Oil Light Problem- *UPDATE*
PatterBon
Samba Engine Connoisseur
PatterBon is offline
PostPosted: Mon Apr 04, 2011 7:31 pm    Post subject: Oil Light Problem- *UPDATE* Reply with quote
Hey guys,
As most of you know, a little over a year ago I rebuilt my engine and have been taking good care of it ever since. But within these past 2 week, while going to my girlfrieds, my oil pressure light has started to flicker at idle. Her house is only a 15 mile trip away from mine but it's all highway driving. I know that the official VW manual says that after the engine warms up after a bit its normal to see the light flicker. But being cautious, I read up on oil and changed my oil for straigh 30w to 10w-40 to try and increase case pressue.
I started feeling better after driving to her house a few days ago after the oil change and the light stayed off..I figured I had fixed the problem.
But today, after going on a 24 mile trip, the light came on and would stay on at idle, it wouldn't flicker it was just on. The second I started to go again, it would go off..But still it is a point of concern..I have just over 10,000 miles on the engine and don't drive it rough at all so I hope its just a switch issue and not the bearings Shocked
So I just want a second opinion from you guys..I'm thinking its the oil pressure switch because I don't abuse my engine and I change the oil constantly. What do you guys think?
Thanks fellas!
PNW Dub Folk & Kitsap dub Folk (KdF)
1973 Standard VW Beetle
1969 Cessna 172K Airplane
US Army CH-47 Chinook Helicopter Repairer
69 Jim
69 Jim is offline
PostPosted: Mon Apr 04, 2011 7:35 pm    Post subject: Reply with quote
What are the rpm's at idle?
PatterBon
PostPosted: Mon Apr 04, 2011 7:41 pm    Post subject: Reply with quote
I set them to 900, so its right around where it should be. Not to low and not to high I don't think, I'll take a video and we can listen by ear. But the closest access that I have to a tach is 36 miles away and when he's open I'm at school or work. But I'd say 900.
PatterBon
PostPosted: Mon Apr 04, 2011 9:05 pm    Post subject: Reply with quote
Also, the light went off after some "smoother" driving at lower speeds..it only does it while highway driving..
vw_hank
vw_hank is offline
PostPosted: Mon Apr 04, 2011 9:51 pm    Post subject: Reply with quote
Hay are you on the olydubs site, or bugswest?? I know there are guys in you neighborhood that have A tack.. When your oil light comes on reeve the motor up A little(just A little) vroom,vroom,vroom,, if the light wount go off Stop driving it..
1302s sunroof..
TimsACVW 1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods!
Big thanks to my friends Jes67 & Keoki
Paul Windisch
Paul Windisch is offline
PostPosted: Tue Apr 05, 2011 6:15 am    Post subject: Reply with quote
Try to get the oil light to flicker and come on then install an oil pressure gauge to see what the actual oil pressure is. You may have a pressure switch going bad. Certainly you are in tune now to how the engine is supposed to sound, so if you don't hear any unusaul noises, my bet is on the switch going bad. Check it out before you assume, though.
*ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6 (the loser cruiser)
Heidebreicht Chevrolet
http://www.heidebreicht.com/HomePage
Scott Gray
Scott Gray is offline
PostPosted: Tue Apr 05, 2011 8:12 am    Post subject: Reply with quote
Mine does the same thing.I put in a new switch and it still does it.It's a single port out of a 67 that I put a new top end on.It runs perfect and has no endplay.If I set the idle to 1000 it won't come on.I've put about 5000 miles on it since the rebuild and it's done it since day one.I'm going to check my oil relief spring and piston on my next oil change.
Someone one on here says that theirs has come on at idle since 1973. Laughing
Paul Windisch
PostPosted: Tue Apr 05, 2011 9:38 am    Post subject: Reply with quote
A flicker at idle when hot is ok, but Patterbon said at one point it came on solid while he was reving it, that's no good and needs to be sorted out.
EDIT: I mis-read. It did not stay on while reving / driving. Either way, make sure the actual oil pressure is within spec and proceed from there.
1984 Mexican Beetle
PatterBon
PostPosted: Tue Apr 05, 2011 2:58 pm    Post subject: Reply with quote
Wilco, I'm trying to get my hands on a pressure switch, to and from school it does just fine and the engine runs like a champ, takes hills really well, the whole 9 yard..But I can't express my concern about having the engine in top shape..I don't want to do rebuild #5..John Morris suggested pressure switch, releif plugs, and oil pump..but he's a good 45 minute highway drive from here and I'd rather not risk it..If you know what I mean..
djkeev
djkeev is offline
PostPosted: Tue Apr 05, 2011 3:07 pm    Post subject: Reply with quote
Easiest thing to do is spend $5 and get a new oil pressure sender switch and screw it in. As already suggested, yours may be going bad.
Your OReilly auto parts store has one in stock. $7.99
http://www.oreillyauto.com/site/c/detail/BWD0/S402...;ppt=C0039
After a new switch is installed and the light still comes on, get a gauge and see what pressures you are really running.
