BerT3  Samba Member
Joined: August 18, 2002 Posts: 1469 Location: Antwerp
Posted: Tue Sep 13, 2011 11:40 pm Post subject: |
| Brent wrote: | | vlad01 wrote: | could be an excuse for a Bert drop spindles ey?  |
Yep. I've ordered a pair. They're supposed to ship this week, I think. |
Indeed - will be collected over 2 hours - I hope to have the first sets out tomorrow morning
BerT3 |
68notch Samba Member
Joined: August 16, 2007 Posts: 456 Location: Perth, Western Australia.
Posted: Thu Sep 15, 2011 1:23 am Post subject: |
| vlad01 wrote: | lol that ain't a precision level the one i use at work can measure 0.2mm per meter of deviation (in the order of 100th of a deg). it costs around a 1000 buk for one though and it ain't digital.
calibrating against a kitchen bench? lol
see if you can hire one from an engineer or some one like that.
Anyways looks like u have a problem somewhere if you can visually see the difference in camber. Is the control arm angles the same on both sides? |
You could also give the iphone handy level app a go?
http://www.youtube.com/watch?v=g47zdo_aDOI _________________ John
68 Aussie notch
97 Ford PV (Panel Van) for sale
2011 Citroen Berlingo
RHD dash pad project http://www.thesamba.com/vw/forum/viewtopic.php?t=475227
Brent Samba Member
Joined: April 28, 2010 Posts: 986 Location: Yokosuka, Japan
Posted: Thu Sep 15, 2011 9:54 am Post subject: |
| 68notch wrote: | | vlad01 wrote: | lol that ain't a precision level the one i use at work can measure 0.2mm per meter of deviation (in the order of 100th of a deg). it costs around a 1000 buk for one though and it ain't digital.
You also give the iphone handy level app a go?
http://www.youtube.com/watch?v=g47zdo_aDOI |
I have that same app on my android phone. I tried it before I bought the little red level. The problem was the volume buttons are in the way and the phone would keep buzzing as the volume turned the phone to vibrate.
I need one of these:
 _________________ 69 Fastback Build (Doris) |
Brent Samba Member
Posted: Thu Sep 15, 2011 6:11 pm Post subject: |
I pulled 'new' beam out of the truck tonight and had a revelation as to my camber problem. It's been in front of my face this whole time.
I immediately noticed how straight the other beams tie rods were. Look at this tie rod. I guess I just thought it was supposed to have that bend there. It's right where it goes over the frame head, so I thought it's supposed to be there to clear it. Doh.
So if the car was hit there, hit a gutter, or whatever it was enough to bend the tie rod. I'm assuming something else bent and that's why I can't get my camber right. Here's the replacement.
supaninja Samba Member
Brent Samba Member
Posted: Thu Sep 15, 2011 6:24 pm Post subject: |
| supaninja wrote: | | bend tie rod is going to mess with your toe in not your camber. |
I realize that, but how did it get bent? _________________ 69 Fastback Build (Doris) |
Brent Samba Member
Posted: Thu Sep 15, 2011 8:16 pm Post subject: |
That's what I was suggesting. And something else bent as well which is messing with the camber.
$65 isn't too bad. I have 195's up front, 205's in the back. _________________ 69 Fastback Build (Doris) |
Brent Samba Member
Posted: Thu Sep 15, 2011 10:01 pm Post subject: |
| supaninja wrote: | PO bent one already, it would be foolish to not upgrade to stronger ones.
Brent- I should warn you about that site that I linked...don't go snooping around in the brake section, you might end up with nice shiny new brembo brake setup  |
Too late, I already snooped when I saw the modded drop spindles Clatter did. I just need to get this thing back together first as my budget is already blown big time.
My wife promises to buy me a Square if/when I restore her Ghia. One car at a time. I'm just meddling in the darkside now, but someday (in a few years)... I've been dreaming up the perfect car. That would be a good thread. _________________ 69 Fastback Build (Doris) |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 910 Location: Gardnerville, NV
Posted: Fri Sep 16, 2011 7:18 am Post subject: |
you and me both supa....Lmfao  _________________ 69 Fasty
71 Beetle
you wanna save something truly special... Restore a Fastback! |
vlad01 Samba Member
Joined: October 27, 2010 Posts: 2087 Location: Australia
Posted: Fri Sep 16, 2011 7:32 pm Post subject: |
hmm? I would be interested in stronger tie rods too.
there is no pics on that site? |
Brent Samba Member
Posted: Fri Sep 16, 2011 8:18 pm Post subject: |
I emailed him yesterday and then again today to give him all the measurements for the tie rods as he makes them to order. US and CDN are equal right now, so it's a pretty good deal.
