Ozzaholic Samba Member
Joined: November 16, 2007 Posts: 210 Location: Bend, Oregon
Posted: Mon Mar 07, 2011 9:27 pm Post subject: Progressive Warm air intake fix |
A couple years ago I decided to go the progressive route, put everything together in Winter and immediately had troubles with icing.
After reading here and other sites I came up with a cookie tin fix that worked pretty well but was flimsy. It ran on the car for about 2 months with no troubles before the car died.
Now a year and a half later i got my new project with progressive going right during the coldest week of the year.
I read this thread, http://www.thesamba.com/vw/forum/viewtopic.php?t=386388&highlight=weber+progressive.
I changed my pre heat set up so one goes to the collector and came up with this hot air intake box to pre heat the carb air. I think this could be used on other carbs also.
A $22 electrical junction box, 2 heater tube rings, Heater tube.
Used the air cleaner bottom, and ring to mark the bottom of box and cut out.
Silliconed the air cleaner base to the box and bolted to carb. Don't forget to put in your air cleaner clips , I found 4 works best.
Welded one heat tube ring to the exhaust near the collector.
With the cold weather we are having lately I hope this helps someone.
In the warm weather I plan on disconnecting the hose from the collector and run it else where or just take the hose off.
So far with just a couple short drives it works great, my carb and manifold are warm to the touch when they used to be covered in frost. _________________ We have Desert in Oregon too
'68 Baja swing stock RIP cancer
'74 Baja IRS stock RIP Big rock, cancer
'71 Baja 002, raised current project |
joescoolcustoms Samba Member
Posted: Tue Mar 08, 2011 2:16 pm Post subject: |
Now that is thinking!
Nice job. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Tue Mar 08, 2011 3:09 pm Post subject: |
Thanks, I was looking into a tractor air cleaner and try to modify the same set up, but just the cleaner housing was $98 and then $30 for a filter.
I think this works just as well and fits better. _________________ We have Desert in Oregon too
2RL Samba Member
Posted: Tue Mar 08, 2011 7:09 pm Post subject: |
i like it. have you noticed any restriction/loss of power sucking air through a smaller intake like that? your box idea has me thinking of a similar idea for duals.... but for an entirely different reason. |
Posted: Tue Mar 08, 2011 7:22 pm Post subject: |
That is one thing I have been thinking about. I didn't have a problem last time I ran it but that was with a tired motor and I didn't really push it hard.
I will be testing that and see if there is a restriction. I'll run it with the lid off and see if there is any difference.
Worst case I run another hose to the other side of the collector.
So far the plastic box is rigid, I think it would sit on duals, and they come in different sizes.
Thanks for the input. _________________ We have Desert in Oregon too
dixon_cass Samba Member
Joined: December 14, 2010 Posts: 930 Location: Axtell Kansas
2RL Samba Member
Posted: Tue Mar 08, 2011 8:57 pm Post subject: |
i wonder if theres a way you could adapt a thermac (thermostatic air cleaner )setup from something like an older chevy or ford air cleaner to the box . the idea would be to just have the preheat active when you need it most, then it would switch itself over to cold air once things get up to temp.... it might work, but it'd take some trial and error for sure. heres some food for thought on the subject
http://arrc.epnet.com/autoapp/9110/9110CH04_Thermostatic_Air_Cleaner__THERM.htm |
Posted: Tue Mar 08, 2011 9:12 pm Post subject: |
To route to higher ground you could cut the hole on top or side with no problem, I thought about a snorkel set up also.
The box is strong enough that you could mount one of those units to it, That ran across my mind also.
From information I got from a respected source, I should be able to run it with the heat on till about 90 deg, which isn't till late Summer here. _________________ We have Desert in Oregon too
Posted: Wed Mar 09, 2011 6:37 am Post subject: |
I was thinking about a rubber flap to operate like a reed valve. At low air flow it stays shut pulling the warmer air in, but in wide open throttle a negative pressure inside the box would pull the flap open increasing the air flow to the air filter.
