happier in the end. I agree, if you are painting a solid color, 400 grit wet will be perfect to spray paint over. Before you spray the next round of primer, get your obvious low spots filled with some poly filler. Save for primer, put a couple more coats on, then spray a guide coat with some spray bomb and sand til its gone. |
spook Samba Member
Joined: December 30, 2003 Posts: 2038 Location: in the shop 35750
buguy Samba Member
Posted: Sat Mar 05, 2011 7:44 pm Post subject: |
Man those look like they suck to get straight! |
TonysGarage Banned
Joined: December 11, 2010 Posts: 419 Location: Orange County, CA
Posted: Sat Mar 05, 2011 10:04 pm Post subject: |
Buguy---you've never done a bus?
I have two at my house right now---they do suck to get straight. Especially since on one of them--the previous owner had 300 small dents--which he decided to put about 4" of bond across the whole side to fix---It took me forever to take down to metal! _________________ I dont take shortcuts, i put care and pride into all i do--for a fair price of course |
Posted: Sat Mar 05, 2011 10:31 pm Post subject: |
sob sob.
spook Samba Member
Posted: Sun Mar 06, 2011 5:19 am Post subject: |
buguy wrote: |
more billable than was charged
I had fun with that one tho,
the longblock was 5' long _________________ www.airkooledkustoms.com
SBS US #10
feedback on the shop : http://tinyurl.com/yc7jgkl
Welcome to he darkside, its lower here. |
buguy Samba Member
Posted: Sun Mar 06, 2011 9:42 am Post subject: |
No I havent ever done one. When I first moved to Florida I was here 4 days and got a job doing limos.....Im sure they are just as bad....maybe worse. Yeah those 5' longboards are hell on your arms huh??!! |
TonysGarage Banned
Posted: Sun Mar 06, 2011 11:01 am Post subject: |
im sure! although most limos that 'ive seen aren't dead on straight....but im sure if you made them straight that would suck! _________________ I dont take shortcuts, i put care and pride into all i do--for a fair price of course |
buguy Samba Member
Posted: Sun Mar 06, 2011 11:16 am Post subject: |
I was amazed and sickened at how the made those limos!! Unreal! But yeah i got em straight...not fun!!! But I got to work right across the street from the beach. Worked totally alone, and set my own hours! Pretty good gig. Plus he paid me a good hourly wage...in cash! |
Posted: Sun Mar 06, 2011 11:21 am Post subject: |
Mike Spadafora kicking it on his 56!! This photo is the only thing that keeps me going. I have not even laid the mud yet!!
But it turned out saweeeet!
TonysGarage Banned
Posted: Sun Mar 06, 2011 12:12 pm Post subject: |
damn hes really putting his shoulder into it!
yeah--its a lot of work--but done right...looks killer! _________________ I dont take shortcuts, i put care and pride into all i do--for a fair price of course |
buguy Samba Member
Posted: Sun Mar 06, 2011 3:16 pm Post subject: |
Looks like a good candidate for sprayable poly right there!! |
Matt K. Paint and Body Nutcase
Joined: January 14, 2005 Posts: 2598 Location: Hemet, So Cal.
Posted: Mon Mar 07, 2011 8:19 am Post subject: |
Definatly alot of work and patience........i think the hardest one i have worked on was a 60 Cad 2 door.......it feels like the quarters are 40 feet long and with the compound curves it make for a true challenge.....Props to anyone will to takle a large project like a bus. _________________ This is my 23rd year in the Auto Body/Paint Game!
*Take a look at some of my custom paint: http://s110.photobucket.com/albums/n119/mrpaint_2006/ .( NOTE: these are some older jobs but still neat.) |
Posted: Mon Mar 07, 2011 8:20 am Post subject: |
spook wrote: |
spend the extra $$ |
Damn Spook, that is probably the straightest Bay i have seen !! _________________ This is my 23rd year in the Auto Body/Paint Game!
TonysGarage Banned
Posted: Mon Mar 07, 2011 8:26 am Post subject: |
He can thank/curse that 5 footer for help with that. _________________ I dont take shortcuts, i put care and pride into all i do--for a fair price of course |
buguy Samba Member
Posted: Mon Mar 07, 2011 8:54 am Post subject: |
Ugh! I dont miss that shit at all. 10 swipes and your arms and shoulders are toast!! |
