Bret Young Samba Member
Joined: August 26, 2006 Posts: 756 Location: Turlock, CA
Posted: Wed Apr 06, 2011 1:04 pm Post subject: How to remove emergency brake cables |
Guys. I have to remove the transmission out of my 1965 bug again and I was hoping to get it out this time without taking the brakes apart. I got the drum off, and the emergency brake cable disconnected on each side from the lever inside of the drum....but I cannot for the life of me get that silver metal hook that hooks to the lever out of the backing plate. It wont fit through the hole.
How do you guys do it? |
63beryl Samba Member
Joined: November 24, 2006 Posts: 745 Location: SE Idaho
Posted: Wed Apr 06, 2011 1:53 pm Post subject: |
There's a little clip the bolts onto the back of the backing plate...(12 mm I think) once you remove this bolt, you can wiggle the clip around/off the cable enough to remove it from the backing plate.
This plate isn't exactly like your car, but notice how large the hole in the backing plate is once the clip has been removed.
hemifalcon Samba Member
Joined: June 15, 2005 Posts: 1481 Location: Union Grove, WI
Posted: Wed Apr 06, 2011 2:13 pm Post subject: |
Love you guys. Backing plate was pretty dirty and didnt even see the bolt. Man that sure made it a heck of a lot easier. Now that those are out, hard lines and tranny mounts and out she will come.
My day just got a whole lot better. |
Posted: Wed Apr 06, 2011 2:47 pm Post subject: |
Getting those clips back into place can be more difficult than removing them, but you'll cross that bridge later. Post some pics if you have any. |
Posted: Wed Apr 06, 2011 2:52 pm Post subject: |
Well for now, they are off. Transaxle will get pulled out this evening after class. I will address the reassembly later once I figure out what is wrong with the transaxle/possible sending it back to KCR.
I will let you know if I have problems putting it back together.
Thanks again guys. Appreciate it big time. |
Posted: Wed Apr 06, 2011 3:06 pm Post subject: |
Have you posted about the issues you're having with the trans? If the trans was rebuilt your problem is unlikely inside the trans, but something that needs adjusted. |
Posted: Wed Apr 06, 2011 5:31 pm Post subject: |
I talked to Kevin at KCR and had it checked out by a local VW shop. Loud noise happens when taking off from a dead stop. Grinding noise and when jacked up in the rear, the rear wheels have too much rotational play.
Have to pull it out, check to see if one of the large circlips came undone, and need to check to see if i have wear in the spider/side gears or check if the noise is from the differential.
I paid for a pro-street/freeway flier with a 3.88/.89 4th so if something might be wrong im pulling it. Im not gonna just keep driving and take a chance of it blowing up. On a college student budget, thats like 2 months pay. Gonna make sure everythings in good shape. |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Thu Apr 07, 2011 3:43 am Post subject: |
mrblyoung wrote: |
pay once-cry once. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
Posted: Thu Apr 07, 2011 10:12 am Post subject: |
I hear ya Bill. Thats been my motto for this entire build. Between that transmission and my Type 4 conversion, I have been committed to doing it right. No cheaping out on stuff.
Im glad I regeared the transmission to the above specs. Still have a little bit of tuning left to do, but 35MPG on the first trip at a constant 70MPH all day long is a nice way to go. Thats with 36 Dells and a 010 dizzy tuned by ear. And yes all of that was GPS verified. Have a few little tweaks that I still plan on changing (stock weight flywheel and ignition system with vacuum) to boost that up to my goal mark of 40MPG. |
ilustr8tor Samba Member
Joined: November 07, 2010 Posts: 426 Location: Maryland
Posted: Sun Sep 21, 2014 10:01 am Post subject: Removing backing plate |
I have disconnected the brake lines, emergency brake line and 4 bolts but the backing plate doesn't want to come off. Is there a trick to getting these off? _________________ I love this analog addition to my over digitzed life. |
grandpa pete Samba Member
mykidsbug Samba Member
Joined: April 07, 2011 Posts: 473 Location: SoSo Cal LA
Posted: Sun Sep 21, 2014 9:06 pm Post subject: |
ok, how do you put the cable back in? mine didn't have e-break when i got it and i want to add it. Sorry to hijack your forum. |
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2002 Location: Texas
Posted: Sun Sep 21, 2014 9:19 pm Post subject: |
I just finished doing this myself. Here's a pic of the clip on the back side of the backing plate. I think it's a 13mm bolt.
Here's a front view of the cable where it comes out. Kind of a pain in the ass.
If you can, get yourself volume 4 of the BugMe Videos on brakes. _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
Posted: Tue Sep 23, 2014 9:29 pm Post subject: |
was it difficult, I'm kind of a brick.. |
Cabo9302 Samba Member
Joined: September 14, 2014 Posts: 39 Location: DeepInTheHeart
Posted: Wed Sep 24, 2014 5:30 am Post subject: |
The most difficult part was getting that retaining bracket that bolts to the back side of the drum to hook into the hole of the backing plate properly before you're able to start tightening the bolt. It just takes patience, and then again, you may have no trouble with it at all. Looks like these:
http://www.thesamba.com/vw/classifieds/detail.php?id=1589062
Notice the small tab at the top of the bracket - it's what hooks into the backing plate hole. |