I got the other beam tore apart tonight and will get out the blaster tomorrow to clean everything up. I'll take some pictures of my method of internal cleaning. The beam was totally original, I think the couple inches of grease saved it from rusting. Once I got all the grime off, you can see all the factory yellow paint over all the tie rod and ball joint nuts. Bump stops are perfect. I think I'll just use the entire beam instead of fitting the control arms into my other one. Then I know that there's no mismatch of wear in the bearing/bushings. Getting these parts cleaned up and painted should work out perfect with the arrival of my drop spindles.
Also, Jim Adney has some rear torsions from an IRS square for me. I don't really want to tear into the subframe again, but it will be easier now than later. _________________ 69 Fastback Build (Doris) |
vlad01 Samba Member
Posted: Fri Sep 16, 2011 8:30 pm Post subject: |
I will love to see your new tie rods when you get them. If all good I will place an order for them too.
I never thought about about til now but stock tie rods with 205 tires, massive vented brakes and 300-400 hp suby engine is not likely going to take such a punishment. |
Posted: Fri Sep 16, 2011 9:47 pm Post subject: |
| Brent wrote: | I emailed him yesterday and then again today to give him all the measurements for the tie rods as he makes them to order. US and CDN are equal right now, so it's a pretty good deal.
Also, Jim Adney has some rear torsions from an IRS square for me. I don't really want to tear into the subframe again, but it will be easier now than later. |
awesome news on everything dude!
Sweet, it should be easier for me to buy those tie rods since your giving him all the specs, I'm going to be ordering them real soon.
I'm getting the IRS subframe in the tomorrow or the next day, $25 heck ya! I'm hoping the later model stuff uses the long torsion bars so I can swap in my 24.5mm 944 torsions. If not i'll be on the hunt for some 944 ones since i'll be using 944 arms. _________________ http://i5.photobucket.com/albums/y163/chucky1974/ninja.gif
Nick
Megasquirted Type 4 powered Notch http://www.thesamba.com/vw/forum/viewtopic.php?t=427890&postdays=0&postorder=asc&start=0
Blog of Doom http://supaninjanick.wordpress.com/ |
Brent Samba Member
Posted: Fri Sep 16, 2011 10:11 pm Post subject: |
| supaninja wrote: | | Brent wrote: | I emailed him yesterday and then again today to give him all the measurements for the tie rods as he makes them to order. US and CDN are equal right now, so it's a pretty good deal.
I'm getting the IRS subframe in the tomorrow or the next day, $25 heck ya! I'm hoping the later model stuff uses the long torsion bars so I can swap in my 24.5mm 944 torsions. If not i'll be on the hunt for some 944 ones since i'll be using 944 arms. |
If I were to do it over I'd use a swing axle subframe and weld in the IRS arms. Then you'd have the horns and IRS. I've already painted it all pretty and just don't want to go do it over.
So, since I'm already talking about beefy tie rods, I emailed Lanner tonight about a kafer setup like what ISP used to make. Might be able to fit that one in the 'budget'. Man, I just need to add a T4 engine now! ...next car.
$25 is an awesome deal! I think the Square torsions are 23.5mm, so pretty close to the 944. Not sure about the length though, I know swing axle and IRS are different, 24" vs. 29"??? I'm not quite sure. _________________ 69 Fastback Build (Doris) |
vlad01 Samba Member
Posted: Fri Sep 16, 2011 10:19 pm Post subject: |
| Brent wrote: | | supaninja wrote: | | Brent wrote: | I emailed him yesterday and then again today to give him all the measurements for the tie rods as he makes them to order. US and CDN are equal right now, so it's a pretty good deal.
$25 is an awesome deal! I think the Square torsions are 23.5mm, so pretty close to the 944. Not sure about the length though, I know swing axle and IRS are different, 24" vs. 29"??? I'm not quite sure. |
thats my plan too  |
kooldub Samba Member
Posted: Thu Sep 22, 2011 9:20 am Post subject: |
brent- great build thread, thanks for sharing! quick question, saw your post in the wheel/tire forum and i am diggin the front tires for the 2liters, do you plan to lower your fasty? i'm rubbin a bit with my 145's on the same rim.. thanks!
kris _________________ 68 Camper - 1914cc w/ dual 40 webers
68 Fastback - EJ22 |