Dave
86 Vanagon Westy "Weekender" 2.1 Auto
Karmann Ghia
PatterBon
PostPosted: Tue Apr 05, 2011 3:17 pm    Post subject: Reply with quote
Will do, I'll go do that tomorrow after school..Thanks guys..I'll report back and let you all know..Dave, is there any way to tell if the old switch is bad once its out? Or should I just take the beetle on a drive and see how she does?
19super73
Hardcore Stock Nazi
19super73 is offline
PostPosted: Tue Apr 05, 2011 3:23 pm    Post subject: Reply with quote
It sounds like your Beetle is jealous of you going to your girlfriend's place Laughing
The pressure switch sounds like it's going bad. They aren't that expensive and at today's gas prices it's cheaper than driving to where you can get access to a tach.
1970 Campmobile
1970 Fastback 1600 TL
1971 Doka
1973 Super Beetle
1973 Westfalia
1974 412 Variant
1975 La Grande Bug
VWCOOL wrote:
The later Supers -Grab one now while all the Gen-Y fashion victims, who wear beards and beanies in summer, are still saying 'Yah, shed find, brah' a lot and pontificating about patina and stance with the pre-70 models Rolling Eyes
djkeev
djkeev is offline
PostPosted: Tue Apr 05, 2011 3:46 pm    Post subject: Reply with quote
Not really any way to check. The spring inside goes bad, the seals leak, etc. Keep in mind that even new ones have been known to be bad. Shocked most often they are fine but on occasion.........
Careful when you install the new one, don't overtighten, it is a taper thread.
Dave
Karmann Ghia
fred69vert
Location: Home of the US Navy Atlantic Fleet, Norfolk, VA
fred69vert is offline
PostPosted: Tue Apr 05, 2011 4:03 pm    Post subject: Reply with quote
I figure (especially after reading the oils sticky) that the ACVW engine runs hotter than H2O cooled gas engines. And diesels run hotter. So putting 2 and 2 together, I switched to Shell Rotella 15W-40 diesel engine oil.
I'm not losing my hair, it's just retired and relocating further south.
1969 VW convertible, "Heidi"
marklee
Location: Barnston, Wirral, back in the cold wet UK.......
marklee is offline
PostPosted: Tue Apr 05, 2011 4:06 pm    Post subject: Reply with quote
Just a thought, what oil are you using, when was it last changed etc, the new modern thin 0w/10 oils and other synthetic oils for modern engines arent really suitable for a VW air coole lump.Try a 20w/50, worked for me with similar issues in my Vanagon. Sorry if Im teaching granny to suck eggs but a good quality mineral or maybe semi synthetic oil and frequent changes is in my opinion best for a VW Air cooled car, the others get too thin and can cause this issue and leaks. A friend had an old 911 Porsche, complained to me of smoky start ups and oil light flicker at idle when hot. The correct oil cured the problem.
Hope this helps, Mark
CGLI qualified body repair and refinish tech
CGLI qualified motor repair tech
Qualified automotive Glass installer
Motor Insurance Repair and Research Centre,Thatcham, Advanced Vehicle Damage Estimator.
Police qualified vehicle examiner
Police Class 1 High performance, pursuit trained Advanced driver
dan macmillan
dan macmillan is offline
PostPosted: Tue Apr 05, 2011 4:43 pm    Post subject: Reply with quote
From the OP's first post,
He mentioned that it was done within the past 2 weeks.
Licensed Automotive Service Technician
Licensed Truck and Coach Technician
Licensed Heavy Duty Equipment Technician
CFC/HCFC/HFC A/C handling and installation license
Alignment specialist
66 Modified Manx,68 Kyote,74 Thing,74 Beetle, 76 Transporter,75 self made Double Cab,65 Meyers Manx,78Westy,68 Ghia, 79 Bradley GT2
Current projects:
Built for others:69 Manx Clone
dasdachshund
dasdachshund is offline
PostPosted: Tue Apr 05, 2011 5:47 pm    Post subject: Reply with quote
marklee wrote:
.....Try a 20w/50, worked for me with similar issues in my Vanagon..........
Yep, that's an old water cooled VW trick. Worked for me also, on a 1985 Cabriolet.
I say do the 20w-50 oil trick. Bet it cures it. Cool
-dasdachshund
Semper_Dad
Semper_Dad is offline
PostPosted: Tue Apr 05, 2011 10:57 pm    Post subject: Reply with quote
You really need to pick up a cheap dwell/tach meter. Should be part of any VW toolbox. You don't need to install one on the dash, Just pick up a cheap portable one. Less than $30. Until then, give me a call and borrow mine. I think mine is 20 years old.
74 VW Thing - Walküre
78 GMC Motorhome - Valhalla
"Patina" my ass, that's rust
Recovering Split Bus Addict
World 181 Registry Map:
http://bit.ly/1axDF1r
Gitm registared boys!
Officially, there are only 112 181s in the world
vw_hank
vw_hank is offline
PostPosted: Tue Apr 05, 2011 11:08 pm    Post subject: Reply with quote
PatterBon,, See I told you there were guys in your neighborhood Wink
And if you know John Morris? then your in good hands Wink
1302s sunroof..
marklee
marklee is offline
PostPosted: Wed Apr 06, 2011 5:38 am    Post subject: Reply with quote
I agree, but if the wrong type or grade of oil was used it couldve been done an hour ago the trouble would still be apparant.....
