donmanolo Samba Member
Joined: December 24, 2010 Posts: 5 Location: Trieste, Italy
Posted: Sun Mar 13, 2011 3:02 pm Post subject: Noob's first post, Fuel pump base stuck inside case.... |
Hello to everyone here, I know it's usually bad form to appear on a forum and ask for help in your first ever post, but please be gentle on me..!
I just brought home my 1974 Yugo-beetle, a 1200J model, built in the volkswagen plant in Sarajevo.( I live in north Italy) and I drove it across north Croatia, and Slovenia before getting home, now I'm fixing up a few minor things while I wait to get an Italian number plate.
Here's the problem I'm having: Basically what happened is that the bottom tip of the fuel pump base has broken off inside the case. The thing must have been 37 years old, as the bakelite is really hard and crumbly.
I just wanted to get any opinions on how to proceed, I've left the thing there for another day while I think about it in Pirsig motorcycle maintenance Gumption trap fashion, (actually my motorcycle is also German, is also an Airhead and is also quirky).
I'm thinking of getting a dremel with a grinding stone attachment and just pulverize the bit left inside, then maybe grind down the new base so at least it'll fit.
Obviously an oil change and filter clean will follow, I'm assuming that this should flush out all the powder.
I'm just worried about what would happen if it doesn't flush out, and if it can cause damage if it finished up where it shouldn't, and maybe somewhere where it could melt while it's there......I'm pretty worried...
I should add that the broken bit is stuck clean inside the case, doesn't even move and is impossible to pry out.
I hope my description is understandable, Thanks for any help and suggestions.
Greetings from Italy,
Manolo |
busdaddy Samba Member
Posted: Sun Mar 13, 2011 3:22 pm Post subject: |
Welcome,
I'm not sure grinding is the answer, personally I'd find a large screw or lag bolt to screw into it, once it's screwed in securely I'd start shooting it with carb cleaner to dissolve the varnish that's causing it to bind. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Sun Mar 13, 2011 3:28 pm Post subject: |
busdaddy wrote: |
Welcome,
I'm not sure grinding is the answer, personally I'd find a large screw or lag bolt to screw into it, once it's screwed in securely I'd start shooting it with carb cleaner to dissolve the varnish that's causing it to bind. |
Great idea - and use a small slide hammer to help persuade it out. If it doesn't start coming out right away then tap down on it to help break it loose. _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
JerryMCarter1 Samba Member
Joined: January 07, 2007 Posts: 6199 Location: N.W. Phoenix
Posted: Sun Mar 13, 2011 4:04 pm Post subject: |
Here's the problem I'm having: Basically what happened is that the bottom tip of the fuel pump base has broken off inside the case. The thing must have been 37 years old, as the bakelite is really hard and crumbly.""
Usually if something drops into the oil case -- nothing happens -- It will finally wash into the oil filter base -- no problem
I am thinking you are talking about a spacer between the case and the base of the fuel pump?
If so your leaking oil ? Correct?
You will have to replace that part |
Posted: Mon Mar 14, 2011 1:57 am Post subject: |
Thanks for that, for now I've sprayed it in brake cleaner and left it for tomorrow. I think that I'll tap a thread into it , screw something in then try to extract it that way.
I'm worried because of powder and bits of bakelite that fell into the engine, however I hope that flushing out the oil will get rid of most of the debris.
I'll be back with a whole lot of dumb questions, after I fix this, the brakes are next!
Wishing everyone a great week. |
osborns Samba Member
Joined: February 28, 2010 Posts: 48 Location: Niceville, FL
Posted: Mon Mar 14, 2011 2:33 am Post subject: |
Quote: |
I think that I'll tap a thread into it , screw something in then try to extract it that way. |
It's worth a try, but I think that would make it expand and be even tighter. I'm pretty interested in the outcome, though, because I have an engine sitting around with the same problem. |
Mygfsbug Samba Member
Posted: Mon Mar 14, 2011 1:05 pm Post subject: |
osborns wrote: |
So do I Let us know what happens. |
Willhelm Samba Member
Posted: Mon Mar 14, 2011 4:52 pm Post subject: |
If he actually taps it before screwing a bolt (or stud) into it, expansion is a non-issue. Be sure the hole is correct for the tap size! Good luck! |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Mon Mar 14, 2011 5:11 pm Post subject: |
Had the same thing happen to me -
used the tap - and it came out like a charm.
I did take the shop-vac with a 1/4" hose adapter - to vacuum the remnant as thoroughly as possible.
good luck _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
Posted: Tue Mar 15, 2011 4:25 pm Post subject: |
Just an update.....
Thread tapping resulted in bakelite crumbs falling into the motor, and what's left is totally glued to the part just above the fuel pump cam inside the block.
I don't see any alternative now apart from filing it all down somehow so a new fuel pump flange will fit.
Now I really need to know what bad effects the crumbs might have on the motor, and if they can be flushed out somehow using diesel fuel ...
This is such a stupid thing to happen, and I've no idea what to do...
thanks for any help, and thanks for all the suggestions I received up til now.
Antonio |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Tue Mar 15, 2011 5:42 pm Post subject: |
I had this happen on mine. I couldn't remove mine with a tap either. I ended up chiseling the old base out, to pieces, with a screwdriver and hammer, then retrieved any plastic pieces out the bottom screen. Did a second oil change after 50 more miles, no issues. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
NYVWGuy Samba Member
Joined: February 09, 2011 Posts: 26 Location: Staten Island New York
Posted: Tue Mar 15, 2011 11:40 pm Post subject: |
My 74 has the same problem. Glad to hear all of these suggestions and that im not the only one this has happened to. Good stuff! I may try this out tomorrow and post the results. |
Posted: Wed Mar 16, 2011 9:56 am Post subject: |
Cusser wrote: |
I had this happen on mine. I couldn't remove mine with a tap either. I ended up chiseling the old base out, to pieces, with a screwdriver and hammer, then retrieved any plastic pieces out the bottom screen. Did a second oil change after 50 more miles, no issues. |
Thanks Cusser, that sort of puts my mind at rest, since it's what I'm going to have to do tonight when I get home.
To everyone else, I should offer a quick apology, I only just found out that this piece is called a "flange" in English, which is why I didn't see that there were already some topics about this on the forum, sorry for not searching properly before posting.
Incidentally, for those who speak french, the best solution I've found is here at this link: http://www.old-droppers.com/index.php?showtopic=22738 |
