post your pics of how u mounted your tachometers
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
turboedbug
turboedbug is offline
PostPosted: Fri Apr 01, 2011 5:25 pm    Post subject: post your pics of how u mounted your tachometers Reply with quote
how u mounted your tachometers, trying to get ideas of what looks good
1969 type 1 rolling subie power
ej20k w/vf-22 roller bearing turbo
ems stinger 4424 engine management
wide 5 discs
soon to be subaru 5 speed! Got the reversed gears just need to find time to install
View user's profile Send private message Send e-mail MSN Messenger Classifieds Feedback
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Apr 01, 2011 5:28 pm    Post subject: Reply with quote
To the left of the speedo.
Glenn
iRide4Sue.org Please Donate to fight Cancer. $25,000 raised in 2016, hoping for the same in 2017
turboedbug
PostPosted: Fri Apr 01, 2011 5:34 pm    Post subject: Reply with quote
thanks for the pic. maybe I shouldnt of been so vague, I am planning on tossing in a 5 inch tach. the location on the left is definently a no go thats where my oil, temp, and vac/boost is located. any other nice options? how about a bracket for easy install. Thanks again TurboedBug
wide 5 discs
Mr. 010
Glenn is offline
PostPosted: Fri Apr 01, 2011 5:36 pm    Post subject: Reply with quote
Some are mounted under the dash, on a pod off the steering column and in a cup above the radio.
Try searching the gallery.
Glenn
turboedbug
PostPosted: Fri Apr 01, 2011 5:38 pm    Post subject: Reply with quote
Thanks again glenn, off to the gallery
wide 5 discs
QRP
QRP is offline
PostPosted: Fri Apr 01, 2011 5:50 pm    Post subject: Reply with quote
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Fri Apr 01, 2011 5:53 pm    Post subject: Reply with quote
to the right of the speedometer:
póg mo thóin
Certified DHS Technician
Samba Member # 24517
Max Welton
Max Welton is offline
PostPosted: Fri Apr 01, 2011 6:04 pm    Post subject: Reply with quote
Cool
Max
"Someone" told him it was true. That should be good enough for anybody.
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Fri Apr 01, 2011 8:28 pm    Post subject: Reply with quote
I have MS, but I don't drive around like THAT all the time! Laughing
No sir only gauge I have is the speedo, and that's currently got a stripped cable spline so it's disconnected.
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
turboedbug
PostPosted: Fri Apr 01, 2011 9:12 pm    Post subject: Reply with quote
good call I should sell my tach and the other gauges. make a laptop mount and go that route using the software for my ecu
wide 5 discs
dmilla
dmilla is offline
PostPosted: Sat Apr 02, 2011 8:25 am    Post subject: Reply with quote
Experience is recognizing a mistake when you make it again...
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Apr 02, 2011 8:34 am    Post subject: Reply with quote
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
turboedbug
PostPosted: Sat Apr 02, 2011 7:24 pm    Post subject: Reply with quote
@ hotrodvw where did you get that bracket? I think that looks great
wide 5 discs
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Apr 02, 2011 10:54 pm    Post subject: Reply with quote
Fast-Fab!
'67 Sunroof
Eric
lots of money!
Hose & Fittings
jfats808
jfats808 is offline
PostPosted: Sat Apr 02, 2011 11:04 pm    Post subject: Reply with quote
Got mine too Hotrod!
MURZI
MURZI is offline
PostPosted: Sun Apr 03, 2011 3:04 pm    Post subject: Reply with quote
62 vert
Cusser
Cusser is offline
PostPosted: Sun Apr 03, 2011 5:05 pm    Post subject: Reply with quote
Since 1976:
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2005 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
Rome
Rome is offline
PostPosted: Sun Apr 03, 2011 7:39 pm    Post subject: Reply with quote
Posting photos in my response has never worked for me, even following the Samba instructions to the letter. Here are two possibilities from my own Beetles:
[img]http://images.thesamba.com/vw/gallery/pix/189173.jpg[/img]
The tach is from a Porsche 914, which has the same diameter as the Beetle speedo. This method requires cutting out the factory speedo opening, relocating it to the left, and welding in a new speedo pod to the right from another car for the 914 tach.
[img]http://images.thesamba.com/vw/gallery/pix/183195.jpg[/img]
Another 914 tach, this time in a RadioShack "project box" under the dash. Disadvantage is that it's out of your direct line of sight.
fredy a
fredy a is offline
PostPosted: Sun Apr 03, 2011 9:52 pm    Post subject: Reply with quote
my test
sorry for the spelling
W1K1
W1K1 is offline
PostPosted: Mon Apr 04, 2011 6:00 am    Post subject: Reply with quote
3.3/4" mini monster tach
Mine mounts with a plate sandwiched under the mirror
Hers uses a plate that screws in under the the visor mount screws
it works well because it's always in your peripheral, and you can't see it from outside.
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