Or a manual choke wire operating a slider that the driver can pull open when performance is needed exposing an additional opening. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Wed Mar 09, 2011 8:59 am Post subject: |
Both excellent ideas, I think I will experiment with the rubber flap idea.
Got a sick boy at home so I can't experiment yet, maybe this weekend.
Thanks for the ideas. _________________ We have Desert in Oregon too
Posted: Mon Mar 21, 2011 9:40 am Post subject: |
I was finally able to get out and play this weekend. Took a nice high speed 45 mile gravel road loop.
YES there is restriction.
I didn't notice it in town, but on the way home there are a lot of long straight stretches.
I took the top off the box and did notice some acceleration gain, and gained 5 MPH all out.
So I immediately started to implement one of Joescoolcustoms ideas I had been thinking about.
Here's what I came up with.
The tube hole is 2", the new relief hole is 1 1/2". The carb intakes are both 1 1/2".
I used a piece of truck tube and it just lays there for now, I will see how it works and if I need to rivet the other side down.
I have a remote camera I am thinking about mounting either inside or underneath the box to watch how this works, We'll see how ambitious I get. _________________ We have Desert in Oregon too
veeweeman Samba Member
Joined: December 20, 2009 Posts: 940 Location: New Port Richey, FL
Posted: Mon Mar 21, 2011 3:44 pm Post subject: |
That's a pretty sweet setup...it's good to see some ingenuity using modern day products...do you have factory heat riser tubes hooked up?
VeeWee |
Posted: Mon Mar 21, 2011 4:02 pm Post subject: |
Thanks. I have the heat riser attached on the one side (R), and the other goes into the collector.
It draws the exhaust through better. I have a cheap manifold. _________________ We have Desert in Oregon too
twomonkeysayoyo Samba Member
Joined: November 17, 2009 Posts: 651 Location: Carrollton, GA
Posted: Tue Mar 22, 2011 5:59 am Post subject: |
Okay, school me on this:
I thought you wanted cold air (high density) on the intake, and to keep it gaseous on it's way through the manifold. With this setup aren't you just pumping in hot air (less dense) as a workaround for the long manifold length instead of using manifold heat to keep cold air/fuel mix just this side of liquid? _________________ ---
Looks like trouble. |
Posted: Tue Mar 22, 2011 11:11 am Post subject: |
I am by no means an expert, I am experimenting with ideas I have picked up from reading this and other forums, and limited experiences with the progressive.
That being said, Here is what I have learned, Please add to or correct me if I'm wrong.
This article [/url]http://www.thesamba.com/vw/forum/viewtopic.php?t=386388&highlight=weber+progressive.[url] confirmed a lot of what I had thought and found through trial and error.
This seams to be more of a problem with the progressive, but I have seen it on other carbs, although eventually the pre heat is enough to melt it off.
Most cars use pre heat that is routed through a thermostat that opens to cool air when the engine is warmed up. They are also surrounded by metal and insulation, so when the thermostat opens to cool air, most of the components around it in the engine compartment are warm and getting warmer, so it is still drawing warm air to a degree, specially on hot days.
On a Baja the engine is surrounded by cold air and with the progressives amount of fuel air flow, along with the thick aluminum intake and long run, It needs a lot of warm air to keep the fuel suspended.
With out the pre heat the fuel puddles up and runs into the cylinders.
Some manifolds have the pre heat go up to the base of the carb, the cheap ones (like mine) don't.
The stock manifold pre heat doesn't work properly with after market exhaust. Instead of flowing through and heating it pulses back and forth doing nothing really. To fix this run one pre heat tube to the collector of the exhaust this draws the exhaust through and heats the manifold really well.
But as thick as the progressives manifold is the pre heat doesn't warm the top, and the cold air/ fuel takes over causing icing.
That's where the warm air intake comes in. The warm air heats the carb and top of manifold and warms the fuel making it easier to suspend in the air mix.
With the whole intake warm the fuel stays suspended and doesn't cling and puddle in the manifold.
