Brent Samba Member
Joined: April 28, 2010 Posts: 1614 Location: San Tan Valley, AZ
Posted: Sat Jun 23, 2012 4:46 pm Post subject: |
Thanks Dong!
Update on a couple things here.
I had Dan Lawson and crew at Competition Enginnering in Phoenix put in an external cooler with a thermostatically controlled fan. It really helps bring the temp down and they did a really clean job of putting it in. I would have done it myself, but I've been staying at my Dad's place and he doesn't even have jack stands.
It's 110F here, so naturally the oil is still a bit hot, but by no way pegging high in the 250+ range as before.
On oil - this thread has been pretty helpful:
http://www.thesamba.com/vw/forum/viewtopic.php?t=467803&postdays=0&postorder=asc&start=0
With the 10W-30, she was barely making 10# per 1k, so I'm back to a thicker oil. Brad Penn this time from the shop when they put in the cooler. We'll see how she does as I'm driving to LA tomorrow morning. Very early to beat the heat. Wish I could be at the Invasion instead...
My oil leak from the pump cover is fixed now (second time), and I have no leaks from anywhere.
The custom breather box I had made was slightly too big. So I installed a second breather under the engine cover to the rear of the 'handle'. All is well so far.
New speedo cable is in, the last one broke on the wheel side. This one is a GEMO, so we'll see how it works out. I was a bit more conscientious putting this one in and avoiding any too tight curves in the cable.
Next up will be installing front beam skid plates. I'm tearing up my tow ring. _________________ 69 Fastback Build
Berg5 Build |
supaninja Samba Member
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Sun Jun 24, 2012 9:21 am Post subject: |
Brent it really turned out to be a beautiful car , very nice very nice!!! _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
Brent Samba Member
Posted: Sun Jun 24, 2012 5:57 pm Post subject: |
VWporscheGT3 wrote: |
Brent it really turned out to be a beautiful car , very nice very nice!!! |
Thank you!
Supaninja- I actually didn't go to the Invasion. I have a 5 week course near LA starting tomorrow morning. I wouldn't have made it back in time... Maybe next time.
So I drove from Phoenix to just north of LA today. Oil was much cooler, still a bit hot coming through the desert, but once I got into a little cooler weather I didn't see above 225. I think I'll try 10w-40 at the next oil change and see how does with pressure. The builder recommended 10w-40 or 20w-50, so I'll try going down in viscosity at the next oil change. This thing takes a ton of oil now! 3 + 3/4 (full flow) + 2 (sump) + 2 (cooler and lines). That's almost 8 quarts!
But she's running well, and I think the tune is just about right. I averaged just under 27 mpg with the car fully loaded front, back, rear and passenger seats. Plus my fat arse. _________________ 69 Fastback Build
Berg5 Build |
vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Sun Jun 24, 2012 8:48 pm Post subject: |
Brent wrote: |
Thank you!
But she's running well, and I think the tune is just about right. I averaged just under 27 mpg with the car fully loaded front, back, rear and passenger seats. Plus my fat arse. |
whats a quart ? is that comparable to a liter? |
Brent Samba Member
Posted: Sun Jun 24, 2012 9:19 pm Post subject: |
vlad01 wrote: |
A little bit less, 4 quarts (or 1 gallon) = 3.78 liters.
We're kind of stuck with the SAE unit measurement system over here, although SI makes more sense.
Supaninja - I'm running a Glenn refurb'd 010. I wonder if an SVDA would be worth it. I could probably get a few more mpg, and I have the vac ports on my carbs for it. Maybe time to send John C. an email? _________________ 69 Fastback Build
Berg5 Build |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Sun Jun 24, 2012 9:46 pm Post subject: |
I switched to the SVDA to run the lean cruise with my dells. It will run 40 or so degrees cooler running at 16-17 AFR at cruise, But i don't get enough time for it to settle down driving back and forth to work in 10 minutes. So it's pretty grumpy when it starts upnormally around 18-19 on the AFR until it gets warm. So I swapped back to 13Afr across the board.
My 26mm pump is 50 psi at start-up and 10psi when the oil is up to temp with 10w30 brad penn. did you blueprint the pump as per the "how to hot rod" book? Is it a snug fit in the case, or o-ringed? I about shat my pants when i first took the car out and saw what kind of pressure it was putting out. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Brent Samba Member
Posted: Mon Jun 25, 2012 6:59 am Post subject: |
W1K1 wrote: |
My 26mm pump is 50 psi at start-up and 10psi when the oil is up to temp with 10w30 brad penn. did you blueprint the pump as per the "how to hot rod" book? Is it a snug fit in the case, or o-ringed? I about shat my pants when i first took the car out and saw what kind of pressure it was putting out. |
I didn't pull the pump out of the case to check. Didn't want to create a leak. I didn't build it, so I don't know.
It does make decent pressure, about the same as you. I think with the 10w-30 plus it being so hot was dropping the pressure.
I'm all in the 13's for AFR too. _________________ 69 Fastback Build
Berg5 Build |
W1K1 Samba Member
Posted: Mon Jun 25, 2012 8:10 am Post subject: |
I guess if you are doing most of your driving more than 10 or 20 minutes, switching to an SVDA and rejetting to 16AFR at light cruise would bring the head temps down, and boost you MPG.
