Brent's 69 Fastback Build
Goto page Previous  1, 2, 3 ... 15, 16, 17 ... 28, 29, 30  Next
Brent
Brent is offline
PostPosted: Wed Feb 22, 2012 6:54 pm    Post subject: Reply with quote
I had this breather made from flatblack12345 who advertises here in the classifieds. I sent him this sketch and today he sent me the finished pics. It's super nice!
So the plan is to have the right valve cover and the stock breather go to the two inlets on the bottom, then the 5/8" outlet near the top will go the the exhaust evacuation. It will mount up under the deck on the right side, it will be tight but I had a good look at Dave's car and it will fit. The footprint is 4.5" cube, roughly 1.58 qts.
69 Fastback Build (Doris)
suruba
suruba is offline
PostPosted: Wed Feb 22, 2012 6:55 pm    Post subject: Reply with quote
that's pretty sweet.
Dave
W1K1
W1K1 is offline
PostPosted: Wed Feb 22, 2012 7:11 pm    Post subject: Reply with quote
Where did the crankcase evac valve come from?
Interesting , i've been wondering how to vent my new stroker.
Do tell
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1961 beetle
1965 squareback 1500E
Brent
Brent is offline
PostPosted: Wed Feb 22, 2012 7:40 pm    Post subject: Reply with quote
Do tell
Supaninja's influence on that one.
The valve and adapter/stem both came from Jegs. I used the dual purpose one so that I could also hook up a wideband to the same connection just upstream of the muffler. Here are the links.
http://www.jegs.com/i/JEGS+Performance+Products/555/30739/10002/-1
http://www.jegs.com/i/JEGS-Performance-Products/555/52211/10002/-1
It doesn't draw a very strong vacuum using the thumb over end of the hose method, even at fairly high RPM. But it's enough that it will suck out any vapor and keep a slight vacuum on the case.
I decided to only do the R valve cover, it seems pretty common from what I've been reading. Can't wait to get it all installed.
W1K1
W1K1 is offline
PostPosted: Thu Feb 23, 2012 10:01 am    Post subject: Reply with quote
i wonder if it would work with my existing O2 sensor connection at a 90 on the collector? or does it have to be on an angle?
That breather box is a nice piece of work.
1973 super
1961 beetle
DONGKG
The Araneta Boys
Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
DONGKG is offline
PostPosted: Fri Feb 24, 2012 3:43 am    Post subject: Reply with quote
I was reading this thread and I noticed the quality of the restoration you are giving your fasty. Nice one. Keep us posted.
'67 KG Cabrio (Mickey) ;
'66 Type 3 (Sharky 2)
'72 Type 2 Homey
'67 Splitty Bus
'65 beetle;'69 Country Buggy; TOOB MEMBER #20
Brent
Brent is offline
PostPosted: Fri Feb 24, 2012 9:18 am    Post subject: Reply with quote
Thanks DONGKG!
W1K1 - I would think the pipe needs to be at an angle. If it was at a 90, the velocity of the exhaust over the end wouldn't have the same effect in drawing a vacuum. Well, that's what I think and I can't prove it. I've seen at least one exhaust setup with two bungs for both. Then you wouldn't need the one I have, just the weld in pipe with threads for the valve at the other end. I think that's what supaninja has.
In other news, I was called to stop by the body shop yesterday. My 'new' door fits worse than the one with the broken hinge. The gaps are just all off with the driver door. They'll fix it, they just wanted to show me first. Sucks...
Yeti69
Yeti69 is offline
PostPosted: Sat Feb 25, 2012 11:03 am    Post subject: Reply with quote
too bad - I know that the doors really suck big time. Experienced the exact same thing. Collected a couple of doors (allthough they are no longer easy available in Germany) before I found the best way to fix the problem: re-use the og door after a full resto of the sheetmetal which was quite wavey after a "professional" sand blasted the outer skin Sad
I can exactly imagine your excitment to finally see the body in paint - 1 year ago I was at the same stage...
But, from what I read you did everything right by choosing this shop - I also can't wait to see Doris' gleaming, shiny body in all its fresh paint! Wink
1966 Fastback "The Volksback"
watch my Blog: http://yeti69.blogspot.com/
My Baja build Blog: http://volksstreaker.blogspot.de/
Brent
Brent is offline
PostPosted: Sun Mar 11, 2012 6:05 pm    Post subject: Reply with quote
The driver door is done. They had to shrink it quite a bit from the inside to get the waves out. I'm not sure of the process but it looks like a bunch of tack welds to the inside of the door panel. I think he said he used some sort of stud gun.
