mattt Samba Member
Posted: Fri Jul 20, 2012 10:40 pm Post subject: |
saddlesore1 wrote: |
Had a couple of folks ask about interior color so I took some over head shots.
I am running a satin Black with Bed Armor on the pan. I love it. Never lost anything in the darkness and it holds up well. My only complaints are it use to hold water like a bath tub until I drilled drain holes and when it gets muddy or dusty(offroading) it take a deck brush and soap to get out of the nooks and cranies.
On another note. The rear fenders (2" wider and 2" Taller) are in the mold shop. They are better than anything else you have ever seen.
1. they bolt in stock locations. No need to drill into the side of the body to mount.
2. They are ready to paint. Not like others where the original mold has voids in it and leave blemished in the glass. I will update when I get them.
Those rear fenders sound familiar....kinda like something on my Thing |
mattt Samba Member
Posted: Fri Jul 20, 2012 10:49 pm Post subject: |
I had to dig far back in the cave to find these pics....this is pre-paint job, circa 2004
before...stock steel
after....fiberglass
mattt Samba Member
Posted: Fri Jul 20, 2012 10:50 pm Post subject: |
BTW....that green will look bad @$$. Excellent job on the build Saddlesore |
ThingOw181 Samba Member
Posted: Sun Jul 22, 2012 9:57 pm Post subject: |
Definitely post up when those rear fenders become available. I have some wide ones I planned to chop up, but I like that look better.
On a side note- do you think your fiberglass guy would do a full front clip? I have one to make molds from. I've gotten leads on a few other possible fiberglass shops, I'll be stateside in a couple of months and plan on visiting a few.
Thanks! |
saddlesore1 Samba Member
Posted: Fri Nov 02, 2012 8:29 am Post subject: |
Pulled last post down. I forgot to pull my license plate number off. Just in case
Sorry for the premature post but excited about progress. Should be done today or over the weekend.
1. New exhaust. I took Kymcos Thing exhaust. Higher and tighter and made it higher to fill the gape from body lift. It also gave more room for the skid plate.
2. Installed new muffler. Removed the spark arrestor and installed muffler. Mammas happier
3. Custom tube bumper with skid Plate.
4. Tubular side bars to help Mamma and kiddies get into. With it sitting almost 3 1/2 feet off the ground they have trouble swinging their leg in and out.
5. New prototye rear fenders (not show). 2" wider and 2" taller mounting (no Cutting or drilling) in stock location. matching the fronts. All I can say is they are awesome.
Posted: Fri Nov 02, 2012 8:33 am Post subject: |
ThingOw181 wrote: |
Thanks! |
My car was in the glass shop for almost a full year to make a complete mold to mount on a tube chassis. My car is straight and ready to paint. Problem is these cars are so crooked that after Glass was done it looked like S&#t. He said it would have taken hundreds of hours to fill and fix then remold to make right. Then cost prohibitive. |
euromog Samba Member
Posted: Sat Nov 03, 2012 8:51 am Post subject: |
When the supply of affordable restorable bodies dries up someone will start making glass bodies. They will be at least $5k to $6k though. Not a bad price for an already painted gelcoat bolt on body. Then all you need is a pan with some Ghia pans and you are ready to go.
ThingOw181 wrote: |
Thanks! |
Posted: Tue Nov 06, 2012 4:08 pm Post subject: |
New muffler painted and ready for bumper
Posted: Tue Nov 06, 2012 4:11 pm Post subject: |
New Bumper
New Fender Wider/Taller Front View
New Fender Wider/Taller rear View
New Side Bars
Posted: Wed Nov 07, 2012 4:03 am Post subject: |
So he did end up making some molds?
I was looking at buying a new drivers side front panel and the front... apron I guess it is... from the Thing Shop and then making molds off of new OEM metal. The only hitch is the passenger side is no longer available.
I wonder if working with pieces rather than a whole unit would work easier.
Car is looking awesome! |
Posted: Wed Nov 07, 2012 8:32 am Post subject: |
I cant remember if he completed the entire front end or pieces. Molds where made. I don't know to what degree. I do know it got expensive. Pieces would be better, but adding the sum of the parts to have a straight car is another issue |
locky Samba Member
Joined: May 08, 2008 Posts: 573 Location: Nelson, British Columbia
Posted: Thu Nov 08, 2012 8:45 am Post subject: |
Saddle, that is looking great. How does the muffler sound? Get a full car shot up here. Nice nice nice!!! |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
mattt Samba Member
Posted: Fri Nov 09, 2012 11:21 am Post subject: |
Right on....looks like it's coming together sweet! |
Posted: Wed Nov 14, 2012 5:10 pm Post subject: |
here ya go Locky. Sounds so much better. Can talk to passenger without yelling. I kept the Basanni style muffler for quick change out at the dessert.
Im going to lower the front about an 1" or 2" for better weight distribution.
Thank everyone for the nice comments. If your looking for new rear fenders check them out in the for sale. They are very sweet.
At the end of winter (desert time) I will pull it all down and paint body.
Mountain man Samba Member
Joined: February 19, 2011 Posts: 37 Location: Sevierville, Tennessee
Posted: Thu Nov 15, 2012 6:03 pm Post subject: Fenders |
Awesome look . I am trying to do the same thing with a suspension lift and fiberglass fenders. Two questions: how did you mount the headlight buckets and what kind are they? and, third question, how much are the rear fenders? I bought some rears at So Cal but they don't fit and have to be mounted on the exterior of the body. I don't want to drill holes in the side of the car and they are so warped even beading won't match them to the body.
thanks. |
Posted: Thu Nov 15, 2012 8:53 pm Post subject: |
The front fenders are precut for the empi headlights. They are the shallow plastic bucket and bolt to the fender from the inside.
Look in the classified for the front and rear fenders. 2" taller and 2" wider. They bolt to stock location and contoured to the body no beading required. I have see the other fenders out there and they are junk. Full of pits, flimsy and crooked as heck. |
Posted: Thu Nov 29, 2012 5:02 pm Post subject: |
My son and I had a friend with a new buggy join us on a ride up to the top of Saddleback Mountain via maple Springs road last weekend. The ride up took approx. 45min. The top is 5700 ft. What a view. The Thing drove great.
Here is part of the video. I wish I knew how you guy embed them into you posts. I hope to have the other 2 videos posted soon. This whole editing thing is new to me.
That is all 4 videos enjoy
Last edited by saddlesore1 on Fri Nov 30, 2012 10:14 am; edited 2 times in total |
Hellnbak Samba Member
Joined: September 16, 2012 Posts: 84 Location: Michigan
Posted: Thu Nov 29, 2012 5:25 pm Post subject: |
Nice car, and nice videos. Looks like you guys were having fun. Unfortunately I have a real problem with heights, and that drop-off a few inches to your right looks like it could ruin your day real quick. Anybody ever end up at the bottom of that valley? |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Thu Nov 29, 2012 5:36 pm Post subject: |
(original video fixed, removing off-topic comment - can't delete a replied-to post) _________________ VW-181 shirts and stickers.
http://ian.epperson.com/vw