I have read in a post a concern about too much hot air causing detonation and over heating problems. I can believe that in a hot climate ( you probably aren't reading this, or think I'm nuts). But when you think about that hot engine surrounded by hot insulation on 110* day, how hot is too hot?, and all I have to do is disconnect the hot air tube.
Also on the air density, I live and drive at 4500' and above, so that might help me, I'm not sure. I thought that is what the jets and air correctors were for, but as I said I'm no expert.
Long winded but I hope it helps, someone _________________ We have Desert in Oregon too
Posted: Tue Mar 22, 2011 11:43 am Post subject: |
twomonkeysayoyo wrote: |
I thought you wanted cold air (high density) on the intake, and to keep it gaseous on it's way through the manifold. With this setup aren't you just pumping in hot air (less dense) as a workaround for the long manifold length instead of using manifold heat to keep cold air/fuel mix just this side of liquid? |
The cold, dense air does make more power. In drag racing, people will actually lay ice on the intake runners to cool them before making a pass and help get that more dense charge in the cylinders. Some intakes are cast with the intakes isolated from the lifter galleys to reduce heat transfer and keep the charge cooler. It does make a difference. Cars will run 0.010 seconds quicker in the 1/8 mile with a cooler intake charge. If the complete incoming air is channeled to be just the outside air directed to a carb that is sealed from under hood air, it can pick up 0.100 seconds on the 1/8 mile drag strip. I have tested this to be fact, not conjecture. But this is with engines pushing 500 and up horsepower.
Now, I am guessing the average guy on a gravel road with the foot flat on the floor would not notice any difference in the performance lost on a 60 horsepower engine by not having the carb inlet isolated to cool air only.
Having driven a 1915 cc engine to college for 6 years with a center mount progressive carb that had the "Good" exhaust/intake heat and it still icing in the winter, this warm air box could have made an inprovement in the drivabality in my car.
Keep on trying and reporting back to us! _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Tue Mar 22, 2011 5:14 pm Post subject: |
You know another mod you can try I just thought of would be to tap into your oil supply and run some rubber hose around the intake and through a oil cooler...this could actually serve well, it could keep your intake from icing up in the winter and if you installed a bypass valve you can just shut it off in the summer...so the oil would run from the engine, wrap around the intake to keep it warm and return to the engine or run it through a cooler...then in the summer warmer weather just detour the oil flow from the engine, through a cooler and back to the engine...just a though I just came up with...I still like your intake box ideal a lot...here where I live we get a lot of sand dust storms and our filters get dirty really fast...your box ideal would cut down on the direct contact to the air filter.
VeeWee |
Posted: Thu Mar 24, 2011 10:22 am Post subject: |
I had thought about wrapping the manifold with a copper tube and run the oil through, but then I read about the reaction with Copper and oil, and the limited space around the manifold ruled that out.
I have found a few people that run oil through the preheat on the manifold.
I would think about that with a newer manifold or one you cleaned out really well. It would be my luck a giant carbon plug would break loose and cause problems.
With my first box made of a metal, the whole idea was for the pre heat. I was trying this time to use a remote filter box like a tractor and incorporate the hot air, the cost of the tractor box was way too much, and had no place to mount close enough.
Then while walking thru Home Depot I found this box and it all clicked.
It protects the air cleaner very well. I have been out and had so much mud on the air cleaner it wouldn't run, not a problem with this set up _________________ We have Desert in Oregon too
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5411 Location: Holland, MI
Posted: Mon Oct 27, 2014 2:56 am Post subject: |
Thread back from the dead.
I was cruising youtube and came across this video which reminded me of this old thread. The first 45 seconds or so shows how this guy hooked is weber progressive to the busses factory air cleaner for preheat. For those of you who don't care for oil bath air cleaners you can substitute a paper or cotton/gauze filter. This mod has been done here on TheSamba to this exact air cleaner. You could easily rig something up like this for progressive carbs.
_________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2663 Location: West Coast (Michigan's)