I would say 225F in the desert with an aircooled is doing pretty good _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Sun Jul 01, 2012 11:13 pm Post subject: |
Got a pic of the cooler install?
I'd love to see it. _________________ Bus Motor Build
What’s That Noise?!? |
Brent Samba Member
Posted: Tue Jul 03, 2012 4:03 pm Post subject: |
Clatter wrote: |
I'd love to see it. |
Here's what I could get lying on my back with no jack stands. Notice relocation of the shock tower tabs. If I were to do it again I wouldn't bother, it's bolted to the body there anyway. The cooler went in as an afterthought, and if I were doing it again I'd use a Setrab from the beginning. But they did a nice job and had custom SS hoses made up so it fits all nice. Should last forever; using rubber hoses and hose clamps for FF or coolers kind of gives me a bad feeling. On the argument of how much power the fan draws robbing HP -- it's something like 500mA to run it; miniscule in comparison to something like headlights.
I've been driving around Ventura a lot and temps are much lower now.
I also put in a breather and have it hooked up the the R valve cover. Quality on the Bugpack breather is questionable, but it works.
Berg5 Build |
IAMIROY Samba Member
Joined: September 27, 2011 Posts: 294 Location: Palmdale, CA
Posted: Tue Jul 03, 2012 7:41 pm Post subject: |
Looks good, glad it made a difference. _________________ Mark's Squareback build |
FASTBACKDON The other insensitive jerk like Neil
Joined: October 08, 2004 Posts: 3592 Location: TORRANCE CALIF
Posted: Tue Jul 03, 2012 8:06 pm Post subject: |
I agree 100% I love that car Brent. I wish mine was even close to yours in quality. Thanks for the good conversation we had. Hope you enjoyed Classic. _________________ FUCK CANCER FUCK CANCER FUCK CANCER!!
Mom 25 months of standing up to Cancer R.I.P I miss you so much.
Buy my best friends stuff
http://www.thesamba.com/vw/classifieds/search.php?username=56TIMOTEO
(21:10:42) Jennepher: Russell is our proudest achievment. I feel like Samba created him from a little nugget of crap into a full blown adult. |
Brent Samba Member
Posted: Wed Jul 04, 2012 12:02 am Post subject: |
FASTBACKDON wrote: |
I agree 100% I love that car Brent. I wish mine was even close to yours in quality. Thanks for the good conversation we had. Hope you enjoyed Classic. |
Thanks Don! I'll make it to LA area again for the PCH cruise on the 22nd. Looking forward to meeting up with the T3 crowd. I hope you can make it out to the meet point and represent the Fastbacks! I have a feeling I may be the lone one if it's like the BBQ. _________________ 69 Fastback Build
Berg5 Build |
Brent Samba Member
Posted: Wed Jul 04, 2012 12:08 am Post subject: |
IAMIROY wrote: |
Looks good, glad it made a difference. |
I'll be interested to see how Mark's runs. I still can't figure out why I was running so hot. This car is my driver right now, driving it everyday; I had to do something to get the oil temps down. _________________ 69 Fastback Build
Berg5 Build |
Posted: Wed Jul 04, 2012 8:47 pm Post subject: |
Brent wrote: |
IAMIROY wrote: |
I'll be interested to see how Mark's runs. I still can't figure out why I was running so hot. This car is my driver right now, driving it everyday; I had to do something to get the oil temps down. |
We won't have a temp gauge to look at.
You should road trip to Mark's one day this weekend. We are almost ready to put the motor in and fire it up. _________________ Mark's Squareback build |
W1K1 Samba Member
Posted: Wed Aug 08, 2012 9:24 am Post subject: |
Where are you measuring the oil temps from?
I have the sensor in the relief plug hole, and am getting some high oil temps with this 30C + weather we are having lately.
I'm thinking of a cooler addition as well _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
Brent Samba Member
Posted: Thu Aug 09, 2012 6:15 pm Post subject: |
W1K1 wrote: |
I'm thinking of a cooler addition as well |
I'm borrowing this picture, but it's set up just like this one. Drill and tap right into the flow stream. Now that the cooler is installed, it's getting temps into the cooler.
Before the cooler I was getting around 250 just cruising the freeway. Now with the cooler, I can drive all day and it will only get above 225 if I'm really working it up a hill and it's hot outside. I drove it through the Arizona desert at the end of June and it stayed pretty cool considering it was 110 outside. I'm pretty confident the gauges are right too, as I tried a couple and tested in boiling water.
I also took off the deep sump and haven't noticed any change in temperature. It just seemed to add a lot of extra oil ($$) and I didn't like that the strainer didn't fit with it on.
In other news, I put the car into storage a few days ago. I'm taking an overseas job and it's just not practical to take with me. She's in good hands though; indoor covered storage, temp/humidity controlled, and a monthly start up, fluid check, and battery charge. I did it once before with another vehicle and was impressed with the service.
The break will give me some time to plan out my dream Squareback build too. _________________ 69 Fastback Build
Berg5 Build |