All the body work is done now and they had the roof, cowl, aprons, etc. all masked off to start painting the jambs and inside.
I finally decided on a color and you'll see some paint next week. PPG single stage.
In the meantime, I've been trying to get everything else bolt-on ready. Here's some of what I've been up to.
I think I'm done sandblasting now. Everything is now painted with either MS or SEM Hot Rod Black.
My fresh air boxes had some surface crust I sanded off. Then Bulldog, then painted (I forgot that picture, but will take one when I put them back in).
localboy style jig. I finally finished the vent wings today. Glad they are done, it's a big job rebuilding those. The driver side is right on, but the passenger seal is a little off. I think the mold used to make them didn't have a deep enough groove for the tabs on the wing frame. I looked at a bunch of pictures and they looked like they fit the same. But they're 99% done now. The felt channels I bought awhile ago were crappy quality. I ordered some new from WW (German) and they are much, much better; but we need 3 as they're too short. You can see where I had to glue in a smaller piece towards the bottom of the finished one.
This side project isn't done yet. I wanted to maintain a normal look of the mount with a modern DIN. I don't really like how the radio bezel fits when the mount is just dremeled out, so I went another way. The sides will get filled in.
suruba
suruba is offline
PostPosted: Mon Mar 12, 2012 7:57 pm    Post subject: Reply with quote
looks good dude. getting mine ready for new exhaust. still cruising it every day. Where did you get that tach?
Dave
supaninja
supaninja is offline
PostPosted: Mon Mar 12, 2012 8:36 pm    Post subject: Reply with quote
Holy crap everything looks awesome, but especially the tank and engine lid Shocked
http://i5.photobucket.com/albums/y163/chucky1974/ninja.gif
Nick
Megasquirted Type 4 powered Notch http://www.thesamba.com/vw/forum/viewtopic.php?t=427890&postdays=0&postorder=asc&start=0
Blog of Doom http://supaninjanick.wordpress.com/
View user's profile Send private message Send e-mail Yahoo Messenger Facebook Classifieds Feedback
Bobnotch
Bobnotch is offline
PostPosted: Tue Mar 13, 2012 5:53 am    Post subject: Reply with quote
Brent wrote:
I've still got to do this to the T-34. At least once I'm done using it for a table. Rolling Eyes
Bob 65 Notch S with Sunroof
71 Notch ...aka Krunchy; build pics here; http://www.thesamba.com/vw/forum/viewtopic.php?t=240540 -tear down
Brent
Brent is offline
PostPosted: Wed Mar 14, 2012 1:27 pm    Post subject: Reply with quote
Paint! L345 Light Grey.
In some of the pics it looks a little more greenish than it is; I think it's that big window in the shop right above the car.
More to come.
supaninja
PostPosted: Wed Mar 14, 2012 2:19 pm    Post subject: Reply with quote
That's lookin tit's Brent! Shocked
Nick
vlad01
vlad01 is offline
PostPosted: Wed Mar 14, 2012 3:19 pm    Post subject: Reply with quote
very nice.
Bobnotch
Bobnotch is offline
PostPosted: Thu Mar 15, 2012 7:36 am    Post subject: Reply with quote
Looks good Brent. Some really nice work. That color should be easy to keep clean too. Cool
vwtyp3variant
vwtyp3variant is offline
PostPosted: Thu Mar 15, 2012 1:35 pm    Post subject: Reply with quote
awsome job Very Happy
dwoah
dwoah is offline
PostPosted: Thu Mar 15, 2012 3:37 pm    Post subject: Reply with quote
looks GREAT!! I'm jealous, lol.
Dennis Womack
'71 fastback
Willo357
Willo357 is offline
PostPosted: Thu Mar 15, 2012 6:24 pm    Post subject: Reply with quote
Tasty..... ! Dancing
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...highlight=
redbug74
redbug74 is offline
PostPosted: Fri Mar 16, 2012 10:50 am    Post subject: Reply with quote
This rebuild totally kicks ass. I check this thread every 4-5 days just to see if there are any new developments. Good luck to you Brent and great job !!!!
Different Strokes for Different Volks
74 Standard Type 1
69 Squareback Type 3
55 Oval Type 1
Page 16 of 30
